help moisture in sidemarkers
Old Nov 19, 2001 | 02:43 PM
zgrm100's Avatar
i installed my clears like 2 weeks ago be4 reading the how to. So i didnt really seal anything just put them on. yesterday there was water on the inside of the lens! IS that bad?
Old Nov 19, 2001 | 03:20 PM
HulaMAX's Avatar
It can get bad if u don't do anything to dry them out. Can possible corrode the terminals and then rust.
Old Nov 19, 2001 | 03:29 PM
Greg's2kGLE's Avatar
Re: help moisture in sidemarkers
Try putting some sealant around where the two pieces come together on the edge. That should work
Old Nov 19, 2001 | 03:56 PM
PhatGuy
I had the same problems. What type of sealant should we be using? Something that can be removed without a mess in the future?
Old Nov 19, 2001 | 04:28 PM
MichaelAE's Avatar
I used clear silicone. The kind you use to seal a glass aquarium. I put the sealer around the clears I got from Autodynamic and have had them on in Seattle for several months with no condensation of any kind.
Old Nov 19, 2001 | 06:49 PM
Rob'sAE's Avatar
You're Faster, I'm Better
make sure you dry them out
make sure you dry them out very well before you seal them, or you risk sealing in the moisture. Either put them in an oven at 150-200 degrees for a few hours or use a blowdryer for about 30 minutes each. Worked for me!
Old Nov 27, 2001 | 07:54 AM
zgrm100's Avatar
Re: make sure you dry them out
ok thanks guys. where can i buy this selent. And i kinda have a problem. because when i was emoving my clears to install the clear bulbs in them, i excidently bent the metal prong that keep it in place on the side marker, so its kinda wobly now when its installed. Any help would be appreciated
Old Nov 27, 2001 | 08:01 AM
SC2K1's Avatar
You can get the sealant at an autoparts store. As for the the metal prong I think you may be able to bend it back. I know when I looked at mine they looked pretty sturdy.
Old Nov 27, 2001 | 10:02 AM
Flash2k2's Avatar
Re: Re: make sure you dry them out
Is this for the front or rear clear sidemarkers?? My rear passenger marker was wobbly when I installed it, but I put in three small self'stick pads on the back of the marker to fix it. The stock units had a three small rubber pads that the clears didn't have. It fixed the wobble right up....
Old Nov 27, 2001 | 07:52 PM
zgrm100's Avatar
Re: Re: Re: make sure you dry them out
i think its the rear one too. But coul dbe the front dont remeber now. Can you tell me where you got the stick pads? And also where can i get this sealant? Thanks for ur help bro.
Old Nov 28, 2001 | 08:09 AM
Flash2k2's Avatar
Re: Re: Re: Re: make sure you dry them out
I'm pretty sure the sealant can be bought at any autoparts store or hardware store...
I think it was 3M or Scotch that makes the selfstick pad - which i got from staples
Old Nov 28, 2001 | 11:16 AM
zgrm100's Avatar
Re: Re: Re: Re: Re: make sure you dry them out
what kind of sealant do i need again? Any specific brand?
Old Nov 29, 2001 | 03:18 PM
MichaelAE's Avatar
Re: Re: Re: Re: Re: Re: make sure you dry them out
Just buy silicone sealant at a hardware store or pet store (in the aquarium section). Doesn't matter which brand.
Old Nov 29, 2001 | 06:59 PM
Flash2k2's Avatar
Re: Re: Re: Re: Re: Re: Re: make sure you dry them out
I installed my clears about two weeks ago and have had no problems with moisture whatsoever - and it's rained alot this past week. Did you guys transfer the teal rubber seal on the stock connector into the clears?? Maybe I"m lucky
Old Nov 29, 2001 | 07:40 PM
Maximum Velocity's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: make sure you dry them out
I think that the moisture is coming in through the edge where the clear plastic meets the opaque plastic though. I sealed mine up when I got them and no problems whatsoever so far. As an added bonus, the silicone helps to releive some of the vertical looseness.
To whomever wants to dry them out...put them in the oven on a low temp for a little while. Hopefully the dry heat will remove most of the moisture. Also, if you can, put some dessicant in a cup in the oven too...that'll help.
Noela
Sep 26, 2015 08:22 AM
erictown
Aug 20, 2015 08:01 AM
teejnut
Feb 8, 2001 03:55 PM
mdeal
Dec 10, 2000 07:48 PM
Avalon Racing
Dec 7, 2000 06:35 AM
