Need some ideas..
Old Jun 2, 2009 | 08:01 PM
jkpgt96's Avatar
Need some ideas..
Well, tomorrow I am finally going to tear into the Maxima. I am doing plugs (bought the ngk laser platinums), plenum gasket since I am in there, oil change and would like to change the trans. fluid. The plugs, trans. fluid are original (almost 86k miles) so I figure it is time. Hopefully next week I will get to try to make that magical 13's pass..My question is this.
The drain plug on the transmission is stripped I found when I was looking at the car this afternoon. A hex key will not loosen it anymore because it looks like someone tried to change the fluid and just ended up screwing up the plug. So...any ideas as to how to get it out?
Old Jun 2, 2009 | 08:15 PM
pimpin02max's Avatar
Sucks to here man...at least all your having problems with is the drain plug...I have to replace my whole transmission!!! Is there any way you could fit a vice-grip on it??? If that doesn't work you could always weld something on there that you could get a wrench or a ratchet on. Other then that I really don't know what else there is to do.
Old Jun 2, 2009 | 08:33 PM
jkpgt96's Avatar
The welder is at my buddy's shop...If it doesn't get done, it doesn't get done, but I dont want to pay 230 bucks for Nissan to do it..
Old Jun 2, 2009 | 10:49 PM
rroderiques77's Avatar
Demodded and Forgotten
Take a dremel and attempt to grind the sides of the drain plug until straight again. You will have to enlarge to the next size up.
It will be easier to remove the pan in order to try to get the plug out.
Old Jun 2, 2009 | 11:00 PM
CMax03's Avatar
How about some small jeweler files or a or run it thru a die. Dremel is just gonna do more damage!
justmaxxin
Jun 18, 2014 05:36 AM
fatboyslim86440
Mar 4, 2011 07:26 PM
DIVINCI
May 3, 2009 10:34 PM
VQmaxi17
Feb 1, 2007 07:46 AM
albo
Sep 9, 2006 08:31 AM
