MAF question
Old Sep 24, 2009 | 12:51 PM
nismoSEXIMA's Avatar
MAF question
ok so currently im going through some MAF problems..my stock one was on its way out so i ordered a new one from ebay for $100... when i got it i opened the box and noticed it looked like a 3.5 MAF... but i put it in anyway. the car ran great for about 3 weeks, then it started to make the car sputter so i would have to unplug it and blow in it or kinda tap the MAF connector then it would run fine... so i decided to put my old one back in and that completly stopped working the car would start but amost have a like a rev limiter at about 2700 rpm.... and if i would try and put the peadal to the floor the car would pop through the air filter and just about stall... so i put the other one back in and it is acting up some but not all the time..
ok so my question is does anyone make a aftermarket performance MAF of can i use one from another car? some help would be greatly appreciated thanks
Old Sep 24, 2009 | 01:37 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
call DaveB, an 00-01 MAF shuld have cost you less than $100 shipped to your house.
Old Sep 24, 2009 | 02:07 PM
who is DaveB???
Old Sep 24, 2009 | 02:26 PM
OC guy's Avatar
2002 maxima se
I think its a dealership in texas and theres a guy name dave b who may give you discount on any part you want. Just remember never buy any electric part's off ebay buy them straight from nissan dealer.
Old Sep 24, 2009 | 02:32 PM
viperboy's Avatar
Originally Posted by nismoSEXIMA
who is DaveB???
Look up the name in the Advanced Search. And please, make your sig smaller. Wayyyy too big.
Old Sep 26, 2009 | 10:53 AM
ok so know i have a new problem.. i bought a brand new MAF from nissan and i put it in, and the car is still doing the same thing as before. i dont know whats causing my car to act like it is... i am spraying nitrous but after the MAF and its a 75 shot.... but i havent had a problem and ive been spraying for almost 2 months now...the car starts but sounds like its running on 5 cylinders.... and i can barely drive it or give it any gas when im driving......im gonna check my coils and spark plugs but other than that i have no idea what it could be.... any help or ideas would be great. thanks
Old Sep 26, 2009 | 10:58 AM
knight_yyz's Avatar
Toolie
What is the part number on the original maf housing? what is the part number on the new maf housing. If they are different you need to go to a dealership and reflash the ECU for the new updated maf.
Old Sep 26, 2009 | 11:24 AM
do you always have to do that? ive never heard of that......how much are they gonna charge me to do that? i used the original housing i just put the new sensor in the old housing.....
Old Sep 26, 2009 | 01:50 PM
MURDRMAX's Avatar
i got mine for my 2000 from advanced auto parts, works great. do you run a aftermarket air cleaner also? if you do you need ta make sure its not an oiled filter. the airflow draws the oil out and it coats the maf causing a bad reading.
Old Sep 26, 2009 | 02:33 PM
Ghost_54's Avatar
You do when you possibly have changed a major part of the engine, and the dealer that sold you one should have asked you first for the numbers on your original old one.
I know if you had called Dave B. Southpoint Nissan TX 888-254-6060 as it was suggested to you, he would have straight out asked you for the these numbers to ensure you get a proper fit and match for you system.
Old Sep 26, 2009 | 07:14 PM
knight_yyz's Avatar
Toolie
if the MAF you replaced is the original one from the day you bought the car, and you went out and bought a brand spanking new one, then yes you have to go to the dealership because the ECU does not know how to read the signal from the MAF. Most dealerships will charge you either 1/2 or 1 full hour of labor. Not sure what the going rate is in your area.
Old Sep 29, 2009 | 11:15 AM
ok well i scanned my car yesterday and i have no MAF code i have a ignition circut code coming up.....i tried changing the ignition coil condenser and nothing its still running like its mis-firing...im gonna check my coils again when i get home and the plugs... hopefully ill get is fixed soon....
Old Sep 29, 2009 | 12:01 PM
RhodeyMax01's Avatar
I just purchased a new MAF sensor from Dave Burnette the other day because mine is on its way out. Nice guy to work with and at a great price highly recommended !
Old Sep 29, 2009 | 12:14 PM
zax 20th ae's Avatar
dave b, is old school hes been around for years. hes my answer to any oem problem.
Old Sep 29, 2009 | 12:15 PM
i got him on speed dial in my blackberry...no bs
Old Sep 29, 2009 | 12:24 PM
lol
Old Sep 30, 2009 | 10:27 AM
ok so after all the bull i finally fixed my car... it wasnt the ignition coil condenser...or the MAF..it was the passenger side front ignition coil..even though i tested it with a multimeter an it said it was good...i took it out put a new one in and the problem went away thank good....ok so thank to everyone for the help and insight...
Old Sep 30, 2009 | 11:11 AM
streetracero1's Avatar
what is an ignition coil condenser and whats it do?
Old Sep 30, 2009 | 12:29 PM
im not sure what it is..but when i tested it and it was no good so i changed it..its a little black condenser and its on the wire harness that runs along the front valve cover the giant tape log i call it
Old Oct 2, 2009 | 12:39 PM
02pearlyWHITES's Avatar
and your welcome to ME bacause im the one who told you what to check and how to check it. I did hear any thanks for that!
Old Oct 2, 2009 | 03:23 PM
hey thanks buddy i appreciate the input and the help.....p.s. nice car
Old Oct 3, 2009 | 05:44 PM
gpresar's Avatar
I recently replaced my MAF after getting a P0505 code and the power increase is quite note worthy. It's a bit like getting new glasses and noticing that the trees have leaves. I forgot just how much pep my Max used to have. Now if I can just get the idle adjusted properly. The idle air volume procedure isn't working for me.
Old Oct 6, 2009 | 02:06 PM
Thanks Buddy
Old Oct 6, 2009 | 03:52 PM
Grand_hustle17's Avatar
did you just randomly changed em??? im having some sputtering issues and i dont think its my MAF either... i changed my plugs to NGK laser platinum and it still sputtered, changed em at work today in the parking lot to NGK platinums and it still sputters... i cleaned my MAF and yet it still sputter... I get a P0300 code, Checked all my coils and they are fine... my question to you is, did yours sputter throughout the whole RPM range??? or was it a certain RPMs???
Old Oct 6, 2009 | 04:32 PM
http://s158.photobucket.com/albums/t...t=553d2ba4.flv
Check that out.... at 10 seconds in i had my foot on 75% the throttle then after 3600K it jumps to 4K and then drives fine and shifts... notice my CEL... My codes are P0057 and P0300
Old Oct 8, 2009 | 09:30 AM
ColinLynch's Avatar
try this
it sounds like you made need new 02 sensors my car had similar problems. I replaced the maf and it ran much beter but not perfect so i replaced both bank 1 and bank2 02 sensors haven't had any problems since. most likely the problem is caused by dirty 02 sensors picking up on exhaust being to oxygen rich or "too lean" try getting new 02 sensors this should fix the problem.
TallTom
57
Oct 14, 2025 05:16 PM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
