Engine noise
Old Jan 26, 2010 | 09:21 PM
mendezrj03max's Avatar
Engine noise
I found this video on you tube witch relates to the same sound thats coming from my endine. Does anyone know if this is a problem with the timing chain? What causes this to happen? This sound keeps coming back to me at 3000 to 3500k miles after an oil change. I check my oil level and its fine. No leaks, and it doesn't burn oil, so what can it be? Any ideas, Thanks.
http://www.youtube.com/watch?v=05yBcOoHOvA
Old Jan 26, 2010 | 09:26 PM
2slow's Avatar
Most likely the cam phasors (VTC), which is normal if it quickly disappears. It may be related to the timing chain guides, but I don't know enough about them to draw that conclusion.
Does the noise go away within 5-10 seconds of a start-up, or does it persist?
http://maxima.theowensfamily.com/tsb/NTB03-060.pdf
Old Jan 26, 2010 | 09:34 PM
It does go away within a few seconds but once i start driving i hear the noise again at around 2500 rpm then i goes away. If i stay at 2500 rpms the noise stays untill it shifts. Then the noise goes away. Also if i accelerate fast, there is no noise.
Old Jan 27, 2010 | 07:30 PM
Has anyone encounter this situation with a solution? I would love to get this issue fixed soon.
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
