Cattman 3" Catback Exhaust - Order Here!
Old May 24, 2011 | 11:50 AM
  #1721
Brl24's Avatar
Originally Posted by CMax03
Hybrid JWT SRI...These cars love a short intake...it works better at Higher rpm than those long intake tubes...I've got pictures of my recently revised Hybrid in the SRI measurement thread....
I'm just hesitant on the short ram just because the humid summer heat around here. Your max looks pretty clean, where are you running that intake?
Old May 24, 2011 | 02:05 PM
  #1722
NmexMAX's Avatar
dot dot dot ...
A little definitive and conclusive intake info:
http://forums.maxima.org/5th-generat...ai-vs-sri.html
http://forums.maxima.org/5th-generat...i-rethink.html
Old May 24, 2011 | 07:52 PM
  #1723
CMax03's Avatar
In freakin Houston, Tx.... You saw my profile advatar?
Old May 24, 2011 | 08:05 PM
  #1724
CMax03's Avatar
Originally Posted by NmexMAX
I believe that Sparks going to a less restrictive 3.5 medium length tube and SPARKS being tuned makes all the difference in the world....In an untuned state like myself long intakes seem to hinder my engines breathing and My Hybrid SRI seems to respond happier.....I'm not running a super short Ram Intake anything like SPARKS (once did) so I don't think we're comparing apples to apples.....Plus he's ran a larger intake for a while now... But I know for a fact running the stock MAF and long intakes don't work well together.....IF you really wanna make big power talk to SPARKS you will have to go the tuned route and larger MAF housing.....
Old May 25, 2011 | 07:42 AM
  #1725
NmexMAX's Avatar
dot dot dot ...
So you want me to talk to sparks about tuning an a larger MAF housing?
I haven't had a stock sized MAF housing since 2007, and have been AFR tuned since then too. I'm 98.5% sure most of Sparks largest power increase came from his manifold coupled with the aforementioned items.
A little touchy there. I didn't post that for you .... I posted it in general.
Old May 25, 2011 | 12:05 PM
  #1726
CMax03's Avatar
That's funny my response was for general info not directed too you Nmex
Old May 25, 2011 | 02:58 PM
  #1727
BobPezz's Avatar
They're were free!!! Some leftover upper shock bushings (the type that fit on the top of truck or american cars with upper and lower control arms). You can use an old exhaust isolator just cut it into quarters!
Awesome! I'd bet I could scrounge some used shock bushings from one of the local brakes/muffler/shock installers trash. Did you put them on just the B-pipe or also on the front muffler mount?
Old May 25, 2011 | 04:10 PM
  #1728
NmexMAX's Avatar
dot dot dot ...
So is there any reason why you quoted me then?
Old May 25, 2011 | 07:07 PM
  #1729
T_Behr904's Avatar
Old May 26, 2011 | 06:23 AM
  #1730
CMax03's Avatar
Just referring to the 2 sites you placed regarding SRI's...no biggie! Just trying to open eyes and sinuses of those more lost than I.......In General that is! I don't think I would be giving you any advice on intakes at all!!!! You've been LRMAF for several years and maybe one of the first to do it......
Old Jun 2, 2011 | 08:55 AM
  #1731
Rods03Max619's Avatar
Getting lighter rims makes me appreciate all my parts that much more especially this 3" Exhaust now drawing way more attention from cars trying to mess around especially on the back streets..
Old Jun 2, 2011 | 07:02 PM
  #1732
CMax03's Avatar
That 3" Cattman should torch those little 225/40/18 really easy now, even while rolling!!!!! I can desintegrate my OEM's really easy by just burping the throttle LOL!!!!!
Old Jun 3, 2011 | 05:58 PM
  #1733
NmexMAX's Avatar
dot dot dot ...
Add MMI's & an ETL for added roastage.
Old Jun 4, 2011 | 09:17 AM
  #1734
CMax03's Avatar
PIC's of MMI and ETL????????? What are these by the way???? Definitely not MMA!!!!!
Old Jun 6, 2011 | 07:31 AM
  #1735
Yeah I know 20 and up car pulls great but I know my timing is at 14* but if I do a WOT from 0 barely get a little chirp...going to put the OEM knock sensor back on see if that's the problem then its Nissan for a ECU reflash and bump timing to 17* and hope my low end power be there....any suggestions...
Old Jun 7, 2011 | 11:59 PM
  #1736
036mtmax's Avatar
MMI's=motor mount inserts and ETL=engine torque link.
Old Jun 11, 2011 | 07:55 AM
  #1737
zero2sixtyZ's Avatar
You embarrass me.
Since I still can't view the org on my PC, and 44 pages of filtering on my phone would suck... Let me ask you guys...
I got my Cattman 3" installed yesterday but it isn't sitting there perfectly. It bangs around over the rear beam. I know I had to remove the support closer to the rear, but is there anything else I need to remove to tuck it in place? Also what hanger bushings are you using? Mine sits fairly close to my AE rear already and I don't want it to burn into the valence.
Old Jun 11, 2011 | 09:07 AM
  #1738
You can check page 43 to see what Cmax03 did to stop his banging and as for the tips close to the muffler might have to go to a muffler shop to see what they can do since mine was like a 1/2 inch away then just kept raising up and burned the bumper a little.......Good Luck and if you do another method post it up here....
Old Jun 11, 2011 | 09:44 AM
  #1739
NmexMAX's Avatar
dot dot dot ...
Also, use hose clamps to tighten the hangars. Mine used to do the same, just clamp it and it should tighten up and be fine.
Old Jun 12, 2011 | 01:51 AM
  #1740
CMax03's Avatar
Your problem is more than likely the rear 3" band clamp needs to be loosened and adjusted....if the 3" pipe contact is on the left side of the exhaust pipe make a line on the 2 pieces and than rotate the muffler a few degree counter-clockwise and retighten the rear muffler section....If the contact is on the right side of the pipe rotate the muffler clockwise a few degrees and retighten....there is adjustability built into it.....My bushing mod was to stop the hangar stud from swinging into the floor panel during hard high speed right hand turns.....
Old Jun 17, 2011 | 12:16 PM
  #1741
BUMP...for the Best Exhaust out there and should be on the Header list Soon...
Old Jun 18, 2011 | 09:58 PM
  #1742
CMax03's Avatar
Man I often wonder how much these Cattman catbacks will be worth in another 5 yrs...and if someone that really wants one but they're not being made anymore how much could honestly sell one for??????
Old Jun 19, 2011 | 05:14 PM
  #1743
Not sure but I probably wont sell mine if so retail.....
Old Jun 19, 2011 | 05:33 PM
  #1744
T_Behr904's Avatar
No telling, depending on condition, or if it was left in the box not installed you can sell it for what someone is willing to pay for it, and how much you would be willing to sell it for... Just my honest opinion, time will tell.
Old Jun 19, 2011 | 07:07 PM
  #1745
knight_yyz's Avatar
Toolie
look for urethane hangers on ebay, replace the soggy rubber ones
Old Jun 20, 2011 | 12:20 AM
  #1746
CMax03's Avatar
Maybe $700 for the 3".....$550 for the 2.5".....
Honestly a used one should be worth more if in really good condition.....and broke in already (Full of soot)!
Old Jun 26, 2011 | 10:29 PM
  #1747
Well these are difinitely worth the cash especially when I hear custom setups, "I paid half the price of that Cattman, like yeah buddy lets see who gets tired of there exhaust first...sure it will be you"...mine joy to my ears theres not so much....
Old Jun 27, 2011 | 12:57 PM
  #1748
CMax03's Avatar
Mine's gonna be there for awhile......Not gonna sell either for sometime to come.....just trying to see what the going price is for a nice used system....Rods03 you're a Cattman 3" Catback as well right? Or are you custom?
Old Jun 27, 2011 | 07:44 PM
  #1749
Cattman FTW...and just got on the Cattman Header list at Lucky #7, so 3 more to go, and 20 or more plus ponies I cant complain...
Old Jun 28, 2011 | 10:04 PM
  #1750
CMax03's Avatar
Your first comment sounded like you had a custom setup for half the price of Cattman...But I think you were mocking the "El Cheapos" that usually have something to say about Cattman's cost! Which I will say time and time again !!!!! He's undercharging us !!! That Catback and his headers are $1000 plus each, pieces of art with real street functuality..... Next time you hear a GM V6 with a performance exhaust system blaring you'll understand how sweet those Cattman products make your car sound.....
Old Jun 29, 2011 | 08:17 PM
  #1751
Yeah my friend has a Mustang and it just sounds like a Honda all Riced Out sound, like isnt that American Muscle doesnt sound nothing like one...
Old Jun 29, 2011 | 11:04 PM
  #1752
KnightRyder8776's Avatar
Is there a group buy going on now? I need one of these exhausts
Old Jun 30, 2011 | 10:00 AM
  #1753
Yeah, don't know how many he has for the exhaust, but he has 7 for the headers, needs 10, but you can call him, his number is on the 1st page....
Old Jul 3, 2011 | 08:20 AM
  #1754
CATTMAN=FTMFW....
Old Jul 5, 2011 | 08:21 PM
  #1755
Old Jul 6, 2011 | 06:03 AM
  #1756
CMax03's Avatar
18007599920 Cattman Performance
Old Jul 7, 2011 | 09:14 AM
  #1757
CMax03's Avatar
For those of you that have Cattman 3" catbacks......I've found another alternative other than modding the Cat gaskets to fit....I'll be ordering a few of these to see if they fit our flanges which they should.....I'll contact SCE's technical department first to get the measurement if I can't find them online...then I'll order a few to test fit on My 3" Cattman. This is the product:
http://www.summitracing.com/parts/SCE-9447/
Old Jul 7, 2011 | 09:19 AM
  #1758
CMax03's Avatar
Also here's the 2 bolt setup for a 2.5" catback:
http://www.summitracing.com/parts/SCE-4200/
Old Jul 7, 2011 | 03:13 PM
  #1759
You embarrass me.
I feel like an idiot still having issues with this. Much less banging, but I haven't been able to put the main support brace back on due to the exhaust sitting too low. Anyone?
Old Jul 7, 2011 | 04:16 PM
  #1760
Cattman's Avatar
Maxima.org Sponsor
When you refer to the main support brace, are you referring to the very thick stamped metal, multi-bolt plate farther to the front, or the thin sheet metal crosspiece that is farther back?
If the former, 1) it should never need to be removed for this installation, 2) there should no conflict with exhaust parts, but just in case 3) you can rotate it 180 degrees and re-attach (when you do it, you'll see how this could help). Remember, this is a key structural component of the chassis. The car is NOT meant to be driven without it.
If its the latter, this is normal because there isn't enough room for a 3" exhaust AND the crosspiece. No big deal because the only apparent function of that stupid thin crosspiece is to keep the stock catback from falling off when it finally rusts through, it has no structural role. Since you've now got a s/s exhaust, then rusting off is no longer a possibility and that piece can be removed entirely. If you want to leave it on the car, just put some spacers betwen that piece and the chassis (washers or nuts) to allow clearance room for the much thicker exhaust tubing.
Brian
