tightening the Throttle cable
Old Apr 1, 2010 | 02:12 PM
imported_D_Roc's Avatar
YES I DID SEARCH, the only ones i found was for the 4th gen and i know its a lost smiler to the 5th but still the guy said theres 2 8mm bolts hear the throttle body and the only bolt i see near the throttle body is the one holing the bracket that holds the cable holder and its like a 12mm bolt. other than that the only one i can think of is put some kind of spacers by the gas pedal, can any one help me out please, coz its loose about 1.5"
Also how lond do the head gaskets on these max's last how do i know if its about to blow? coz i want to clean my intake manifold and if i take it off i have to replace the gasket and it cost money$$ and if the head gasket blows any time soon i have to spent $$ on intake manifold gasket twice
btw my car has 147K
Old Apr 2, 2010 | 06:43 AM
essential1's Avatar
My axles cry for mercy...
They are not 8mm bolts. They should be either 12mm or 14mm. It's the easiest thing to do man. Just follow the throttle cables (1 for cruise control and 1 for your right foot) from the firewall all the way to the throttle body. You seriously cant miss it. counting both cables, there are 4 bolts. 2 to adjust it and 2 to tighten it again. If you really cant figure this out, close your hood, take it to a mechanic and dont try to do anything else to your car. No offense, but it's that simple.
The intake manifold gasket is so cheap and easy to get off, I wouldnt stress about changing it twice. In most cases, as long as the rest of your cooling system is up to par, the headgasket will be fine. Pressure from a clogged cooling system is USUALLY the cause of a blown headgasket.
And no offence, but if you cant figure out how to tighten the throttle cable, you cant take off your intake manifold, and if you cant take that off, you will never get to the headgasket, and if you cant do all that, you probably cant re-time your motor... Not trying to discourage you, I just dont want you to take your car apart and not be able to get it back together.
Old Apr 2, 2010 | 06:50 AM
1997MAXZ's Avatar
excellent point
Old Apr 2, 2010 | 07:50 AM
thanks ill look into it, i have replaced the manifold gaskrt before on a tundra and a corolla before but i really cant find a wat to tighten the cable ill look into it again today
Old Apr 4, 2010 | 07:15 AM
never mind i'm a dunba$$ i thought it will be little more complicated coz that seems a little too easy
Old Apr 4, 2010 | 07:52 AM
maximal01's Avatar
ya i have 199459 miles, and no head gasket problems its running good just make sure you dont over tighten the cable it will stick if you do
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
Noela
Sep 26, 2015 08:22 AM
thenewguyy
Sep 12, 2015 11:12 AM
pktaske
Sep 4, 2015 08:40 AM
