What is the best intake?
Old May 24, 2010 | 07:30 AM
  #241
soto2635's Avatar
Originally Posted by 2002AltimateV6
JWT Popcharger > * Especially in the RSRI form.
on the 3.0 what do u guys do with the sensor thats on a the snorkel??
Old May 24, 2010 | 07:43 AM
  #242
BlackHawk3G's Avatar
i would like to see some pictures of 3.0's with intakes.
Old May 24, 2010 | 09:11 AM
  #243
NmexMAX's Avatar
dot dot dot ...
3.0's have the IACV and related lines, so a little more complicated with respect to idling issues.
Old May 24, 2010 | 10:52 AM
  #244
soto2635's Avatar
X2
Old May 24, 2010 | 11:14 AM
  #245
essential1's Avatar
My axles cry for mercy...
^ if I could just find my camera charger
Old May 24, 2010 | 08:55 PM
  #246
soto2635's Avatar
well i did mine today thanks to all the ricer parts courtesy of autozone, took me a bit due to all the damn vacumm line but not to bad
Old May 24, 2010 | 10:02 PM
  #247
SoonerFan's Avatar
Cletus
just ziptie it somewhere near the intake...it will be fine
Old May 25, 2010 | 05:25 AM
  #248
Rochester's Avatar
Is he talking about the 5.0 gen's IAT? I always wondered where that model's temp sensor was.
Old May 25, 2010 | 05:27 AM
  #249
CMax03's Avatar
RSRI-REAL SHORT RAM INTAKE or SSRI!!!! The Stub! LOL!!!! No Torque?????
Old May 25, 2010 | 06:02 AM
  #250
NmexMAX's Avatar
dot dot dot ...
This short ram = the blue line
Old May 25, 2010 | 08:28 AM
  #251
soto2635's Avatar
wat a pain it was to do vacumm line after vacumm line the other one i just left near the filter, i must say it does run smoothly
Old May 25, 2010 | 08:45 AM
  #252
NmexMAX's Avatar
dot dot dot ...
Back to the lean condition issue.. as noted in the PCV diagram, @ idle/low loads/throttle angles, it will be lean, pretty much only @ idle.
Lean isn't good for cats/precats as we all know.
Old May 25, 2010 | 08:59 AM
  #253
Rochester's Avatar
NmexMAX, a small vacuum leak would cause the car to run lean, right? What are the symptoms of a lean A/F ratio that doesn't throw a CEL?
Old May 25, 2010 | 09:27 AM
  #254
NmexMAX's Avatar
dot dot dot ...
Erratic/funky idle and that's about it. Turn the AC on and see if it goes away.
Old May 25, 2010 | 09:43 AM
  #255
Rochester's Avatar
No, no... I'm good. I just want to know because, well, it's good to know.
So on the other hand, if you were running rich, you could also have a funky idle and rough ride, but in this case accompanied by smell and pinging?
Old May 25, 2010 | 10:34 AM
  #256
NmexMAX's Avatar
dot dot dot ...
It would have to be ungodly rich to affect the idle.
Throttle tip would stumble in very rich conditions. Mine has done this. In the summer, when I had the VC vented to atmosphere, I would see lean, so I added a bit of fuel @ around idle, and when I’d turn the AC on, it would go too rich, meaning it would idle fine, but once throttle increased ever so slightly, I’d see it go way rich and the car would semi stumble.
Too much of a horses pooch to be adjusting with respect to seasons, etc, so I decided to connect the PCV hose the way it was meant.
So, even @ 10.0 the idle will be fine. If you have a test pipe, the smell will be different. Pinging typically only occurs under load under different conditions, so I don’t think this would occur @ idle.
Old May 25, 2010 | 10:39 AM
  #257
Rochester's Avatar
Let's try another approach. If pinging occurs because of timing advanced too far, or running rich with pre-ignition, then a vacuum leak couldn't cause pinging because you'd be running lean... is that about right?
No, wait. This is even more direct: could an IM leak cause low-end pinging between 700 and 1200 RPM?
Old May 25, 2010 | 10:50 AM
  #258
NmexMAX's Avatar
dot dot dot ...
Pinging also occurs when lean. In short, I don't think your pinging is related to an air leak.
  #259
soto2635's Avatar
and whatever this guy has, get that best intake in the world, i think the overspray is included:
LMFAO!!
Old May 25, 2010 | 10:52 AM
  #260
Rochester's Avatar
Thank you.
Dude, I don't know where you've been this last year, but I love that you're around again.
Anyway... my quest continues.
High octane & octane boost - no.
Seafoam upper-engine cleaning - no.
New Mass Air Flow Sensor - no.
Time to see my mechanic, I think.
Old May 25, 2010 | 10:56 AM
  #261
NmexMAX's Avatar
dot dot dot ...
The last time I dyno’d I went quite lean, about 13.8, and the method was using a SAFCII, and I have Z33 injectors. The timing curve jumped about 2-3º globally ... so the fact that it is compounded by me taking fuel out and leaning the AFR didn’t cause any SK. I noticed a lot of SK on my A32, I wonder why.
Old May 25, 2010 | 01:38 PM
  #262
MoncefA33's Avatar
VQ35 heads have better knock suppression...
Old May 25, 2010 | 01:40 PM
  #263
NmexMAX's Avatar
dot dot dot ...
It went way after I changed my KS though.
Old May 25, 2010 | 01:58 PM
  #264
MoncefA33's Avatar
4th gen KS sucks...
Old May 25, 2010 | 02:11 PM
  #265
NmexMAX's Avatar
dot dot dot ...
Old May 25, 2010 | 02:18 PM
  #266
MoncefA33's Avatar
What were your impressions of the RSRI with respect to low-end/midrange/top-end power?
Old May 25, 2010 | 02:20 PM
  #267
NmexMAX's Avatar
dot dot dot ...
Noise. I then went back to the stock airbox & LRMAF.
Power delivery wasn’t consistent as seen in that dyno. I plan on dynoing sooner rather than later and this will show the gains of the velocity stack, albeit not peak #’s, but rather a smoother curve.
There are still a few myths to dispel for me.
Smoothest delivery = OEM Helmholtz. I need to find all the pieces to mine.
Does the ‘MAF screen help laminar flow, and if so, does it do for power delivery? The LR has a honeycomb, but as seen in my dynos power delivery left something to be desired. My current MAF housing does not have a screen/honeycomb, it has nothing.
Old May 25, 2010 | 03:36 PM
  #268
MoncefA33's Avatar
I'm gonna go ahead and go with a 3" MAF housing and my JWT pop charger/velocity stack and see how I like it in terms of driveability.
Is closed loop operation affected with a 3" MAF housing? Did you change sensor outputs on the SAFC2? I need to look into how to do it on EU...
Old May 25, 2010 | 04:08 PM
  #269
Rochester's Avatar
Does the ‘MAF screen help laminar flow...?
That's the whole point, isn't it? It certainly isn't there to catch debris.
Old May 25, 2010 | 05:20 PM
  #270
Z-Powered's Avatar
Sorry if this is OT, but what are the screws called that attach the MAF to the intake? They look like a star pattern...
Old May 25, 2010 | 05:21 PM
  #271
knight_yyz's Avatar
Toolie
I'm trying to figure this out as well. I know we should just be able to adjust one of the little pot screws inside the unit but it seems like no one knows how to do this except for maybe greddy and sr20den.
Old May 25, 2010 | 05:48 PM
  #272
MoncefA33's Avatar
The shatty thing is, the Ultimate doesn't have any pot screws. It's 100% software driven. I'll have to call GReddy sometime and be like WTF man how do I adjust for large MAF housing.
Old May 25, 2010 | 06:09 PM
  #273
Rochester's Avatar
Torx
Old May 25, 2010 | 06:27 PM
  #274
NmexMAX's Avatar
dot dot dot ...
Re: emu, is there an application list somewhere and if so, is the q45 an option?
Old May 25, 2010 | 06:29 PM
  #275
MoncefA33's Avatar
I'll check.
Old May 25, 2010 | 06:36 PM
  #276
NmexMAX's Avatar
dot dot dot ...
Heck, dandy used to run mafless with multiple maps for certain weather conditions.
Old May 25, 2010 | 06:42 PM
  #277
MoncefA33's Avatar
I'm not looking to do a MAP sensor conversion + temp correction maps...
Old May 26, 2010 | 06:11 AM
  #278
NmexMAX's Avatar
dot dot dot ...
Couldn't find more than these.
http://forums.maxima.org/5003701-post143.html
http://forums.maxima.org/4921445-post38.html
Old May 26, 2010 | 06:26 AM
  #279
essential1's Avatar
Torx
Actually its called "tamperproof torx". Notice the hole in the top of the torx tool.
http://www.amazon.com/pc-Tamper-Proo.../dp/B0009U6ABE
Old May 26, 2010 | 06:30 AM
  #280
Rochester's Avatar
That seems to be true on some, but not all. Mine are standard Torx heads, on my original MAF and my new one. I can't explain why these MAF screws vary from car to car, but they do.
