Autozone starters, anyone have experience?
Old May 20, 2010 | 07:10 AM
Amave's Avatar
So my starter has begun to crap out on me. When i go to start it, it sounds like the starter is dawing too many amps from my battery & is starting to kill it.
The starter will go dead for a split second and then crank. I measured the voltage it is drawing and my DMM reads 9 volts at the battery when cranking. It shouldn't read so low....
anyway i was looking for a starter and the only store that has them in stock is Autozone, and they also have a lifetime warranty, but my questions is would i be better off getting an OEM quality starter?
or would a lifetime warranty be better considering the warranty maybe the quality isn't so great ) .
i just don't want to have to keep taking this starter back to AZ every year because of the lack of quality.
Anyone ever buy one of these?
Old May 20, 2010 | 07:14 AM
higney85's Avatar
I have about 80K miles on a duralast starter from autozone- no issues. A lifetime warranty and a 30 minute install time made the financial decision easy for me.
Old May 20, 2010 | 07:23 AM
Amave's Avatar
yeah an easy to get to starter is wonderful
Old May 20, 2010 | 07:46 AM
Nelsito65's Avatar
About 42k miles on my Duralast; so far, no issues here either.
Old May 20, 2010 | 07:59 AM
Scottwax's Avatar
That's Mr. Detail to you
Couldn't get one of theirs to work in my '90 Accord, all three they gave me (two under warranty) would grind every 2nd or 3rd start. Went to an all Honda wrecking yard, got a used one which worked perfectly and got my money back on the Autozone starter.
Old May 20, 2010 | 08:13 AM
Amave's Avatar
so can i use an 11 tooth starter ? they don't have the starter listed as to how many teeth, but on other ato parts stores they specify 8 tooth or 11 tooth starters
Old May 21, 2010 | 12:23 AM
LoveSick's Avatar
Autozone doesn't make its own starters; it purchases from manufacturers that produce, rebuild, or repackage parts. It depends on the brand you get. I have a Bosch starter (rebuilt using factory core) for my Maxima that is more heavy duty than the stock one.
Also, the Autozone Duralast brand Ignition coils are genuine Made in Japan, repackaged for sale through another brand.
Old May 21, 2010 | 03:20 AM
BronxSleeperMax187's Avatar
Autozone's starter for my max has been good the last few years
Old May 21, 2010 | 04:19 AM
MURDRMAX's Avatar
i got mine from ebay and it was around 60 bucks shipped with no core charge. great build and it works wonderfully. dont waste your time with autozone.
Old May 21, 2010 | 04:22 AM
MURDRMAX's Avatar
here you go.....
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Old May 21, 2010 | 07:55 AM
NmexMAX's Avatar
dot dot dot ...
Nice thing is the warranty. It dies, bring it back ... and get another for free.
I've gone through 3 on my A32, but only paid once.
Old May 21, 2010 | 08:54 AM
Amave's Avatar
this is why it's so attractive... lifetime warranty
Old May 21, 2010 | 09:46 AM
medicjdl's Avatar
I got a rebuilt starter from advanced auto parts. It had a lifetime "limited" warranty. Worked great for about a month then crapped out on me. I went back to replace it and they told me I could only use the warranty once. So I used it and got another starter. Long story short and 4 starters later, They ended up ordering me a brand new starter. So I would stay away from rebuilds and go with a brand new one. GOOD LUCK !!
Old May 21, 2010 | 10:01 AM
NmexMAX's Avatar
dot dot dot ...
Or maybe stay away from advance, since AZ actually honors their lifetime warranty, at least in my case.
Old May 21, 2010 | 12:55 PM
mandyfig's Avatar
Limited warranty should mean as long as the defect is not by abuse, Advance Auto must honor and replace. 1 time use limited warranty is absurd. If you get another lemmon, they say you are out of luck? No I do not think so.
Old May 21, 2010 | 01:04 PM
tedo007's Avatar
faster than you think
I have tried in my 99 max I had. First one I bought came defect from the store. Second one I bought made all kind of weird noise when you try to crank it. I personally don't like them. Cheap stuff.
Old May 21, 2010 | 01:11 PM
Amave's Avatar
lifetime warranty and relatively easy to get to...sounds like a plan ....
on other car forums i've heard people say they never had a problem with AZ starters
Old May 21, 2010 | 02:33 PM
tbergma1's Avatar
Yep, i installed one on my 97, i had 45k on mine. No problems. Then i got hit from behind and totalled my car. Now i have a 2000se sterlingmist.
Old May 21, 2010 | 03:09 PM
SoulEater's Avatar
i had a starter from autozone for a few years and i got ZERO problem.
Old May 21, 2010 | 07:35 PM
mandyfig's Avatar
Looks like az starters are ok.
Old May 21, 2010 | 11:11 PM
NmexMAX's Avatar
dot dot dot ...
Old May 21, 2010 | 11:20 PM
rayac88's Avatar
had mine for 6 months, auto start multiple times a day. still cranks great
240tomax
Tires and Wheels
Feb 10, 2016 11:01 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima297
Sep 30, 2015 03:32 PM
Pied
Sep 26, 2015 03:29 PM
msellas
Sep 23, 2015 09:16 PM
