Underdrive pulley belt size...
Old Dec 3, 2010 | 09:19 PM
Tee00Max's Avatar
Does someone have the belt size that I need to get to run the UDP? I'm assuming its the serpentine belt. I guess I need the mm size. I searched on the ORG but I haven't came up with a definite size.
Old Dec 3, 2010 | 09:56 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
i recently asked the same thing. its listed on the unorthodox site, but that was too big for my application. i can get you the size in the am.
Old Dec 4, 2010 | 06:46 AM
Rochester's Avatar
Unorthodox Racing website page for their UDP on the 2000 Maxima:
http://www.unorthodoxracing.com/Item...ke=30&Model=92
...assuming that UR's UDP is the same diameter as your UDP.
This is one of the reasons I went with an OEM diameter on my light-weight crank pulley. Just saying.
Hope this helps. Good luck with the belt.
Old Dec 4, 2010 | 06:48 AM
phatboislim's Avatar
^where'd you get yours Rochester?
Old Dec 4, 2010 | 07:01 AM
Rochester's Avatar
Direct from Unorthodox Racing almost 2 years ago. It doesn't seem that they have an OEM-diameter crank pulley anymore... in curiosity, I was looking for it after I posted that link for the OP.
When they had it available last, they were asking $250. I paid $200 for mine new. However, with hindsight, there are far better things to be spending two bills on than a lightweight crank pulley.
If you can do a crank pulley for $50 to $100, that seems more reasonable for what it is. People can and will disagree. That's just my 2-cents.
Old Dec 4, 2010 | 07:06 AM
yea thats alot of money for little results...not like i have alot of power adders, etc for that to make THAT much of a difference. i could drop $200 on a wideband or a tuning unit to work towards a tune and get better results
Old Dec 4, 2010 | 07:12 AM
Tee00Max's Avatar
Yeah I just ordered my an OBX one...just wanted to get fully bolted on before I tuned it come first of the year...
Old Dec 4, 2010 | 07:15 AM
Tee00Max's Avatar
Ok that would be great...I ordered an OBX one, Im going to send them a message and ask them do they know the size as well...
Old Dec 4, 2010 | 07:21 AM
is OBX a lightweight OEM diameter pulley?
Old Dec 4, 2010 | 07:23 AM
Tee00Max's Avatar
lightweight....
Old Dec 4, 2010 | 07:24 AM
*feels retarded about question after looking at thread title again* LOL
Old Dec 4, 2010 | 07:26 AM
Tee00Max's Avatar
lol its all good, I couldn't see myself paying like $200 for one, im with you, im going to save that for my tuning items...
Old Dec 4, 2010 | 12:30 PM
Tee00Max's Avatar
anyone?? I have the OBX UDP if that helps..
Old Dec 4, 2010 | 12:42 PM
j23a45m9's Avatar
ralco makes a oem size lightweight one here is the link
http://cgi.ebay.com/ebaymotors/Ralco...Q5fAccessories
NmexMAX's Avatar
dot dot dot ...
Get OEM from Nissan. Most aftermarket's I've dealt with (all of them actually), tend to squeal. Nissan's do not squel unless they're actually loose.
Old Dec 4, 2010 | 12:45 PM
Tee00Max's Avatar
yeah Im def gonna get good quality belts, I just wanna find out what the size of them are..I guess there measured in mm. I know if all things fail I can do the old string measuring trick..
Old Dec 4, 2010 | 03:02 PM
NmexMAX's Avatar
dot dot dot ...
Go to Nissan and ASK for OEM BELTS from the sales clerk, or order them online by using your make and model and year, that should get you where you need to be.
36 inches? Hell, I can't remember, but asking for OEM Maxima belts eliminates having to ask for a certain size.
Old Dec 4, 2010 | 04:14 PM
Tee00Max's Avatar
Yeah I know but I still have to get the right size belt.
Old Dec 4, 2010 | 04:20 PM
NmexMAX's Avatar
dot dot dot ...
They will give you the right size if you order it from Nissan. Which is what I recommend.
Old Dec 4, 2010 | 04:21 PM
Tee00Max's Avatar
Yeah but I have an OBX UDP and they prob will not know the specs of those....I can see if I got a stock diameter but I didnt..
Old Dec 4, 2010 | 04:25 PM
NmexMAX's Avatar
dot dot dot ...
I have a UDP (don't even know the brand ), and I am using stock belts becaue thay are superior.
Also, from posts 9 & 10, it's seems to me as if it's lightweight, and not a smaller diameter? Even then, the stockers will fit a smaller pulley, since both belts have quite a bit of adjustability.
The only time yo need to use a smaller belt is when you completely eliminate say the AC pulley, which is what I used to do in the winter. I believe it's a total of 2" smaller (50.8mm)
Old Dec 4, 2010 | 04:34 PM
Tee00Max's Avatar
ooo ok good to know.....I thought since I was using the lightweight UDP i needed a new serpentine belt (prob spelled it wrong)...
Old Dec 4, 2010 | 04:35 PM
Tee00Max's Avatar
I ordered this one if it helps...
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_2612wt_754
Old Dec 4, 2010 | 05:10 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Gates is working fine here. The only time it squeals is when I completely deluge the underside of the car speeding through a 6"+ puddle And that only lasts for a couple seconds.
Old Dec 4, 2010 | 05:46 PM
Tee00Max's Avatar
yeah Gates always works good for me...
Old Dec 4, 2010 | 10:12 PM
MaximaSpd85's Avatar
per the stickies, k060408...ill cross reference it for u at work tomorrow to let u know how much ours are. but id go with gates also....
Old Dec 4, 2010 | 10:36 PM
Tee00Max's Avatar
man where did you find that at? as hard as i was looking!
Old Dec 4, 2010 | 10:45 PM
search function lol. also, its in the link someone provided in here for unorthodox, and here
http://www.greghome.com/Greg%27s%20G...e%20Pulley.htm
Tee00Max's Avatar
yeah i see it now, and I like the way that they get the pulley bolt loose...might have to try that method..
Old Dec 4, 2010 | 10:49 PM
Tee00Max's Avatar
the method in this site..
http://maxima.theowensfamily.com/udp.asp
Old Dec 4, 2010 | 10:57 PM
CMax03's Avatar
Did you get your answer yet?
Old Dec 4, 2010 | 10:59 PM
Tee00Max's Avatar
this is the only part number that I know of as of right now...
Old Dec 5, 2010 | 12:06 AM
Rods03Max619's Avatar
Got the same ones work good got a squel but they say I need a new A/C Compressor I was like F33k wanted it to be something cheap!! And I read some where on here that somebody had a OBX pulley and it broke off, but hope it works well for you I wwent with the Ralco Pulley off ebay also!!
Old Dec 5, 2010 | 01:48 PM
Tee00Max's Avatar
Yeah ive read different reviews about them and I know the positives and the negatives, I have also read some good things about them so...I will have to find out for myself....
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
homewrecker
Sep 24, 2015 07:01 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
