Eastern or Bosal PRECAT??
Old Feb 10, 2011 | 03:41 PM
paulpearl's Avatar
I am getting the dreaded P0430 on my OBDII scanner. Having a rattle under acceleration and know I have to replace my precat 170,000 miles. I have been reading for several hours many threads about this code. I am confused about which one would be an easier direct fit for me. The Eastern precat or Bosal or neither? I also ordered the nissan part #'s 20822-3y110 and 20840-3y110 cap/wiremesh. Can someone please help me before I order the precat? Thanks....
Old Feb 10, 2011 | 06:35 PM
VQP0WER's Avatar
Eastern will fit fine without the gasket. I could not get the precat and manifold to mate up with the OEM gasket installed. I had zero leaks without the gasket.
Old Mar 11, 2011 | 08:08 PM
Rods03Max619's Avatar
Mine is hella cloggedbthe front one bouts to gut it tomorrow and call it a day instead of buying one since I should still pass emissions with the fastcat and a new rear one already but if get a CEL will be buying one, if no CEL a step closer to Cattman Headers....
Old Mar 11, 2011 | 08:32 PM
CMax03's Avatar
Gut both of them and install a dual O2 sim.........
Old Mar 11, 2011 | 08:42 PM
Scottwax's Avatar
That's Mr. Detail to you
I'm going to install a dual O2 sim first to make sure it works for m before I do anything. No rollers here, they just check for codes.
Old Mar 11, 2011 | 09:30 PM
CMax03's Avatar
Scott I'm in Houston and I've been running Headers on everything I own...86.5 Hardbody (No more rollers it's an Antique now), 1990 Maxima VG30 (headers, cams, ecu, intake, ignition and passed emission rollers with ease), 2003 Maxima (headers for 3-4 yrs no problems)! I'll knock o wood but I've never failed a emission test ever!!!!
Old Mar 12, 2011 | 07:50 AM
Scottwax's Avatar
Just want to be on the safe side, hate to gut the cats or put headers on the car and then find out for some reason O2 sims won't work for me.
Old Mar 12, 2011 | 10:24 AM
CMax03's Avatar
They will work!!!!! there's no difference it's fooling the ECU with a signal in place of the secondary sensors regardless as to what you're exhaust setup is....."GUT THEM"
Old Mar 12, 2011 | 11:27 AM
So if I just gut the front will it trigger a CEL I see the 02 sensor on the manifold, is there one after the pre cat also underneath the heatshied. Don't want to gut the rear will sell that only got like 20000 miles on it bought it brand new from Nissan when I failed smog and it was more than the Cattman Headers I was pisses...since nothing online would ship to Cali...but Magnaflow has a 50 state legal I found for 250 I was like sh1 t where was this 2 years ago....
Old Mar 12, 2011 | 12:19 PM
spock's Avatar
There is an O2 sensor immeadiatly b4 and after each precat for 4 in total.
Old Mar 12, 2011 | 12:54 PM
efanatic's Avatar
So where do you get the 02 sims from? I have th ep0430 code and have to replace the front cat. But if I can rip them out that would be cool to
Old Mar 12, 2011 | 06:05 PM
CMax03's Avatar
Well why run unequally??????? here's the sims.....http://www.o2simulator.com/index.php...7b944b4bda570a
Old Mar 14, 2011 | 05:54 AM
TallTom's Avatar
Would an o2 spacer fit as well?
One of these:
http://www.amsperformance.com/cart/A...or-Spacer.html
carid
Sep 9, 2015 05:06 AM
paulpearl
Sep 2, 2015 07:50 AM
george__
Aug 18, 2015 07:06 PM
wiseguy
Jun 24, 2002 12:03 PM
