Replacing clutch soon ... Please I need your advice
Old Apr 5, 2011 | 07:35 PM
mahanddeem's Avatar
Hi
My clutch needs to be replaced soon on my 2k2 6spd ...... I assume it's the original stock clutch that is on the car now....Pedal feel is OK to me from the stiffness point...My car is pretty much stock apart from the 17 degree timing advance(if it you count it as a mod)...Now I need a clutch kit replacement that would meet (or exeed) the OEM clutch performance (but nothing crazy and would bankrupt me).... What should I buy ?
1.I always like the OEM ... but I started to hate the OEM clutch just from some orgers opinions.
2.My mechaninc is swearing by SACHS Clutch . It would cost me around 260$ from rockauto.com....I'm afraid after I install it I would find it sucks more than its name...What do you say about this clucth ?
3.I can get Exedy OEM replacement kit (NSK1002) for around 160-170$ shipped ... Should I go with that ? it seems to be a tempting option for the brand and price.
Excuse my post....I searched and my head was about to blow with all the debate around that issue...Some say exedy and then others say ACT and suddenly someone comes and swears by the OEM and so on...
And another point please , I don't want the hassle of getting a 350z clutch than moddding it and such...I am looking for direct fitment parts without any fancy work for a daily driver on a stock 2k2...
Thanks alot
Update
If I go with maxima OEM clutch , what parts I need other than the disc , the pressure plate and the throw out bearing ?
Old Apr 5, 2011 | 07:57 PM
L36's Avatar
L36
Hi
Thanks alot
Ill be monitoring this thread since im in the same boat with my 5 speed, need to know what brand of clutch to get...
It seems like the clutch job is fairly easy for maximas, as long as you have a transmission jack...
Old Apr 6, 2011 | 08:01 AM
TallTom's Avatar
From what I read, the 350x clutch needs no modding as long as you buy the Maxima throwout bearing and Maxima flywheel.
Old Apr 6, 2011 | 08:11 AM
phatboislim's Avatar
i have a 5th gen i think i got my stage 1 clutch from competition clutch for around the same price as teh clutch you are paying for...i paid another $2+ for my LWFW as well from competition clutch. not upset at all w/ my purchase. if you arent planning to make much power...a stock clutch and a LWFW would be a nice purchase. i just did stage 1 off of my principle of 'when you replace you upgrade'
Old Apr 6, 2011 | 08:27 AM
MintVQ35's Avatar
So you say the pedal feels fine from a stiffness perspective...so is the clutch slipping or you just feel that "it's time" to replace it?
If this is your daily driver I wouldn't do anything but a stock replacement clutch and leave the flywheel alone unless it's in bad shape and needs resurfacing/replacement, just wouldn't bother with a lightened flywheel for a daily driven street car personally.
Old Apr 6, 2011 | 10:20 AM
95%maxxedout's Avatar
imo there are mixed feelings for all of the different options for replacement clutches. i just recently bout my 02' and i just went with a stock replacement because of all the uncertainty of the different options.
i say just go oem if u didnt have a problem with it b4.
Old Apr 6, 2011 | 12:17 PM
mahanddeem's Avatar
thanks
what about the exedy OEM ? please other opinions are welcomed
Old Apr 6, 2011 | 03:05 PM
Lsgun1's Avatar
I would just go with a Nissan clutch from the dealer. If you had no problems then why not use what you know is good? You probably won't have a problem with just a standard aftermarket replacement but once it's in you are stuck with it so like I said, go with what you know is good.
Old Apr 6, 2011 | 03:40 PM
datsunzcar84's Avatar
I just replaced mine with a steel one piece flywheel and and exedy DE 350z clutch . Great combo IMO .
I will be done with it Friday . I will Let you know how it works out for me.
Old Apr 6, 2011 | 03:42 PM
And I can't speak for quality of sachs clutches But I have never had any issues with a exedy clutch kit. Very good quality IMO .
Old Apr 6, 2011 | 09:21 PM
mahanddeem's Avatar
Old Apr 6, 2011 | 09:24 PM
Yes get a "clutch kit" that will have all parts needed.
Old Apr 6, 2011 | 09:36 PM
Unklejoe's Avatar
What are you doing about a flywheel?
Old Apr 7, 2011 | 06:24 AM
I sent My stock dual mass to South Bend Clutch . They used the ring gear from my stocker (they can only buy the ring gear in lots of 500) and they sent me a steel one piece flywheel .
Old Apr 7, 2011 | 06:27 AM
OOmaxSE's Avatar
I believe you can throw in a 350Z clutch-- HR sounds like the toughest so you can look into that. I believe it has a stronger tq capacity than the exedy stage 1 for the Maxima's.
Old Apr 7, 2011 | 06:47 AM
rosader's Avatar
I have an Exedy and haven't had any problems going on 2 years now and believe me when I say I am hard on my clutch (I have to clutch the sh** out of my car every day inching my way up those freeway on-ramps with the traffic metering lights) I don't have any experience with ACT but I'm sure it's fine too. If you can get an Exedy OEM shipped for $170 I'd say go with that, it's a great brand.
Old Apr 7, 2011 | 07:52 AM
RA121625's Avatar
Yeah I hear that the 350z clutch is a good improvement over stock and still gives you that OEM reliability.
Old Apr 7, 2011 | 10:05 AM
mahanddeem's Avatar
I see from your sig that you have Exedy stage1 clutch...And I mentioned 170$ for Exedy OEM "replica" clutch...So they are different...But thanks for sharing your experience with your clutch .
Old Apr 7, 2011 | 10:38 AM
Yes there is a difference . As you go up in "stages" the clamping force and the torque it will be able to hold goes up .
If you don't plan to turbo or supercharger your max, IMO the exedy DE 350z clutch will be perfect . To go with a "stage " whatever or a HR 350z clutch your just going to throw money out the window for a mostly stock maxima .
Old Apr 7, 2011 | 01:58 PM
rosader's Avatar
I was giving props to Exedy products in general. It is not a "replica" when it says OEM it means it meets OEM standards. Yes I have the stage 1 but the Exedy OEM would be more than sufficient for your needs.
Old Nov 10, 2011 | 10:04 PM
lfthandwhip's Avatar
I am going to try DIY on my clutch. This will be the first one to do for myself and could use some good pointers.
Old Nov 10, 2011 | 10:55 PM
clintb3astwood's Avatar
I just replaced my stock clutch last week with an Exedy oe clutch kit, feels and grabs great! Now if only i had that light weight flywheel =./
Old Nov 11, 2011 | 03:36 AM
knight_yyz's Avatar
Toolie
The exedy clutch is slightly bigger than the 350z clutch in diameter and holds a little more torque. You will be fine with it if you are stock
Old Nov 11, 2011 | 04:51 AM
wirelessdude04's Avatar
Basically take your time replacing the clutch. Remember to drain your gear oil. Try using Redline 75w-90 gear oil. If you havnt replaced your gear oil recently. Might as well since your gonna be draining it out.
Also remember to tq down your clutch to spec
Old Nov 11, 2011 | 06:02 AM
Shift_Max's Avatar
Actually the better option now is to Use Redline MT85 instead of Redline MT90.
Old Nov 12, 2011 | 11:21 AM
tbizzle's Avatar
i went with a lightened flywheel and stock clutch disc and stage 1 clutch. I drove it everyday and was not hard at all.
Old Nov 12, 2011 | 07:41 PM
fishtale6spd's Avatar
Yea so I'm in the same boat as the op. Thinking bout going with exedy I've heard of it before check my sig for mods no s/c or turbo in the future but I want all tie bolt ons I can get should I just get a stage 1 or possibly 2 and I'm super hard on my clutch. Burn it, dump it all that I have 96k on factory. I would like a lightened flywheel also looking to spend 300 maybe 400 if so any good opinions on stuff
Old Dec 22, 2011 | 08:09 PM
artilarygoboom's Avatar
what are people averaging with there clutches? im at 149k orginal clutch and it catches kinda high but its not slipping yet.
Old Dec 23, 2011 | 08:51 PM
luvlexus101's Avatar
I'd make sure to get the car real high off the ground. Possibly look into getting a tranny or atv jack if I did it again. Make sure you take off all those plastic covers, they get really annoying. Also make sure you pull out both axles....ahem ahem beastwood..lul
Old Dec 24, 2011 | 01:00 AM
arlan's Avatar
i have exedy stage 1 and fidanza flywheel for almost 2.5 years still going strong
Old Dec 24, 2011 | 07:08 PM
-________- STFU! lol. yes make sure you pull both, or you will run into the nightmare i did. I did Exedy OE clutch kit, feels great, and grabs nice with the stock flywheel. the next one going in the car is exedy stage 1
Old Aug 13, 2014 | 11:02 AM
rickmilehigh's Avatar
oem flywheel exedy clutch
So I am thinking of replacing my clutch with exedy. But I was wondering if the combination of the exedy clutch dampers and the dual mass flywheel will be too springy?
Old Aug 13, 2014 | 11:03 AM
Hey man I'm wondering is this combo springy? Or did you not notice a difference? I'm concerned since both exedy and oem FW have dampers.. thanks.
Old Aug 13, 2014 | 11:42 AM
ateick's Avatar
OE Exedy clutch (NSK1002) doesn't have springs. The DM flywheel takes care of that. Stage 1 and 2 has springs but you would want to change to a solid flywheel.
jskirwin
Jun 8, 2016 08:49 AM
Starrider
Sep 17, 2015 07:26 AM
vanebecker
Aug 17, 2015 08:24 PM
carlosvq30
Aug 17, 2015 11:32 AM
Balkins
Aug 12, 2015 06:39 AM
