View Poll Results: 5th Gen LED mod thread, Yepe or Nepe?
I'd read it, maybe even subscribe to it, but I'd never actually have the balls to do it on my car
15.22%
I'm going to use this thread immediately to deck out my lights!
65.22%
I have no interest in modding my lights, stock is fine for me
4.35%
I've already done it, but would like to contribute my experience and technique to this thread
15.22%
Voters: 46. You may not vote on this poll
How to LED your 5th gen _~ Feeler thread .w. POLL
Old Mar 5, 2012 | 06:35 PM
  #201
guarj17's Avatar
I did the a/c controls today and damn does it look good. I also changed my cluster to blue to match. I was very suprised I soldered the a/c bulbs correctly lol it was a mess.
One question though and I know its newbie, but I can't get them damn key ring out!!! I read somewhere that you don't need to take it all apart it should just slide right out, but I cant get it. I got the black outer ring out of course, and got the inner piece about a quarter inch past the ignition, but can not get it to budge past that. What am I missing?
Old Mar 6, 2012 | 04:21 AM
  #202
TunerMaxima3000's Avatar
if you're having issues with it just take the trim piece off, otherwise you can break it. Sometimes trim gets stuck together pretty good. should be ok to just pop the bottom steering column piece off, if you did the gauges, you've already been there.
Old Mar 6, 2012 | 05:42 AM
  #203
guarj17's Avatar
I didn't take the steering column off to do the gauges. I didn't need to. I will try it again after work and try to get the steering column off.
I even tried that last night though, and I could not get the 3 screws all the way out they just kept spinning, but I will try it again.
Thanks Tuner. After the key ring is done, I will post pics of what your write-ups have made my car look like.
Old Mar 7, 2012 | 08:36 PM
  #204
Amerikaner83's Avatar
finished up my 4th gen...check it out!
http://forums.maxima.org/8392420-post57.html
Old Mar 8, 2012 | 06:23 AM
  #205
cjandura's Avatar
Tuner maby this could be a good solution for your lighting and other control options.
http://www.centrafuse.com/CentrafuseAuto.aspx
Old Mar 8, 2012 | 02:26 PM
  #206
What does that have to do with lighting? And I dont even have a computer PC...
Old Mar 8, 2012 | 03:34 PM
  #207
cjandura's Avatar
its basicly a front end for a carputer.you can configure it to do everything from ODB functions to controling the lighting and all entertaining functions
Old Mar 8, 2012 | 04:22 PM
  #208
Hmmm interesting... If I ever get a car-puter, it'll be way, way down the road. I don't expect to ever get one TBH, I have a pile of other things much farther up on my list of mods. Thanks for this cool to know whats out there.
Old Mar 9, 2012 | 06:39 AM
  #209
CustomLowz's Avatar
Sneak peak of my custom LED Reverse lights...
Old Mar 9, 2012 | 06:43 AM
  #210
cjandura's Avatar
Hey tuner i found a roll of this stuff in a cabinet in the garage yesterday.any use to you?
Illuminated pinstripe kit
Old Mar 9, 2012 | 06:44 AM
  #211
cjandura's Avatar
Looks good what did you use?i tried one of them 15w hid kits but it kept blowing the fuse and i was worried about the heat.
Old Mar 9, 2012 | 07:02 AM
  #212
guarj17's Avatar
Holy obnoxious reverse light! I want it!
That would really help me backing up at night because my tints make it impossible to see.
Old Mar 9, 2012 | 07:06 AM
  #213
CustomLowz's Avatar
The exact reason I did this. I should install the other side tonight.
Plus I am going to do this to my other car since it also has tinted windows.
Old Mar 9, 2012 | 07:10 AM
  #214
guarj17's Avatar
If you would be interested in doing a write-up or simply saying what you used, I think it would help the thread. (me)
Old Mar 9, 2012 | 07:13 AM
  #215
CustomLowz's Avatar
Ill see what I can do.
Old Mar 9, 2012 | 07:19 AM
  #216
superbrightleds.com has LED reverse lights...but I don't think they're simply plug and play... do tell! Me likey!
Old Mar 9, 2012 | 07:20 AM
  #217
CustomLowz's Avatar
The Plug and Play is on the left, and my retrofit is on the right...
Old Mar 9, 2012 | 07:22 AM
  #218
so what you're saying is you turned the "regular" LED backup lights into super-bright-WTF-searchlight-spotlight LED backup lights?
Old Mar 9, 2012 | 07:24 AM
  #219
CustomLowz's Avatar
you forgot the OMG, but Yes.
Super-Bright-OMG-WTF-Searchlight-Spotlight LED backup lights!
Old Mar 9, 2012 | 07:28 AM
  #220
HAHA I love it!
Old Mar 9, 2012 | 09:13 AM
  #221
I know what you did, same thing I plan on doing with the ones I used in my Puddle lights too
Old Mar 9, 2012 | 09:22 AM
  #222
cjandura's Avatar
so those bulbs do fit in the reverse light?did you rebase them with autolumination bases?
Old Mar 9, 2012 | 09:30 AM
  #223
CustomLowz's Avatar
No, and No
Old Mar 9, 2012 | 09:35 AM
  #224
did somebody retrofit a 48SMD panel in or something?
Old Mar 9, 2012 | 09:39 AM
  #225
CustomLowz's Avatar
I dont know, but mine is only 4 LEDs
Old Mar 9, 2012 | 06:44 PM
  #226
CustomLowz's Avatar
All outdoor lights off... Standing about 12 feet behind the car, just in reverse...
Old Mar 9, 2012 | 06:52 PM
  #227
Ok it's awesome, but if you're not going to post what you did, or how to do it, then wander off brah!
Come on dude.
Old Mar 9, 2012 | 06:55 PM
  #228
CustomLowz's Avatar
Come on dude.
Im working on it... relax...
Old Mar 9, 2012 | 07:10 PM
  #229
CustomLowz's Avatar
I used These bulbs: 4W 12V 440 Lumen 60 degree Replacement LED bulbs (halogen replacements)
First I took the ring off of the top and removed the lens. De-soldered the 2 wires from the LEDs and then unscrewed the base. After the metal housing was removed, I re-soldered the wires to the LEDs.
I took the loose lens and figured out the size of hole I would need to make. Using the cutting disk and grinding pad on my dremel I made the hole slightly smaller than the LED lens.
After I epoxied the lens to the tail light housing, and let dry for 20 minutes. then took the LED bulbs and base, stuck them back into the holes in the epoxied lens, and then expoxied them to the lens. Let dry for a few hours.
After that was done, I took the prongs from the bulb, bend them outward sligtly and plugged directly into the reverse socket. Ran some electrical tape to hold in place (didnt know how well the lights were going to work, so I taped it as a temp), and installed them into the car...
Shortly I will remove the tape, and remove the connector from the tail light harness. I plan on crimping on some connectors, and connecting them directly to the bulb.
This is the end result.
and both sides done:
Old Mar 10, 2012 | 05:10 AM
  #230
Thought so
Nice work dude those are close to the same style I put in my Puddle lights, and those are the ones I'm going to put into the G's reverse lights too
How are they at night, actually? Is it overkill? I'm worried about it being way too obnoxious, perhaps if I can aim them down enough..
Old Mar 10, 2012 | 05:20 AM
  #231
CustomLowz's Avatar
Thought so
simply put... It looks like I have headlights coming out of the back of my car... You can always go for a bulb thats not as bright... Mine are 440 lumens each and you can go for something in the 150-200 range.
Old Mar 10, 2012 | 05:33 AM
  #232
cjandura's Avatar
Just for a thought i wonder how bright that 30w flood light single chip bulb would be in there?
Old Mar 10, 2012 | 06:00 AM
  #233
I'll probably put the 16 Ohm resistors on them as well to dim it down, same as I did for my Puddle lights.
Also cuts the heat output large, so you don't have to worry bout melting housings
hope you didn't use just Hot glue or something, any length of reversing and you'll melt them. Likely it'll be ok as they're not on long. But they get hot FAST running full wattage.
Maybe I'll grab another pair, my Mirrors are done until the relay's get here, and I'm waiting on a gauge face to keep my LED project going. Everything else is on hold... and the temp outside has sucked. So this sounds like another little project.
OAN Customzlow, I'm in for some actual output shots!!!
Old Mar 10, 2012 | 06:06 AM
  #234
CustomLowz's Avatar
Also, they are Epoxied in, so the heat shouldn't effect anything. I've already had them on for a few minutes at a time while taking pictures and whatnot, so I think they will be good.
I will try to get some good output shots in the near future...
Old Mar 10, 2012 | 06:15 AM
  #235
Good call on the epoxy that's what I used to mount mine as well. Smart man.
In for pics!! Nice work again dude.
Old Mar 10, 2012 | 06:36 AM
  #236
CustomLowz's Avatar
I am also planning on doing this to my forester (has darker windows than the maxima)
I have an idea how to make the install easier for the next vehicle, but I wont share the idea yet because I dont want anybody else to try it and ruin their lights...
Old Mar 10, 2012 | 09:33 AM
  #237
dude - NICE job, man!
Old Mar 10, 2012 | 11:51 AM
  #238
What's with all the electrical tape, etc, and harness on piece on wires then finally, the heat sink that has the actual LED's on it?
I can't make sense of it.
Old Mar 10, 2012 | 02:57 PM
  #239
CustomLowz's Avatar
if you read the previous posts you would have seen that its to test the system. The connections will get connectors that will plug into each other.
Old Mar 10, 2012 | 04:27 PM
  #240
Ah I did miss that my apologies dude.
