Intake Manifold Thermal Coating/Heat Shield
Old Apr 4, 2013 | 02:08 PM
  #81
95VQ30's Avatar
if only
http://forums.maxima.org/5th-generat...-so-blahh.html
Old Apr 4, 2013 | 02:11 PM
  #82
cjandura's Avatar
Originally Posted by Chris Gregg
If it allows the venting and therefore elimination of under hood hot air pockets, that is a positive. Of course, it's really only going to be BENEFICIAL if those hot air pockets are centralized at the intake plenum and/or air intake (assuming use of a cone filter or ghetto air box).
Unless someone maps out an under hood temperature grid, hood spacing, hood vents, duct piping, removal of splash shields is all kinda snake oil to me....IMHO.
Install the functional hood louvrs that came on the 87 iroc 5.7 wilwood edition that will cool things down
Sent from T_Bittys Melon Farm
Old Apr 4, 2013 | 02:19 PM
  #83
95VQ30's Avatar
You can always go this route.
I'm sure it could look decent if installed correctly(maybe...), much better than scoops or that super aggressive CF hood.
Old Apr 4, 2013 | 02:29 PM
  #84
FastnFuriousMax's Avatar
It's not like we have serious heat issues in our engine bay. We are NA for the most part after all.
There is plenty of places to grab cool air from.
Don't understand why anyone would do this.
Old Apr 4, 2013 | 07:02 PM
  #85
Chris Gregg's Avatar
Get Off My Lawn
Yeah, without a under hood air temp grid, I have to agree. Otherwise it's just a shot in the dark in many respects.
Of course with several options discussed, those regarding modification of hood, vents/spacing/etc....I struggle with the possibility of my junk getting wet. Er, my engine/electronics getting drowned.
Old Apr 4, 2013 | 07:21 PM
  #86
cjandura's Avatar
Just whip out the 6" hole saw and have at it ffs and as far as getting your junk wet your too old for that and besides the hookas charge extra for junk wetting service.
Old Apr 4, 2013 | 07:32 PM
  #87
Get Off My Lawn
Old Apr 4, 2013 | 09:55 PM
  #88
TunerMaxima3000's Avatar
uhh i guess technically it does something that is not good if that is what you mean.
Educate me? You seem to be hinting at some awful thing that happens when you do this, please tell us
Old Apr 4, 2013 | 10:23 PM
  #89
Fakie J Farkerton's Avatar
Old Apr 5, 2013 | 05:28 AM
  #90
1) It's stupid
2) It's stupid
3) See 1 & 2
4)it stupid because you make it easier for thieves to cut your battery cable.
5) you don't drive a civic
6) http://www.importatlanta.com/forums/...-your-car.html
bad reasons to do it:
engine swap'd and needed for clearance
designed your turbo wrong
edit: The invader hood probably lowers temps on a maxima. Pulls the hot air right from the radiator. But even that might be a bad idea. Either way it doens't add HP and no one really tracks a maxima so the whole thing is moot. Just keep it stock and keep it shut.
Old Apr 6, 2013 | 10:05 AM
  #91
Blue Mesa's Avatar
Vents/scoops would look terrible on our cars IMO.
Ripping off the rubber seal would certainly help air flow but I'm with Chris Gregg in the whole not wanting everything to get wet.
An angled hood with no rubber sealing wouldn't work well in this situation...
The other thought I had was running cold water through the stock TB waterlines. Issue is youd need a pump and all the necessary plumbing. The other issue too is the effect would be (for the most part) localized to the TB, and unless you are pumping water out of a cooler full of ice water the effect wouldn't be much as I doubt the TB gets that hot (relative to ambient temp) anyway.
Old Apr 6, 2013 | 10:14 AM
  #92
CMax03's Avatar
1) It's stupid
2) It's stupid
3) See 1 & 2
The first frontend collision will be a instant decapitation!!!!
Old Apr 6, 2013 | 05:16 PM
  #93
Rods03Max619's Avatar
Old Apr 6, 2013 | 09:55 PM
  #94
Get Off My Lawn
1)
Old Apr 6, 2013 | 10:48 PM
  #95
Old Apr 6, 2013 | 11:45 PM
  #96
MaxFiyah's Avatar
not worth getting injured over a hood :/
Old Apr 7, 2013 | 07:10 PM
  #97
Thanks for posting that info dude great read!!!
Old Apr 7, 2013 | 07:29 PM
  #98
BlackThornDemon's Avatar
Just be like Roadkill on MotorTrend, run with the hood off.
Old Apr 8, 2013 | 10:03 PM
  #99
2kMaxim's Avatar
Our cars were designed to be elegant and a little sporty, with some sleeper ***** under the hood. No idea why people will go to all these crazy lengths to scrape out another 10-20hp (at very best) out of the car at the cost of making it possibly look funny.
Like i said before..get creative with some stealthy air ducting to feed your intake colder air.....and lose your bottom panels to create more fresh air turbulence under the hood before ever raising the hood up or doing something else extreme....
Old Apr 9, 2013 | 04:32 AM
  #100
tcb_02_max's Avatar
Don't do this. Besides increasing your fuel consumption, you will have many other unintended consequences (e.g. less effective flow through the radiator). 2kMaxim does not know what he is talking about. The engineers designed it that way for a reason.
Old Apr 9, 2013 | 04:59 AM
  #101
This. Someone obviously didn't read the link I posted.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
