Fog Light Adjustment
Old Jun 23, 2012 | 05:47 PM
Xpcgamer's Avatar
So I removed the stupid HID fogs and installed new Fog light housings and new 2700K Halogen bulbs. Damn things are aimed WAY too low. With the car 6 feet from the garage door the cut off is around 7's from the floor. There is a 12" gap from the fog light cut off to the low beam cut off. I want to raise the fogs beam up a hair. Is my only option to adjust with the fogs out then reinstall and check out the pattern. Repeat as necessary? Thats gonna suck. Has anybody tried trimming the space behind the fogs to get a clear shot of the adjustment screw?
Old Jun 23, 2012 | 05:56 PM
Xpcgamer's Avatar
So apparently section EL-80 of the manuel shows the adjustment screws are able to be reached from the back of the bumper. Mine are covered by a section of plastic. Maybe I have an aftermarket bumper cover and never realized it? Do you guys have it covered?
Old Jun 23, 2012 | 07:10 PM
Brudface's Avatar
I am pretty sure the way I aimed them was just whip them out of the bumper, I am pretty sure thats the only way to aim, unless you want to dremel out the plastic, but even then good luck getting anything in there to adjust it, its kinda tight back there.
Old Jun 23, 2012 | 07:51 PM
03VQMAX's Avatar
Papo, what I did on mine, take the fogs out, then drill a little hole where the adjuster screw sits on the bumper, then you can slide a 5/16 deep socket through and adjust them while tighten and mounted on the bumper....
Old Jun 23, 2012 | 08:04 PM
dfj240's Avatar
If for some reason you can't get the adjustment screw to work, use washers. There are two studs for mounting the fog light. You can just add a few washers to the bottom stud. It's a little ghetto, but it'll work.
-Nathan
Old Jun 23, 2012 | 08:51 PM
Chris Gregg's Avatar
Get Off My Lawn
I'm sur my front bumper is a replacement and there was not hole. Mine ended up being aimed properly, but I cut out the section blocking the adjustment screw.
BTW, read shiftice's page on aiming headlights and driving. As I recall, at 25 feet, the top of the beam should be 4" below the measured center of the driving light from the ground.
The driving light should be aimed low, suppose to illuminate the area right in front the car and to the sides of the road.
Old Jun 23, 2012 | 10:46 PM
luvlexus101's Avatar
Either aftermarket bumper or aftermarket fogs. Either will mess you up unless you drill a hole
Old Jun 23, 2012 | 11:04 PM
ColombianMax's Avatar
I was also wondering the same about adjusting since I recently bought myself some aftermarket fogs because the originals were beat to crap.. they're ok but I'm picky about light alignment. Gotta love this place!
Old Jun 24, 2012 | 06:18 AM
Xpcgamer's Avatar
Yeah. I guess the back on all the bumpers are covered. The SM says that you are to remove the lower cover and adjust thru the back. I removed my headlight to reach the fogs. Looks Like I will have to do that again and cut the back section of the bumper. BTW I got Depo OE style fogs. The look fine. Wondering how long they will last before they crack .
Old Jun 24, 2012 | 06:30 AM
cjandura's Avatar
wow anyone wanting new fog lights for their 03 courtesy has the foglight kit L/R lights w/Stalk and Relay for $176.00 vs. a single foglight for $143.00.how does this happen?i just ordered the kit sense i need a new bumper anyway and the one has a crack in it.
Home » Maxima Parts (A33B) 2000-2003 » Accessories » Exterior » B61E0-A33BFLKT
Nissan Fog Light Kit
2002 to 2003 Maxima
Quick Product Details
Manufacturer: Genuine Nissan Accessories
Category: Exterior
Product SKU: B61E0-A33BFLKT
Product Description
Integrated design to fit Nissan bumpers/valance panels for a factory installed look.
White lens add a wide-angle view to help increase road visibility under any operating conditions
Design of the lens is maximized for a close, low, wide angle which is proven most effective under foggy conditions
Replaceable halogen bulbs
Price & Availability
Your Price: $176.19
Usually leaves our warehouse in 2-4 business days
Simple Instructions
Old Jun 24, 2012 | 08:48 AM
Get Off My Lawn
You'll get a better price through Tri-city Nissan. Call them. Website: www.nissanpartsasap.com
Old Jun 24, 2012 | 09:28 AM
dfj240's Avatar
^Truth! I've been ordering from them recently while I'm away from my shop. Some of their parts are as cheap or cheaper than my wholesale discount gets me at the local dealership.
-Nathan
Old Jun 24, 2012 | 09:54 AM
djshwini's Avatar
http://www.amazon.com/Nissan-Maxima-...xima+fog+light
Both for around $80.00
Amazon also sells L and R separately for 43 each.
Old Jun 24, 2012 | 09:59 AM
Xpcgamer's Avatar
Same ones I got for 73 shipped off of Ebay. They are not OEM thou.
Old Jun 24, 2012 | 10:41 AM
Eirik's Avatar
Why'd you decide to kill the HID fogs?
Old Jun 24, 2012 | 11:20 AM
Xpcgamer's Avatar
Didn't really "light up" the road any better then the Halogens. Had to go thru the hassle of running dual relays on them. One of the relays got stuck and I woke up with one fog on. Not worth it. I took all that crap off. I did get to blind quite a few people with the glare when they where on thou!
Old Jun 28, 2012 | 04:03 AM
CMax03's Avatar
I did the same thing about 9 yrs ago...........
The Frye
Sep 2, 2021 11:03 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Maxima30
Sep 7, 2015 06:13 PM
