Engine cooling fans
Old Jul 2, 2012 | 09:19 PM
originalhandy's Avatar
Engine cooling fans
As i look at the car the left fan wont turn on.
I took off the relay for the fan and activated the relay manually (took it apart) and it kicked in. the circuit to the relay seems good, there is power to every pin except to one.
Should i just replace the relay or can there be another problem ?
Old Jul 3, 2012 | 04:59 AM
VQP0WER's Avatar
The second fan will only come on if the engine gets hot enough, or when the A/C is on and certain temperature settings are met. Are you having a overheating issue?
Old Jul 3, 2012 | 09:45 AM
OK cool that clears that up, I just havent seen one fan run on its own before I always thought it was both.
captchaos
Mar 15, 2016 12:18 PM
Smackasmith
Feb 1, 2016 12:40 AM
seesole
Sep 14, 2015 12:38 PM
asianstyle
Sep 10, 2015 11:30 AM
Wareagle92
Sep 3, 2015 07:18 PM
