P0300, p0303 & p0305
Old Nov 25, 2012 | 12:58 PM
shobuddy's Avatar
For the last month, I've been getting these codes (pending codes sometimes) intermittently. They usually show up for a day or less and then go away. Right before the light comes on, I feel a rough idle on startup but that goes away and the car runs fine. Right now no lights and car is running fine. I get the P0300 and P0303 more and the P0305 only showed up once. I've had the spark plugs changed about two months ago. Also had the cylinder 4 ignition coil changed when I was getting P0304 about a month and half ago and that took care of it. So my question is, should I change the ignition coils on the 3 and 5 cylinders? I'm hesitant because when the SES light does come on, it doesn't stay on very long and the car runs fine. Does the ignition coil slowly go bad which could be causing the on/off SES light or does it go bad at once?
Old Nov 25, 2012 | 01:23 PM
Huttig2009's Avatar
Same thing happened to me with the ignition coil SES light would go on and off till finally the coil gave out completely. Car would shake like crazy, till I got the new and put it in. After that it ran fine. So yeah ur ganna have to change those ignition coils out.
Old Nov 25, 2012 | 01:54 PM
shobuddy's Avatar
Thanks man. Ordered the coils and will have them put in when I get them.
Old Nov 25, 2012 | 02:46 PM
cjandura's Avatar
I hope you got OE coils or be ready for the 1320 code
Old Nov 25, 2012 | 02:49 PM
shobuddy's Avatar
Yeap, got OEM coils because I got lots of advice on these forums against anything but OEM. That said, when I replaced a coil in a front cylinder, I used an Advance Auto coil. Was not aware at the time that aftermarket coils can be troublesome. So far so good though and if it does go bad, I can replace it easily since its in the front. The rear ones I want to make sure are OEM.
Old Nov 25, 2012 | 07:19 PM
shobuddy's Avatar
Originally Posted by supra11
P0300 is multiple misfire, you may not need new coils. Check each coil first with engine running and disconnect each coil at a time, if theres no change in engine that means that coil(s) is bad
Thanks Supra. I'm going to have the mechanic doing the work so I may ask him to test. Hopefully he has a coil tester. If not coils, what else could it be?
Old Dec 6, 2012 | 05:35 PM
shobuddy's Avatar
How long did the light go on/off before it finally gave out? I've been SES free for a couple weeks now and engine is running smooth. I bought the coils online and am wondering whether I should return them.
Old Dec 6, 2012 | 06:50 PM
Huttig2009's Avatar
I would say a good month.
Old Dec 6, 2012 | 07:05 PM
MaxinO2's Avatar
I have a PO300 code as well with no others.. I've been fighting it for months now and still no solution.. Looks like I may just end up replacing all 6 coils since I don't know what else to do. My car is scarey to even drive its so bad. Good luck with the your codes, let us know how it goes.
Old Dec 7, 2012 | 06:55 AM
shobuddy's Avatar
And was it on and off like every day or every other day? Or did you have a week or two week period like I'm have where its running fine w/out any driving issues or SES light. Trying to understand the behavior.
Old Dec 7, 2012 | 06:56 AM
shobuddy's Avatar
How many miles do you have? Have you replaced the coils/spark plugs before? You also let us know how it goes.
Old Dec 7, 2012 | 07:23 AM
Huttig2009's Avatar
The SES would be on and off so it was like back and forth. Would run good then bad. I think the longest the light stayed off was for about a week and a half, but once it started shacking like crazy thats when i said ok its time for some new coils.
Old Jan 22, 2013 | 05:35 PM
shobuddy's Avatar
I'm getting the code below in conjunction with a P0303. I've already had the spark plugs replaced so I'll have the ignition coil replaced now. My question is, does the P0328 mean anything more serious or be looking at? Or is it tied to the P0303/ignition coil?
P0328: Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
Old Jan 23, 2013 | 05:24 AM
vkcooke90's Avatar
I know the p0300 is random/multiple misfire, but with the p030X have you tried moving the "affected coils" to other cylinders and see if the SES light switches to that cylinder?
Old Jan 23, 2013 | 06:25 AM
shobuddy's Avatar
I have not, only because I don't have the tools or the expertise to get to the three cylinders in the back. I have a mechanic I take it to but rather than have him charge me for any sort of diagnosis and testing, I usually tell him exactly what I want done, like in this case I think I'll get him to swap out the three rear coils but was just wondering if I should be looking at other things at well given the P0328 code.
kevinoseguera99
18
Aug 18, 2010 04:45 PM
Maximamisfire
21
Dec 31, 2009 09:00 AM
abakalen
18
Jun 7, 2008 01:51 PM
Ted_MEng
Mar 29, 2004 12:49 PM
