Drivetrain Project
Old Mar 25, 2013 | 09:04 AM
Chaka's Avatar
Zulu
Drivetrain Project
I was going to buy wheels/tires but i decided to invest in upgrading/repairing my drivetrain. Clutch slips and stinks when i change gears at High RPM. (5500RPM+). I am sure i will get the Fidanza/Exedy (stage1) combo. Anything else you would recommend replacing while doing this? and also deals? Got quote below from Prostreet.
Old Mar 25, 2013 | 09:43 AM
rebelhell's Avatar
5 qts of Redline? The 6spd only uses 2.5 how much does the 5spd take? You can also look at the JWT flywheel. It's the same as the Fidanza with a different label and can sometimes be found cheaper. Don't forget your throwout bearing. Might also be a good time to change those motor mounts out for some ES mounts.
Old May 8, 2013 | 11:22 AM
Chaka's Avatar
Zulu
the mechanic said that it would be a good idea to replace the seal. I am assuming that it would be this part?
http://www.courtesyparts.com/38342n-...-p-193914.html
Old May 8, 2013 | 01:25 PM
Gemner's Avatar
what seal is "the seal"?
Old May 9, 2013 | 06:24 PM
metalpiotr's Avatar
03 Maxima, 6spd
Don't remember exactly, but I recall my 4th gen's 5 spd (which I think is not much different than the one in a 5th gen) taking way more than the 6spd... so I think he's on the right track.
Old May 10, 2013 | 07:15 AM
Max_Gator's Avatar
I just did all of this - and upper oil pan leak fix.
The 5spd takes between 4 and 5 quarts.
The clutch should come with a new throwout bearing. It should also come with a new pilot bearing. Don't waste your time changing the pilot bearing - our cars don't use it.
Why only replace one axle seal? Do both.
Are your bearings bad? If not I wouldn't bother replacing them. You never know when you are going to create a problem. I had to replace my passenger side and it turned out that the Timken bearing I got was bad. Had to do it twice.
If you are still going to replace the bearings and pull off the knuckle, I would look at the lower control arms bushings and ball joints. You may want to replace those.
How old are the inner and outer tie rods? These can both be a pain in the *** to change but if they are old, this may be the time to do them.
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Excalibur23
Oct 13, 2015 04:33 PM
hot04
Sep 18, 2015 06:14 AM
thenewguyy
Sep 12, 2015 11:12 AM
