5th Gen: What did you do to your 5th Gen today?
Old Jul 23, 2014 | 09:51 PM
  #1001
blue_strip's Avatar
I changed out the bulbs for leds in my cluster today, that is an easy mod to do!
Old Jul 27, 2014 | 07:19 PM
  #1002
cornholio's Avatar
gave myself a key that can go on a keyring
put the rack on
couldn't decide if i wanted the fairing or not- was having trouble getting it to sit flat and got tired of messing with it. took it off, threw the bike rack up and this is how it will sit until i decide if the added noise truly bothers me
Old Jul 28, 2014 | 01:13 PM
  #1003
Garrettz459's Avatar
My babe is in my friend's shop garage getting brakes job done and $#&!!*$* Catalytic Converter replacement, and once she all fixed up I"m gonna lowered her some more!
Old Jul 28, 2014 | 07:38 PM
  #1004
Donkeypunch's Avatar
Did an at home alignment.
Turned out real good.
It's still acouple mm to the left but I'm going to tinker with it some more tomorrow.
Way better then how it was @ 10 o'clock.. Now it's at 11:58
Did it on the floor using this guy's suggestion.
https://www.youtube.com/watch?v=OzN0Z2HupcM
Got a new phone and tried out an effect just for fun
Old Jul 28, 2014 | 08:27 PM
  #1005
cornholio's Avatar
Originally Posted by Donkeypunch
dat tread
Old Jul 28, 2014 | 08:38 PM
  #1006
maximase86's Avatar
I love lamp.
Home made racing slicks FTW?
Old Jul 28, 2014 | 08:47 PM
  #1007
That's what a 300 shot of nawz does boys
....and bad toe settings.
Old Jul 30, 2014 | 08:57 PM
  #1008
stickybones's Avatar
p0102 and p1102....limped to autozone for those codes.
Anyway I got the new MAF and a filter while I was at it today. Installed and did the pedal dance to reset the ECU. I didnt disconnect the battery, oops. All seems to be fine now. Damn that MAF was expensive!
Old Jul 30, 2014 | 09:02 PM
  #1009
tosheto's Avatar
Changed the in cabin air filter.
Old Jul 31, 2014 | 08:29 AM
  #1010
ateick's Avatar
Replaced main cat with a gutted cat. Not very exciting but kind of a first step to replacing the precats.
Old Aug 3, 2014 | 08:04 AM
  #1011
Govols83's Avatar
Installed the BRM 3" exhaust and replaced my front valve cover gasket
Old Aug 3, 2014 | 08:39 AM
  #1012
th3shuck's Avatar
Installed led's in the car--total spent $14.00.
Installed speedometer led backlight--total spent $17.00.
Installed new ABS sensor.
And a wash/wax
Old Aug 5, 2014 | 07:18 AM
  #1013
Lilyjanay's Avatar
Did the fog light mod yesterday, turned out real good.
Fog light rewire
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-max-fog-2.jpg   5th Gen: What did you do to your 5th Gen today?-max-fog.jpg
Old Aug 5, 2014 | 01:05 PM
  #1014
02FrostWhite6spd's Avatar
I gutted the precat's
before gutted and off the car
5th Gen: What did you do to your 5th Gen today?-photo-2.jpg
Front precat before being gutted- look at that crap clogging it up
5th Gen: What did you do to your 5th Gen today?-photo-1.jpg
Front precat after being gutted
5th Gen: What did you do to your 5th Gen today?-photo-4.jpg
Rear precat before being gutted- metal type of material
5th Gen: What did you do to your 5th Gen today?-photo-5.jpg
Rear Precat Gutted- nice and hollow now
5th Gen: What did you do to your 5th Gen today?-rear-precat-gutted.jpg
I pressed in my ES motor mounts.
i changed My water pump and thermostat and my Timing Chain Tensioner all with Genuine Nissan Parts. <----- i jumped timing doing the water pump and had to take off the timing cover to set the timing marks correctly only to put it all back together and still have the timing off 1 tooth.
now i have to redo that crap again this week. Grrrrrrr
I went off topic a little bit, But the last of it is
replaced the Radiator with a $61 koyo from rockauto.
replaced both belts.
changed all spark plugs with NGK/Nissan Single tip Platinum Spark Plugs. i had a hookup and got them for $8 bucks each at Star Nissan rather then the $13 they had them listed for.
cleaned my throttle body replaced the PCV.
all work was done with the Engine still in the car btw.
Old Aug 5, 2014 | 05:03 PM
  #1015
The front cat was well clogged!
need to do mine here soon at almost 200,000 I bet they're clogged.
Old Aug 6, 2014 | 07:49 AM
  #1016
Itz Shak's Avatar
Hey are these strut braces any good? Reason I ask is because they're so cheap. I'm just getting the front done.
http://www.streetbeatcustoms.com/Meg...NM00FU/773616/
Old Aug 6, 2014 | 08:45 AM
  #1017
ateick's Avatar
I had one. They are cheap but fairly solid once set up. I had to remove it though once I put on my NWP spacers. It will rub on the IM and I never got around to grinding so it would fit.
Old Aug 6, 2014 | 09:18 AM
  #1018
Itz Shak's Avatar
Ahh okay, thanks mate. I'll go ahead and get these.
Old Aug 7, 2014 | 04:22 AM
  #1019
D.Stillwell's Avatar
Took a hard drive down some windy roads thru the woods few nights ago with a buddy, these roads were in bad shape with bumps all over the place.
Long story short, this drive was bumpy enough and fast enough to blow my radiator.
Opened hood next day (which was yesterday) to find a bunch of coolant spray. Ordered new radiator from 1800radiator and got it within a few hours, replaced, good to go now.
Old Aug 7, 2014 | 07:21 PM
  #1020
tosheto's Avatar
Changed the oil and oil filter. She seems happy!
Old Aug 7, 2014 | 08:39 PM
  #1021
george__'s Avatar
On the gen 5.5
- Changed wiper blades... Old ones were STUCK
- Ordered oil catch can for it
- Front lip getting repainted
- Front grill getting repainted
On the gen 4
- Took it to work
- Quick wash
Old Aug 8, 2014 | 06:41 AM
  #1022
Originally Posted by george__
On the gen 5.5
On the gen 4
- Took it to work
- Quick wash
Your 5.5gen is STILL running?
Old Aug 11, 2014 | 08:43 PM
  #1023
Max99ES's Avatar
Get my car washed and waxed over the weekend....
Put on new OEM wheels from 2014 Nissan Tiida turbo
Installed A33 Cefiro rear seat with headrests
The best part of the Cefiro rear seat is that it came with center cup holder and small storage compartment:
Old Aug 12, 2014 | 05:41 AM
  #1024
Chris Gregg's Avatar
Get Off My Lawn
Wow, like that rear seat!!
This past weekend I repainted my grill. Changed the shell from dark gray to silver in order to match the body color.
Old Aug 12, 2014 | 09:14 AM
  #1025
Lontar1's Avatar
Puerto Rico-Maxima Lover
Pressure washed the interior of the car.. got tired of spending money on products that wont clean fabric. Spent $6 and the interior and now it looks better than before.
Old Aug 12, 2014 | 09:32 PM
  #1026
zgrm100's Avatar
Originally Posted by Maverick4189
Hey, what color is your Maxima? Is this a stock paint color? Or did you re-paint it?
Old Aug 13, 2014 | 05:43 PM
  #1027
Fatboy98maxima's Avatar
That looks like charcoal gray color ^^^^^^^
Old Aug 13, 2014 | 06:04 PM
  #1028
Rcrootbeer's Avatar
It's grey lustre metallic
Old Aug 13, 2014 | 10:31 PM
  #1029
a33_ridah's Avatar
Today i plasti-dipped my recently bought (used) Racingline FSTB...and installed it on!
Front end seems a tad more planted on take off/bends.
I have way to many PENDING projects tho.
Old Aug 14, 2014 | 04:52 AM
  #1030
Used CarGuage Pro to adjust my idle RPM +100 to 800RPM instead of the stock 700. Feels much smoother that way at idle, and sounds so much better at idle and on decelerations.
CarGuage Pro is an awesome little app for what it's worth. Checked my timing with it, and it was on point at +2.
Anyone need timing advance? I'll do it free for any (no ricers) Max in my area. Doing it on a buddys 01 GLE today and then another 03 Max tomorrow.
Old Aug 16, 2014 | 01:23 AM
  #1031
Jprocs24's Avatar
I'm new.
I discovered what was making my car sound so good. I call it Natures Rumble.
5th Gen: What did you do to your 5th Gen today?-maxima-exhaust.jpg
I know this isn't the place but since it's my first post I'll fire some details out. '00 GLE, stock, in desperate need of some rims... Fuel economy is roughly 500 or less km's/ tank? It has been running regular all of its life, will be trying premium soon!
5th Gen: What did you do to your 5th Gen today?-maxima-gle.jpg
Old Aug 17, 2014 | 05:24 PM
  #1032
I assumed power line was leaking.
But it was bone dry. So moved on to doing arm.
Bushing was trashed. It pulled to the right when I gave it some gas.
I may have over tq the ball joint since pin isn't even close to the nut.
Need another alignment. New bushing put my wheel at 1:00 !
Feels good though steering is solid now.
Old Aug 22, 2014 | 01:16 PM
  #1033
DOODOOCHIP's Avatar
Failed the emissions test evap codes
Old Aug 22, 2014 | 09:10 PM
  #1034
King_Ten_Ahead's Avatar
Hit a curb hard. Ran off tge road around a curve:/
Old Aug 23, 2014 | 07:13 PM
  #1035
BigLou55's Avatar
New passenger CV axle and axle seal
Old Aug 25, 2014 | 08:47 PM
  #1036
a33_ridah's Avatar
Drilled 4 inch Holes on Filter housing instead of using hangers to to GAB mob. Filed edged as smooth as possible (mehh). Enjoyed a nice run and felt the VQ wake up. Best FREE mod in my opinion.
Sitting to the side is all components i need for a sri minus the "right" maf adapter (one i have isnt gonna work)..that will be phase 2 of intake mods.
It what im going to do in a few days im most excited about--NWP block off plate install
Old Aug 26, 2014 | 01:10 AM
  #1037
AT978's Avatar
Wrapped my dash in carbon fiber vinyl that I got off of eBay for way cheap, sorry for the poor quality photo but you get the idea Name:  IMAG2505_zpsmy5sgrik.jpg
Old Aug 26, 2014 | 08:15 AM
  #1038
DjSinikal's Avatar
Detailed my engine bay. I bought it a few days ago and it was in need of a good cleaning. Not bad for 15 minutes of work.
Before:
After:
Old Aug 26, 2014 | 10:42 AM
  #1039
DennisMik's Avatar
Nice Job! wanna do mine now?
Old Aug 26, 2014 | 11:30 AM
  #1040
Lilyjanay's Avatar
Before:
After:
That looks awesome!!! how did you clean it?
