Rubbery acceleration even with new mounts.
Old Jul 9, 2016 | 08:36 AM
MadMax SE's Avatar
So I have been having a small issue with my drivetrain feeling a bit wobbly the past few months. When accelerating or deaccelerating the car will kinda bounce back and fourth while in the first 3 gears and reverse, the last 2 gears aren't so bad. (5spd). I suspected the subframe and crossmember were the cause so I used the washer trick to tie them solid and it got rid of almost all of the banging that would happening while using the clutch. My engine and tranny mounts are all new but of a lesser brand and advertised for the A/T model (I couldn't use the driver side mount due to this so I bought a new trans mount) Is is possible the A/T mounts use a different hardness then the manual ones or my control arms need changing? What do lca's feel like when they are failing?
Old Jul 9, 2016 | 10:21 AM
losifanatic's Avatar
The a/t mounts are electronic. They won't work with the manual car. They won't get the signal to harden up
Old Jul 9, 2016 | 12:15 PM
MadMax SE's Avatar
I should have mentioned, the kit I bought had all non electric mounts. None had wires.
Old Jul 9, 2016 | 06:49 PM
maxiiiboy's Avatar
Well, your experience shows that the kit does not work very well.
Old Jul 9, 2016 | 07:47 PM
MadMax SE's Avatar
Im still trying to figure out if it's even the mounts giving me the issue. When perfectly rev matching there isn't a single wobble at all. I don't know what a failing lca feels like either. I can hear slight thud under the passenger side wheel well when the rubbery feeling occurs.
Old Jul 9, 2016 | 08:38 PM
cornholio's Avatar
To clarify, which mounts did you replace? All 4, or just the passenger side and Trans mounts?
Old Jul 9, 2016 | 08:50 PM
maxiiiboy's Avatar
My bet is, it's your mounts.
How do I know? I have an AT Maxima; I disconnected my mounts about a year ago to avoid the well-known ECU damage. Ever since then, I have the (not so) occasional in-line vibration, weak or strong, depending how I step on the gas, when I step on the gas, ... .
Since your car is a Manual, I would strongly suggest installing MT mounts. Why did you even think about AT mounts ?? Makes no sense to me.
Old Jul 9, 2016 | 09:09 PM
cornholio's Avatar
I agree it is strange, only because most MT sets are priced cheaper than the AT
For that reason (and potential ecu damage) most of us do it the other way around, replace our At mounts with the Mt ones
Old Jul 9, 2016 | 10:30 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Fill with urethane and call it a day.
Old Jul 10, 2016 | 03:27 AM
MadMax SE's Avatar
I had replaced all four mounts and the only reason I resorted to these specific mounts was because it was 80 bucks for the front rear and passenger mounts and needed to be on the road asap on a budget. I'm going to fill the mounts to see if it does . The front and rear mounts look exactly like M/T mounts because they are wireless, just rubber and metal. I didn't know it was for an auto until I had recieved the parts and saw the odd looking trans mount there.
Old Jul 10, 2016 | 07:48 AM
cornholio's Avatar
Is the radiator support in good shape? Not cracked or rusted through?
Old Jul 10, 2016 | 07:52 AM
MadMax SE's Avatar
It's brand new and painted. The bushings that were used for the two lower bolts were replaced with thick steel washers
Old Jul 10, 2016 | 09:24 AM
HerBlue2kSE's Avatar
Since you have the AT mounts in place, let me offer this option to you:
https://www.amazon.com/Energy-Suspen...rgy+suspension
Just swapped my AT 2000 over to these after picking up the cheapest MT mounts on Rockauto.
Old Jul 10, 2016 | 06:30 PM
I have those in mine. Took 99% of my wheel hop away
Old Jul 11, 2016 | 04:23 AM
BronxSleeperMax187's Avatar
Shocks ever been done? Mounts and Shocks caused most of my wobbles etc..
Old Jul 16, 2016 | 12:31 PM
MadMax SE's Avatar
Ordering poly engine inserts this Friday along with the poly lca bushings to get rid of this dreaded looseness.
Speaking of looseness those steering Colum bushings get hella loose! I thought i had terrible torque steer, but what I have almost 3" of play turning the steering wheel while the car is off before the wheels budge, needless to say I contacted a vendor and he still carries the hardened steering colum bushing so I'll be grabbing that too for 30 shipped
carlosvq30
20
Mar 5, 2016 02:27 AM
tmorales509
Feb 29, 2016 05:08 PM
sebastian2041
Feb 28, 2016 08:36 PM
maxima703
Feb 14, 2016 08:58 AM
