New engine in rought start t
Old Aug 4, 2016 | 07:27 PM
sebastian2041's Avatar
New engine is in but starting is giving trouble, hard crank and turn over but not start? Any ideas? Crank sensor? Grounds?
Old Aug 4, 2016 | 07:55 PM
DennisMik's Avatar
Is the cranking speed normal or is it slow?
Old Aug 4, 2016 | 07:59 PM
nestorlugo's Avatar
Got gas?
Old Aug 4, 2016 | 09:06 PM
Originally Posted by nestorlugo
Got gas?
Yes haha i read someone forgot they had none
Its cranks normal, we thought it was crank sensor but we bought one and acted the same.
Old Aug 4, 2016 | 09:19 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Got gas?
Old Aug 5, 2016 | 02:48 PM
https://youtu.be/RSwnFtYmlcs
Video of the problem
Old Aug 5, 2016 | 03:28 PM
DennisMik's Avatar
It sounds like the engine is starting to me. However, it does not sound like it is running on all 6 cylinders.
In the video, did you turn the engine off or did it die by itself?
Old Aug 5, 2016 | 04:29 PM
Brudface's Avatar
Jesus that is NOT running on all 6 cylinders. Did you change plugs before installing new engine? Did you use the old coils that were on the engine? This one is stupid but did you remember to connect the rear mini harness for Bank 1?
Old Aug 6, 2016 | 08:35 PM
Well guys the problem was the crank not the engine because when it stared (rarely) it worked flawlessly. I found the problem tho. We installed the flywheel wrong sonthe crank timing was off. The automatic engine doesnt have a pin coming out so we didnt notice there was a right way to i stall the flywheel car is running great now! Thanks for all you input tho!
Old Aug 7, 2016 | 07:17 AM
Scottwax's Avatar
That's Mr. Detail to you
Glad you got it sorted out! Little things like that can be a huge pain. Did a 455 swap into a '77 Cutlass I used to have. Got it in, all hooked up, turned the key. Nothing. Not a damn thing. I was an assistant manager with Jack in the Box at the time and since it was already 8 pm (we pulled the 455 from a Delta 88 I'd bought and the 350 out of the Cutlass and did the swap in one day) and I was working graveyard I had to clean up and get into work on almost no sleep.
Get home in the morning, poking around under the car and I saw a single wire hanging down-forgotten to hook it up to the starter solenoid. Connected it, car started up immediately. One stupid wire.
Old Aug 8, 2016 | 05:43 PM
i just can't believe we forgot about it! anyways now im a pro at taking transmission out of the maxima
Old Aug 9, 2016 | 08:35 PM
Blassmasta's Avatar
Do you remember how far out of position you were (# of holes on crank flange)?
I figure you must have been off by 2 or more for it to run like that.
And what exactly do you line up the flywheel with on the automatic engine's crankshaft? I thought they all had a dowel pin (auto and manual).
Finally,
If you used a factory Dual Mass Flywheel, what does the alignment hole look like on the crankshaft side of the flywheel? (assuming you put this engine in a six speed car).
Looking for answers to some problems of my own.
Old Aug 10, 2016 | 11:25 AM
Finally,
Thats not the car running but trying to crank im holding the key trying to make it start... and we didnt check the position we had it because we were in a hurry. Both engines do have a dowel pin just the manual one sticks out and the automatic doesnt so you line up the flywhee where the dowel pin would be which you know because its the only hole on the flywheel that different. The crankshaft side has an automatic pilot bearing so you have to take it out if youw want to be able to use the clutch alignment tool... if you take it out though you will need a manual pilot bearing.
Old Aug 10, 2016 | 12:20 PM
Blassmasta's Avatar
Gotcha.
I was actually asking about the back side of the flywheel itself. What does the hole look like that lines up with the dowel? I know on the LUK aftermarket ones it has an insert with an elongated hole.
Do you know what it looks like on the OEM Flywheel?
Old Aug 11, 2016 | 12:22 PM
Gotcha.
I have a luk flywheel so I actually dont know sorry
Brawi_Brbal
Apr 22, 2016 06:24 AM
2damax
Apr 11, 2016 04:28 PM
Knotz428
Mar 13, 2016 07:44 AM
Max I am
Mar 9, 2016 03:12 AM
Oct 10, 2000 07:28 PM
