Front Strut Question 02 Maxima
Old Mar 16, 2018 | 05:42 PM
fastcarny's Avatar
Hello all I noticed my front Strut to Knuckle bolts were loose i was hearing a chatter at times when pulling into the driveway--The tires are wearing perfect and i have no drift or pulling--I tightened each both up while froint of car was jacked up--Drove car after that--No more noise and no pull or drift.. Is there an Alignment adjustment where the strut mounts to knuckle didnt see any cams or anything.. All i did was simply tighten the bolts! Thanks..
Old Mar 16, 2018 | 06:20 PM
03VQMAX's Avatar
Actually does make a difference, you can push and pull the knuckle, then tighten bolts. Pushing in with throw steering wheel off, pulling spindle out then tightening works best.
Old Mar 17, 2018 | 07:05 AM
fastcarny's Avatar
Thank you!
Old Mar 17, 2018 | 09:13 PM
ajahearn's Avatar
Slight pull as well
I had one half axle replaced and I always felt a slight pull on that side. Nothing signiifcant but definitely a feel. Probably due to a small difference in length.
Old Mar 18, 2018 | 07:14 PM
CMax03's Avatar
There's not enough play in the strut bolt bores to make a difference unless someone enlarged the strut bolt bores
streetuner
22
Apr 18, 2010 08:34 AM
HDB Audio
Aug 13, 2009 06:13 PM
maximumpower96
51
Apr 8, 2008 06:46 PM
Street Reeper
May 28, 2004 11:23 AM
