Power windows dont work
Old Mar 21, 2018 | 10:00 PM
Peter Sabourin's Avatar
power windows dont work
Old Mar 21, 2018 | 10:07 PM
Whostheboog's Avatar
What year?
Old Mar 21, 2018 | 10:17 PM
Check these 2 fuses, check this relay, if you don't know how, don't have a relay to replace it make a jumper wire like this, and jump the white red wire to the whit blue wire only those 2 just like in the picture. Leave the top 2 should be purple and black alone. Your windows should work now. Know this that jumper is perfectly safe and won't cause you any harm. However as long as the batter is connected the windows will go up and down any time any switch is pressed. It won't drain the battery and will be fine until you get a relay. Just know that those switches work if the car is off, locked, and alarmed even. If the jumper doesn't work you're either out the 40amp fuse able link under the hood(not likely) or the master switch is bad (drivers door switches actually controls all other door window switches) (most likely if jumper doesn't work) . If only one e window doesn't work it's that switch (also not likely) (you didn't give me much info so I gave you all I could)
Old Mar 21, 2018 | 10:18 PM
Forgot to add the pics I do that all the time.
Attached Thumbnails Power windows dont work-screenshot_20180322-011010.png   Power windows dont work-screenshot_20180322-010901.png   Power windows dont work-screenshot_20180322-010854.png
Old Mar 22, 2018 | 06:51 AM
Derrick2k2SE's Avatar
Does the power seat work?
Old Mar 24, 2018 | 08:07 PM
ajahearn's Avatar
Another item to consider, on my Nissan mini-van one of the electrical door switches was stuck in the down position which prevented the window from going up. The master door switch could cause all windows to fail going up.
Starrider
Jul 6, 2017 06:43 AM
LaCross
35
Apr 8, 2014 11:01 PM
playtoy
Jul 2, 2009 05:35 AM
supertool
Jan 13, 2001 08:50 PM
