Auto Trans Fluid
Old Apr 14, 2018 | 05:21 PM
fastcarny's Avatar
Auto Trans Fluid
Hello all doing a drain and refill ( I do this every couple of years) however i forgot which trans fluid to use? Was it 5 or 4 quarts that drain out of the trans oil drain plug? 2002 Maxima AT Thanks...
Old Apr 14, 2018 | 05:28 PM
03VQMAX's Avatar
Matic D, part number 999MP-AA100p, my drain and refill is about 3 quarts or so
Old Apr 14, 2018 | 05:56 PM
fastcarny's Avatar
Thank you!
Old Apr 14, 2018 | 05:57 PM
nestorlugo's Avatar
You can drain more if you remove the return line and drain into a bucket
Old Apr 14, 2018 | 06:28 PM
MichMaxFan's Avatar
I use castrol import atf for probably 80-100,000 miles. Its been good to me. I drain and fill every 7000 miles because not all of it comes out. Only 50%. About 4qts.
Just my $.02
Old Apr 14, 2018 | 07:52 PM
fastcarny's Avatar
What i did see is a Global Multi Vehicle automatic transmission fluid One fluid to meet all car requirements--what i dont get is i guess ATF is all teh same except what they add to it?
Old Apr 15, 2018 | 05:06 AM
MadMax SE's Avatar
I wouldnt reccamend a "global fluid" for the fact that most trans have a certain additive group they need (chevy uses dex and toyota,nissan uses *import fluids* and ford uses mercon). a global fluid could work for someone who doesnt beat the trans but why sacrifice reliability for a cheaper product, trans cost alot more than propper fluids.
maxima94ever
Nov 8, 2011 04:44 PM
RI-Max
Sep 19, 2002 05:29 PM
njmaxseltd
Jul 27, 2001 11:41 AM
dakota
Nov 24, 2000 03:38 PM
