Need Help with P0335 and P0725 code
Old Oct 22, 2018 | 07:15 PM
Kevin Ventura's Avatar
This is my first post here on the forums and was hoping someone could help me. I have a 2002 maxima se 3.5 L (automatic) with the P0335 code and P0725 pending code. I believe that the P0725 is due to the P0335 because it is the crankshaft position sensor. The rpm isn’t working and it has a long crank. If I was to drive the vehicle for a long period of time the vehicle might stall and shut off on me. I’ve changed the crankshaft position sensor with the oem one but still no change and still have the SES. I am aware of the recall but I called Nissan they had told me that the vehicle was already been serviced by the previous owner. I really don’t want to bring it in to the stealership but if anyone has any idea on how to fix this problem it would be greatly appreciated. Also how many crankshaft position are they on the 2002 maxima model. I’ve looked everywhere for the information but could not find it anywhere. The one I’ve replaced was the one by the oil pan underneath the splash shield.
Old Oct 23, 2018 | 04:36 AM
Prophecy99's Avatar
fix all three, they do not allways throw codes if any, be glad you had one code, and make sure you replace OEM or u will be back to square one in 12 months.
if you do not replace all 3 sensors, u will waste your time.
Old Oct 23, 2018 | 04:49 AM
so there 3 crankshaft sensors? Where are they located on the vehicle? I have already changed the camshaft sensor bank 1 & 2. But I picked up those sensors at advanced auto shop you might be right about those going out in a few months. They were the first sensors to go bad 2 weeks before the crankshaft did and went away after changing them to after market. I have changed everything on that list of codes.
Nmaxima27
Jul 29, 2014 06:59 PM
homeboy
Jun 20, 2014 10:58 AM
Coupedncal
Sep 8, 2012 10:07 AM
mishaguy
Mar 27, 2004 03:23 PM
NinerRR
Aug 1, 2003 10:08 AM
