Help asap please! How do I get my auto tranny mount off??
Old 04-13-2019, 02:35 PM
Devin Hand's Avatar
I've been trying for hours but I can't figure it out, doesn't seem to be any decent guides or videos, thanks!
Devin Hand is offline
Old 04-13-2019, 03:19 PM
Maxima 97 SE's Avatar
Jack the transmission pan up. That's the only way to get that mount off. It needs to be lifted to get that long screw out. When jacking the transmission use wood so you don't damage anything.
Maxima 97 SE is offline
Old 04-13-2019, 03:21 PM
Devin Hand's Avatar
I have, I can't seem to figure out how to get that main bolt out, did the passengers side earlier with little issues.
Old 04-13-2019, 03:22 PM
Devin Hand's Avatar
It's definitely different than the other side
Old 04-13-2019, 05:27 PM
Devin Hand's Avatar
Couldn't get it out today, would love any help I could get thanks!
Old 04-14-2019, 01:30 AM
Father of the 00 VI
krismax's Avatar
Is there a nut on the other side? Some times it spins.
krismax is offline
Old 04-14-2019, 07:25 AM
Slamrod's Avatar
this x10000. the long bolt running through the mount is held by a nut on the other side that is not welded to the mount. If you dont hold that nut still you will just spin it with the bolt endlessly without making anything looser. Took me an embarressing amount of time to figure that out myself lol.
Slamrod is offline
Old 04-14-2019, 08:14 AM
Devin Hand's Avatar
Is it supposed to be a square nut? Because that seems to be the case, and then I don't know how to actually get to the other side where the bolt is. Thanks!
To follow up here is the nut side, looks welded on doesn't it? and if not I do I hold it down, what socket?
Old 04-14-2019, 12:44 PM
Father of the 00 VI
krismax's Avatar
If it's just spinning the bolt. Put some pressure on the bolt.Or try hitting it with something. The threads may be ruined.
If that doesn't work,cut it with a sawzall blade.
krismax is offline
Old 04-16-2019, 03:34 PM
Devin Hand's Avatar
Got it off and then found out the new mount was to thin in the bracket area making the bolt protrude lol oh well, put old one back on for now, any one have idea what size bolt I'd need to use on those four for the new mount? Also here's the huge bolt you have to get out in case anyone else is confused out there.
Old 04-16-2019, 10:08 PM
User1's Avatar
Raise the mount with washers between the mount and the tranny.
User1 is offline
Old 04-17-2019, 05:10 PM
Devin Hand's Avatar
Could I get new bolts instead? Slightly shorter bolts seem easier than trying to get washers down there haha, of so what size?
Old 04-17-2019, 07:02 PM
User1's Avatar
Sure
User1 is offline
Old 04-18-2019, 04:55 PM
Devin Hand's Avatar
Sure
Any idea what size? Or is it in the manual somewhere? Thanks! Here's a pic of the bolt if it helps.
Old 04-18-2019, 07:03 PM
User1's Avatar
I don't know man. Match it up with one of the old ones. Or grind that guide off at the tip of the old one.
User1 is offline
Old 04-19-2019, 01:46 PM
tundrawolf89's Avatar
They're size 12 diameter. I think thread pitch is 1.5 I can't remember to be certain. Goto harbor freight and get a digital calliper or bring the bolt to a hardware store. Replacements are cheap. If you goto a local hardware store get grade 10 or higher. Next time, beat it out with a hammer/chilsel.
That trans Mount might be a real pain to find a replacement for. As I'm fairly certain they're discontinued now. At least the bracket part is. Pretty sure there shouldn't be a nut threaded onto trans Mount other than the welded square one.
2 nuts don't make a right
Do what I did, get some 3M roof flashing polyurethane, clean the old mount with brake clean, then shoot the poly into it, give it a couple days to dry. And you'll not have to worry about it a longggg time .
I ordered new hardware from Nissan dealership online. Somehow managed to get a wholesale account, so nuts sand bolts cost alil more than hardware store, but usually from Japan. Some new hardware is USA made.
tundrawolf89 is offline
Old 04-20-2019, 04:00 AM
Father of the 00 VI
krismax's Avatar
[QUOTE=Devin Hand;9200164]Any idea what size? Or is it in the manual somewhere? Thanks! Here's a pic of the bolt if it helps.
I am not sure what your asking ...do you need replacement bolts or the size?
Because i have the bolts in my garage.
I can get the exact size for you,but not till Sunday, Monday.
krismax is offline
Old 04-20-2019, 04:26 PM
User1's Avatar
[quote=krismax;9200226]
It's a bolt, he'll figure it out. Lots of options, just gotta think it through.
User1 is offline
AustinTylerDean
04-14-2014 02:56 AM
thealliance43
03-30-2010 05:26 PM
t6378tp
19
03-17-2008 03:01 PM
toddyfresh
04-04-2007 11:20 AM
Quick Reply: Help asap please! How do I get my auto tranny mount off??
