AC recharge or something else?
Old Jul 22, 2019 | 07:45 PM
Shawn33's Avatar
Every since I have owned this vehicle, the AC has been mildly strong during extreme temperatures.. It takes pushing the accelerator to get some really cold air going. During a 20 mile drive in the heat, it works just fine as normal. But I notice (when the car is very hot) That the AC isn't as strong.. When I start it at night it gets cold fairly quick with out a need to accelerate. Could it just need a recharge? Furthermore, this wouldn't indicate a leak since it has worked this exact way for years would it?
Old Jul 22, 2019 | 08:02 PM
DennisMik's Avatar
Are both of the radiator fans running?
Old Jul 22, 2019 | 09:25 PM
krismax's Avatar
Father of the 00 VI
Yes as Dennis said...check the fans both should run with AC on.
Recently with my 00 i30 ,when the car would sit,the temps would rise. And not only that the car would start to get warm, All because ,ones of the fans wasn't working.
It was the one right in front of the engine.
Changed the motors with two aftermarket ones,they work great so far.
Old Jul 24, 2019 | 03:21 PM
Shawn33's Avatar
Yes
Old Jul 24, 2019 | 03:23 PM
Shawn33's Avatar
Yes they are working, even when I get on the freeway when its really hot, it blows air but not cold. This seems to only be a problem when its extremely hot.
Old Jul 25, 2019 | 08:40 AM
ukmastermind's Avatar
After replacing my cooling fans, in addition to other things, the AC is noticeably cooler in my car.
I suspected the fans were old and just not pulling enough air
Old Jul 25, 2019 | 09:02 AM
MadMax07SL's Avatar
Different car, but about a year ago the compressor was replaced. seemed to cure the problem, then the following summer hit, same kind of thing you are experiencing, it was cool if the car was cool, but things got hot, it couldn't keep up. Was a bad expansion valve that was causing the problems. Wasn't leaking, was just not working correctly so it wasn't getting refrigerant into the evaporator correctly
Old Jul 25, 2019 | 03:19 PM
DennisMik's Avatar
It is possible for the fan motors to be running, but running slow as MadMax07SL said. When the car is not running, take hold of the tip of the fan blade and wiggle it front to rear. There should be no wiggle. Then try to rotate the fan. There will be a little resistance but not very much.
When the fans are on, are they very noisy? There will be some noise but not much more than when they are off. If any of these things are true, then you have a bad fan.
And check BOTH of the fan motors.
Old Jul 25, 2019 | 05:22 PM
Shawn33's Avatar
I see.. I noticed today that this problem is intermediate. It's hotter than it was when I didn't feel cold air, but it worked perfectly normal.. I'm guessing it just needed to adjust since summer just kicked in.
My2010FoUrDsC
Oct 8, 2012 11:40 AM
Ignatius Reilly
May 30, 2012 03:03 PM
NYghettoGLE
Jun 13, 2008 09:43 PM
teeezmaxSE
Jul 21, 2006 06:58 AM
_DRU_
25
Jun 3, 2001 02:02 AM
