01 Headers Install
01 Headers Install
So Ive gotten a bunch of tips on what I should do for my car, and it seems to be headers and y pipe. My concern is actually doing it. No one has ever seemed to post anything about this job on the VQ30DEk. So im here to ask if anyone knows or has a write up on this job. Im thinking there can be access by taking the intake manifold and the cross member out and that will be easiest. Still not sure if ill get all of the bolts out lol. At 193k miles I still worry if this is a good idea. Everyone Ive talked to in my area wants to see an HR swap, but if this seems easier by most maybe I should do it.
Its the same exact process from 95'-03'. You will 100% need to take the intake manifold and crossmember out to make more room. Using a jack to lightly tilt the motor helps a lot as well. How attached are you to your car? If you are looking to make power gains you are better off with a VQ35, just that switch alone will net you more power than headers + Y pipe ever will on your VQ30.If you just want a very simple and effective mod though just do the y-pipe, its easy and cheap.
I've done plenty and having the crossmember removed makes it much easier! Spray the exhaust manifold heatshield bolts and the exhaust manifold nuts down with plenty of PB Blaster it will be your savior!
If you don't have emission issues in your state, I highly suggest you consider Forced Induction instead of a motor swap. It will come out nearly the same as an engine swap $$ wise in the end but you'll have way more HP. If you can find a used supercharger kit for your 01, it's a direct bolt on and 49 State street legal (not legal in CA). Motor swaps are overrated in my opinion. Go FI or forgettaboutit.
Have fun with supporting mods alone for boost being cheaper than the total swap. Rigging a boost setup together is a sure fire way to make sure the engine doesn't last.
If you mean paying someone to do it...then yeah, but that's pretty irrelevant with a car that's worth 1,500.
*signal inverters are 130 shipped, couple bolts/washers/barb fittings and TB pigtail (junkyard or china) if you need it, so let's say 50 max
*fluids should be about 100 = 830
That leaves you some change for miscellaneous stuff for assembly. Alternator bracket is made from any ol piece of scrap metal laying around.
Did I miss anything?
Maintenance items are on you (clutch, PS hose, etc). A direct swap is cheap. If you're thinking boost and you won't need maintenance/upgrade items....
Maybe im just stupid (ok probably) but why would anyone use 3.0 timing on an HR swap? Why not just swap to a 3.5 ECU and harness?
On second thought, maybe wizard knows best afterall. Forced induction would net more way more power for the same if not less money than having to swap the motor, wiring, ecu, trans, etc... I couldnt see 3.0 timing on an HR swap being worth doing either when you can just straight up buy a 5.5gen and get basically the same result with zero effort required.
There's not many long term success stories with FI on here for a reason. Knowledge and money are a huge limiting factor. IF you can get a complete PnP S/C kit for cheap that's not worn out, sure, go for it.
NO ONE with a rwd claims it's cheap to mod VQs....and they have infinitely better support. Emanages are junk, Utecs are getting rare (but I guess you can find one), and I haven't kept up, but I don't think anyone is reflashing 3.0s, yet.
You know what a low use, complete (minus fuel/tuning solution), vortech kit cost me for RWD? 3,200.
As far as I can tell most people are DDing these things, too. Once you do the swap, you can drive until the tranny ****s out or needs a clutch. FI isn't going to be so simple.
I dont have an apples to apples comparison for this and my old swap just yet, current swap needs an intake and exhaust to be comparable to my old numbers.
I do plan to dyno my current setup, but haven't decided when.
I consider the Gen II engine to be a DE with headwork and without oil burning (among other minor improvements over the Gen I DE).
Variable cam timing or not, the airflow improvements are still there.
That's what I am currently running on my 4th gen 6mt. Altima headers and everything else (power wise) is stock. As it sits right now I ran 14.3@99 @ 3020 race weight.
That's like asking why do any swap on 3.0 timing, that dead horse has been beaten over and over again.
I could log mine if anyone is interested in replicating it. No knock on 93 in summer heat.
Korn, define summer heat.
I've tuned both my old 3.0 and 3.5 setups - there are always healthy gains to be made on these cars!
Id argue that my engine is begging for more air just as much, if not more than a tune. Thinking about it, I have an OEM intake and catback installed that were designed for an engine producing 100hp less (from the factory) than the one in there now.
vq_ryder
May 4, 2010 07:59 PM
evil_spork
Jul 15, 2006 10:05 AM
mdloops
Feb 13, 2004 11:15 PM
