Rear Window Tint...
Old Oct 4, 2019 | 01:20 PM
ukmastermind's Avatar
Rear Window Tint...
I just noticed the rear window on the i35 has a lot of lines/ dot matrix near the top.
Are there any potential issues with tinting this area ?
Tint: Xpel Prime XR Ceramic Black
Old Oct 4, 2019 | 03:41 PM
JaVq35hr's Avatar
I don't believe there would be an issue. To my knowledge those lines are for the rear defroster as well as the antenna for fm radio
Old Oct 5, 2019 | 02:51 AM
Theslaking's Avatar
Zero issues. Ceramic really can hurt cell/gps signals though. Just a rear window won't be an issue.
Old Oct 5, 2019 | 08:56 PM
They're above the defrost lines, so maybe antenna I'm guessing? Thanks for the input.
Old Oct 5, 2019 | 11:50 PM
User1's Avatar
I have a dilemma regarding the dots and lines and tint:
REMOVING THE OLD ADHESIVE!
I am serious! One of the first things I did when I bought my car was strip the old tint. The only reason I have yet to re-tint the vehicle is that I cannot, for the life of me, after using multiple attacks, remove the old adhesive from the back glass. The film itself lifted and was removed by steam, however the majority of the adhesive remained. I am at a complete loss here and have been since I pulled the tint. I have even considered keeping my eyes open for a non-tinted back glass from a yard but man, what a PITA to have to replace glass just because of a chemical adhesive! An option also would be to just razor-blade the entire window, as I will never need the antenna and this car will probably never leave Florida where I will never use the defroster.
I didn't think this thread would go much further, but it is established and has had some views. Was hoping someone would chime in with their adhesive removal success story! I really want tint on this car! I have a carbon-ceramic film and shop all lined up to do it ($600 total) but can't schedule the job until I figure this out!
Old Oct 6, 2019 | 06:42 AM
Theslaking's Avatar
Goof off or 3m adhesive remover. New glass.
Old Oct 6, 2019 | 04:27 PM
Paint Thinner has worked magic on some of the stickiest sticky's.
Old Oct 6, 2019 | 04:33 PM
fd3rew's Avatar
The same soapy water that you use to tint the window is what will remove the adhesive glue thats left after peeling off the color layer of tint. Soapy water will soften the glue, and a white or pink scotch pad from the supermarket....I forgot which one but it is the lightest duty one. Spray the window with the dish washing detergent mixture and then gently scrub the lines using the white scotch pad in the direction of the defroster line. you can always test in a area without the lines first or test it on the ends of an antenna line. This is after scraping of as much of the glue as possible using a razor blade in the areas without lines using soapy water
Old Oct 8, 2019 | 02:00 PM
User1's Avatar
Thanks for the tips, guys! I tried lacquer thinner with no result. I bought goo gone but not goof off. I've used that stuff before so I'll give it a try. Had no idea dish soap suds would help. I'll give that a shot too. The adhesive is almost a complete sheet covering the entire glass. Man, I really don't want to pull this thing. I'll razor blade the whole thing, lines, dots and all before I do that. I fear impending leakage with replaced glass. I might consider replacement after my subwoofer has had a couple months to take apart my car. We'll see how bad it gets.
Old Oct 8, 2019 | 06:02 PM
fd3rew's Avatar
The dish soap mix will soften the adhesive and basically provide a lubricant for the razor to lift off all glue on the clear glass and dots area. Think of it as shaving cream for your razor. When you have most of it off, you can hit the defroster lines with dish soap water and gently run the white/pink supermarket scotch pad along the lines. Practice on the ends of the antenna lines so you know how hard you can scrub with out screwing anything up.
Old Oct 8, 2019 | 07:02 PM
User1's Avatar
Interesting. I'll give it a go tomorrow. Thanks!
Old Oct 8, 2019 | 07:14 PM
fd3rew's Avatar
Just be sure to use the white/pink scotch scrub pads or what ever is the softest or lightest duty pads and not the blue(medium) or green(heavy duty) pads.
Old Oct 9, 2019 | 01:58 PM
Upon further inspection, the top 3+ inches of my rear window is pure Dot Matrix, not thick lines as I thought before. Can this be tinted over?
Old Oct 9, 2019 | 05:43 PM
Donkeypunch's Avatar
does using the defroster **** it up?
those lines can get pretty hot i think.
Old Oct 9, 2019 | 07:26 PM
User1's Avatar
Mine was tinted over and looked fine. Lots of cars with tint over that stuff. Also a big reason why removal is such a pita for me. Haven't had time to attack it yet. I'll get on in soon with the above suggestions.
Old Oct 9, 2019 | 07:27 PM
User1's Avatar
It never bothered any of my rear windows in Colorado.
Old Oct 14, 2019 | 01:47 PM
Thanks. I might just be over thinking this.
Old Oct 14, 2019 | 05:20 PM
User1's Avatar
I do the same thing bro, just ask child.
prc1974
Aug 23, 2018 08:50 PM
dmilamj
Nov 16, 2007 07:53 AM
jrbeilke
Dec 14, 2005 05:57 PM
00SEMAX
May 13, 2002 10:12 PM
sls_2000gxe
21
Jan 12, 2002 02:21 PM
