2003 Max: Car is auto locking itself. Help please
Old 01-01-2020, 05:31 PM
Bobby T.'s Avatar
New to the site. My Maxima started auto locking random about a month ago. The other day it started doing it a lot. I researched and did the turn the key on for 20 seconds then push door lock until blinkers blink to make the auto lock stop. It did exactly what it was supposed to do. Then 15 minutes later it started auto locking like it was possessed. Won't stop. I got in the car to do the key thing again and it won't change. It just kept locking. It was so bad I couldn't get out of the car until I timed hitting unlock and pulling the handle at the same time. Unhooked the battery. Next day hooked it back up, no changes. Anyone have any suggestions?? Thanks!
Bobby T. is offline
Old 01-02-2020, 05:02 PM
Theslaking's Avatar
Does it do it with battery out of the key fob?
Theslaking is offline
Old 01-02-2020, 05:19 PM
Perhaps the body control module will need replacing. Get one from a junkyard.
The Wizard is offline
Old 01-02-2020, 06:19 PM
Bobby T.'s Avatar
Yes, took the key fob battery out . Thought that was the problem.
Bobby T. is offline
Old 01-03-2020, 08:56 AM
fd3rew's Avatar
assuming everything is oem and you don't have any aftermarket alarm system......
just to make sure you don't have a bad door lock switch, pull off the door panel and disconnect the door switch. Do the driver's door first and if problem is still there disconnect the passenger side.
if you have an aftermarket alarm system yank the fuse for the module or disconnect the pair of aftermarket door lock/unlock relays
fd3rew is offline
TravisCadello
12-15-2011 08:41 AM
Nealoc187
19
11-13-2008 11:36 PM
sullivs
11-30-2005 03:33 PM
big_al
02-05-2005 07:29 AM
Bmr4life
06-25-2002 08:51 AM
Quick Reply: 2003 Max: Car is auto locking itself. Help please
