Car won't start. Help!
Old Jun 25, 2020 | 02:47 AM
Reba's Avatar
I have a 2000 Maxima. My car was running when the wires from the ignition coil connector (I think) touched and sparked. My car died and hasn't started back since. It turns over but it's not firing. The fuel pump is priming when I turn the key and all my electrical components (dash lights, radio, ect) are coming on. Anyone have any idea what I could do? Someone said i might have fried my computer? Thanks
Old Jun 25, 2020 | 09:16 PM
User1's Avatar
Replace whatever you fried when you shorted it.
Old Jun 26, 2020 | 05:43 PM
Reba's Avatar
Well that's the problem. I don't know what it messed up. Checked all my fuses. I was needing help figuring out what might have messed up causing it not to start
Old Jun 26, 2020 | 07:05 PM
User1's Avatar
I'm not sure I understand what your problem is. Try explaining it with more detail and context.
Old Jun 27, 2020 | 06:38 AM
Reba's Avatar
My car was running when the wires that plug into one of the coil.packs touched and sparked. The car shut off and hasn't started since. Its turning over just not getting any spark to fire up. Changed the coil pack, checked fuses, just have np clue what elss to do.
Old Jun 27, 2020 | 12:34 PM
Costee's Avatar
Run a scan. What is the status of your security indicator light with the ignition off and on?
Old Jun 27, 2020 | 01:22 PM
CMax03's Avatar
The car cranks over right? Check your ignition Fuses first. If it is blown fix the coil pack connector first (junk yard has plenty)! If there are no fuses blown check for spark, if there’s no spark check your ignition capacitor.
Old Jun 27, 2020 | 03:36 PM
DennisMik's Avatar
Under the hood is a fuse block. Check the 15 amp fuse labeled ENG CONT 1.
Old Jun 27, 2020 | 04:34 PM
User1's Avatar
Still not clear how that happens. Post a picture of the components that sparked.
95CustomMaxima
34
Jan 2, 2025 09:41 AM
Antant2485
May 7, 2015 08:12 PM
robsterzallan`
65
Jul 14, 2010 10:26 AM
96GreenGLE
Feb 20, 2005 06:33 PM
silvermax2k2
Feb 23, 2003 08:40 AM
