Front defrost button - not working
Old Jan 2, 2021 | 03:46 PM
josep's Avatar
HiSince I bought the car 4 y ago it did not bother me much, but this winter is pretty cold and I need to have my front defrost working - only that button does nothing (light does not turn on, no heat...). Apart from this, heating and AC work perfectly. Tried to find if there is a fuse or relay for this, but could not find it...I will appreciate any hint!
Old Jan 2, 2021 | 04:24 PM
J P D's Avatar
4 years of light winters? Sounds like TCU issue
Old Jan 2, 2021 | 04:31 PM
User1's Avatar
They have Maximas in Spain?
Old Jan 3, 2021 | 12:39 PM
josep's Avatar
yes 4th and 5th gen direct imports from Japan made it to Spain. Now pretty depreciated due to low mpg and 95octanes at .4$/gallon
Old Jan 4, 2021 | 01:07 AM
Fernando Alvarez's Avatar
What trim is yours? Does it have the factory touchscreen navigation? I ask cause I had the same problem on mine (03' SE) ; my problem was that the button had came off and all the Heater/AC controls and dials are actually integrated into the Nav system. Havent' been able to find replacement for mine but I was able to get it to work. Even if yours isnt the same post a picture of your AC controls to see if I could provide some sort of help.
Old Jan 4, 2021 | 12:05 PM
josep's Avatar
hi Fernando, I am not with my car now, but interior is as https://images.app.goo.gl/WLkCSJzXxWTaHeWS8which I believe is olderthan yours. thanks a lot for your interest in helping me!
Old Jan 18, 2021 | 08:00 PM
scotty64's Avatar
have you checked the heater resistor, this is located close to the blower motor in the heater assembly. it is held in with 2 screws, easy way to check if the resistor is stuffed is it will only blow hot air of full fan speed. the common issue with the blower(heater) resistor is it burns the electrical track and depending on how much has burnt away you may be able to solder the track together again. i did this with my A33 where i soldered it on the resistor it sort of resembles a fusible link. as to the lights not working on the switches it could be a loose plug, if you hit the sides of the heater switch and lights either flicker or come back on it could potentially be a loose connection.
Old Jan 18, 2021 | 08:08 PM
scotty64's Avatar
above is what the blower resistor looks like.
NismoMaximaA32
Mar 12, 2014 02:07 PM
gladiator
18
Aug 6, 2013 11:59 PM
whitemax99gle
Feb 26, 2005 05:57 AM
crazyravr
Mar 26, 2003 05:05 AM
ToYLeT902
Jan 30, 2003 11:54 AM
