Front engine mount replacement... Any advice?
Old Oct 6, 2021 | 03:49 PM
lapdog12's Avatar
Hey everyone, I have an '03 Maxima AT and I'm going to be replacing the front motor mount (OEM) this weekend and I was hoping to get any tips, tricks or advice. I consider myself still a beginner when it comes to working on my car, but I think this is a job I can handle. BTW, I only need to replace the front mount as that's the one that's broken and leaking. I replaced all the other mounts with OEM mounts about 30,000 miles ago so they should be fine.
I've done lots of searching and have a good idea on how to approach this. I will be dropping the front cross member and I'm also replacing the cross member bushings with OEM bushings while I have it down.
This is what I have planned after doing the research on here:
Start by unplugging the electronic sensor (brown clip)
1) Jack up car and put in Jack Stands at their appropriate places.
2) Remove the splash guards from under the car
3) Using the floor jack with a piece of wood I will jack up under the oil pan, slightly, maybe an inch, to take the pressure off the mounts.
4) Use a 17mm socket to loosen the center bolt on the front engine mount.
4a) Use a 17mm socket and a wrench on the nut on the other side to loosen, but not remove, the two bolts on the engine mount bracket that holds it to the cross member.
5) Repeat on the rear engine mount.
(My big concern is getting to the rear mount's center bolt, the one that attaches to the engine bracket. I've seen posts where someone takes a couple feet of socket extensions and reaches through the driver's side wheel well. Is there an easier way to access that bolt?)
6) Using 17mm socket, remove the rear (2) cross member bolts.
7) Repeat on the front (2) cross member bolts.
(Is the cross member heavy? Do I need to worry about it potentially falling on me?)
8) Since I'm only replacing the front mount, I remove the two bottom bolts holding the mount to the cross member. Put on the new OEM mount, put anti-seize on the bolt threads and bolt it back together.
(should I bolt this NOW to torque specs 57-72 ft-lb according to the FSM or should I wait until I have everything back in the car before tightening everything to spec?)
When putting everything back is there a smart way to bolt everything back up so it easier to line up the center bolts? Like, put in the rear mount center bolt first then the front mount, then put in the cross member bolts?
If any of you have any other tips and tricks, I'd love to hear them. Remember, I'm not as knowledgeable as you guys so don't speed through any explanations you might have.
Thanks!
Old Oct 7, 2021 | 04:51 AM
uptownsamcv's Avatar
I would recommend getting a cheap set of mounts for the manual transmission version and putting energy suspension mounts into them. I have an 02 6 speed and it would easily go through a set of mounts in less than a year, then I switched to Energy Suspension engine mount bushings, and they last a lot longer.
Old Oct 7, 2021 | 10:10 AM
lapdog12's Avatar
Thanks for the reply, but I'm not replacing any other than the front mount (at this time) and I'm sticking with an OEM mount. I don't have a 6 speed and I'm a pretty tame driver. I'm looking for advice, tips and tricks with the install process. Since you've done this a few times do you have any insights I should know to make the install go smoothly, well.... as smooth as possible.
Old Oct 8, 2021 | 10:11 AM
LA02MAX's Avatar
I wouldn't worry about jacking up by the oil pan. Matter of fact, I always advise against it because it's possible to create oil leaks doing that. Untorque all bolts first. Put the jack under the crossmember, then remove the bolts that bolt the crossmember to the car, then lower the jack. The engine will sag a bit but its held in by the left and right mounts. Then remove the two bolts holding the mounts to the engine and drop the crossmember. It's not a very heavy piece so no worries about it injuring you. Just lay it on your chest as you remove the last bolt. Install in reverse order, but make sure that the holes are well aligned with the car before you install the bolts or else you risk stripping the threads. You can torque everything down once all the bolts are hand tight. Leave them fairly loose until they're all started, at least, so you have some play to line everything up. It's always a good idea to source new bolts and subframe bushings if that fits into your budget. Also, you could soak the bolts with PB blaster an hour or two ahead of time to help with removal.
Overall it's a very easy job; much easier than most motor mounts I've replaced.
Old Oct 8, 2021 | 10:42 AM
Prophecy99's Avatar
i paid a shop, and they must have freaking done it in a very hard sequence or order. took em roughly 6 hours to replace both, i gave them new mounts with polys pressed in too. mine were also original so almost 19 years old. so maybe they had a hard time getting things loose idk. in hind sight i wish I shared the forum knowledge with them, prolly woulda saved them 4 hours lol
i am kinda glad I didn't do it my self i feel like I would have ran into problems, and i need this as a daily.
Old Oct 8, 2021 | 11:26 AM
LA02MAX's Avatar
Yikes, that's criminal... lol. I can jack up the car and remove that crossmember in 15 minutes.
Old Oct 11, 2021 | 05:12 AM
Ksnelgrove's Avatar
I replaced my front / rear mounts last year. You sound like me, perhaps a shade tree mechanic, but without any leaves left on the tree. It did require just the right length of extensions, and weaving through the wheel well to get to the center bolt. I live in the South, no rust, so it just took PB blaster and some muscle. BUT, I couldn't imagine having to do the job without an extra pair of hands. For example, for that bolt in question, I held the the extension/socket firmly in place while my partner cranked on the breaker bar two feet away. The same for removing and reattaching the cross bar. It's bulky, awkward, and a little heavy. Having one pair of hands on the front mount and a 2nd pair on the rear mount at the same time made a huge difference. Moral to my story: bribe a friend with Beer, or pizza, or both. You'll be glad you did.
Old Oct 14, 2021 | 05:22 AM
NZ 4th gen cefiro's Avatar
Consider not plugging the electronic mount back in, if the mount shorts out it will fry your cars computer.
Old Nov 22, 2021 | 06:18 PM
hithesh's Avatar
What do you loose if you don't plug in the electronic mount?
Old Nov 22, 2021 | 09:53 PM
Maybe a slight vibration at certain revs, I didn't notice any difference after I disconnected both electronic mounts. It is a known fault in this car along with the IAC valve, if either of the mounts or the IAC valve shorts out, they burn out a chip in the computer and it becomes a nightmare to sort out.
Old Nov 23, 2021 | 07:51 AM
DougR's Avatar
What do you lose if you don't plug in the electronic mount?
When I unplugged the front and rear mounts, I only noticed more vibration through the steering wheel. I can live with that.
Old Nov 23, 2021 | 08:12 AM
WTF? it took them 6 hours or you just left it there for 6 hours? I've done the lower mounts in less than an hour, in my driveway, with no power tools, and not even rushing it.
I can drop my tranny in a little over an hour in my driveway by myself.
Old Nov 23, 2021 | 09:10 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Scammers.
Old Nov 24, 2021 | 08:54 AM
best way to do it is drop the beam with the mounts attached and just change both, the only size socket and wrench you will need is 17mm and I think the 4 nuts are 19mm.
be careful on the 4 special bolts that attach the beam to the car, I've had mine off so many times that one of them always feels kind of iffy even though I replaced the 2 rear bolts twice. I recommend a tap to clean the threads m12x1.25...
I actually just had to email Energy Suspension on the lifetime warranty, mine are shot.
https://drive.google.com/file/d/1wZ4..._Kf5hXXiH/view
Old Nov 24, 2021 | 09:37 AM
Prophecy99's Avatar
yea man i was pretty disappointed once I saw the bill, to defend them , first off its not a normal routine thing, 2nd I am guessing they removed it the completly complex way and not the way the org knows, and 3rd they were original 19 year old parts down there so maybe stuff was hard idk..... but yea it sucked! i forget the cost of it, but I am glad I pressed the polys in mounts in myself and gotta good deal on the mounts from rock auto around 10~20 a piece...
i am super noob with turning wrenches and it's my daily driver so I left it up to them.... still a good shop though, they have figured out super oddball stuff when some shops don't even attempt. they installed ultra racing side lower bars for me with no directions
Old Nov 24, 2021 | 10:45 AM
what are ultra racing side lower bars?
Old Nov 24, 2021 | 11:39 AM
RA030726's Avatar
I'm nutty for Nissans
Sub frame connectors. Ultra Racing offers a bunch of chassis stiffeners that connect various parts of the car together.
Old Nov 24, 2021 | 11:50 AM
I went to their site but I'm not seeing a Maxima section, just 240sx, Skyline, Altima and Z's
Old Nov 27, 2021 | 07:45 PM
hithesh's Avatar
I have been working on swapping my front/rear motor mounts last few days.
Just when I thought I was done, the rear mount did not align.
The replacement mount frame needed to be expanded to fit the cross member bolt holes. Huge pain.
I might give up and call a mechanic.
Old Jan 18, 2025 | 07:37 AM
Originally Posted by Vq35deProof
Hey uptown! The front motor mount for my 2003 Max SE 3.5L '4 A/T' is shot. Would the 6-speed M/T 'Energy suspension' motor mount 'bushings' fit the A/T motor mount brackets? Or are the 'ES' bushing inserts different for the A/T and M/T motor mounts? Could any fellow org member point me towards some good brand motor mounts for the 2003 Max SE 3.5L 4AT? There are alot opinions about whether to change the 'front' motor mount to a 'manual tranny' motor mount because of the A/T wire/sensor issue doing major damage to the ecu. Then some say the M/T front motor mount will not fit. Or would it be much easier to get an A/T front motor mount w/ wire/sensor and just keep it unplugged and press-in an 'ES' bushing/insert? Any help will be thoroughly and greatly appreciated!
the auto has different size mounts but you can switch to 6MT mounts if you want to run the E.S. bushings...
Old Aug 31, 2025 | 07:34 PM
Hey uptownsamcv. Which aftermarket manual driver/passenger side brand motor mounts and manual tranny mounts would you prefer that would be great for polyurethane press-in bushing inserts dirt cheap, for a '02-'03 Max which has the auto mounts? Just replaced the destroyed front motor mount on my '03 se auto with a oem motor mount and kept the brown electronic sensor unplugged. Should have gotten a manual front mount. Just found out from mechanic that all mounts are shot to **** and would like to change out the side mounts & trans mount with a decent brand, but cheap to insert ES poly bushing inserts if they even make polyurethane press-in bushings for the manual 'side' motor mounts for this car. I am not that confident in changing the original auto mounts to manual mounts and not too sure how the best way to go about changing the driver/passenger side auto mounts and tranny mount to press-in either ES bushing inserts or the ES bushing poly insert into a manual transmission mount. Am I thinking too hard into this, and would you, or anyone chime in to guide me how to do this job? Any help/knowledge is greatly appreciated & welcomed, as the 2 side mounts & auto tran mount bushings are not only cracked, but they are completely ripped/ pulled out causing excessive noises, kicking, pulling, pucking as I turn the wheel and the car feels like it's shifting opposite directions when turning left or right. Its not the control arms.. just replaced them with Moog R-series control arms, but the front swaybar bushings need replacing because they're sliding. Just one more thing, where would be a few reputable part websites to buy budget-friendly manual 'side' mounts/transmission mounts with brands like Anchor, skp or even more expensive Beck Arnley if I have to source them one at a time and add the ES inserts, or any other polyurethane brand bushings. Just trying to go the manual mount/ES poly bushings route & don't mind a little vibration and not buy 3 more oem motor/tranny mounts. Need help desperately,
VQ
DAYUM, that's a lot to read..
when it comes to mounts you want to change all of them at once. most likely the uppers are worn and will reduce the life of the lowers if you change them.
Nisformance sells mount inserts that aren't too stiff and they're the only ones that has bushings for the upper mounts. since you have an auto you can only get the lowers and the upper on the passenger side from them. as for the upper driver side get a regular replacement.
you can get the lower mounts for the manual transmission for a really good price on Rockauto. the Anchor mounts are a good fit.
to remove the old bushings I drilled the rubber and cut the sleaves.
Old Sep 1, 2025 | 11:20 AM
you will need the manual lowers which are considered front and rear. just looked online and Nisformance doesn't sell mount bushings anymore. you can just fill the uppers with urethane filler and get the Energy Suspension lower mount bushings.
my Youtube video of me pressing in lower mount bushings
this is one I found on filling mounts..
Old Sep 10, 2025 | 06:02 PM
CMax03's Avatar
Nothing beats the ES mounts… I’m on my second set the original ES mount bore elongated after 10 yrs of spirited driving! All that mixing urethane chemicals BS never will make 2 yrs. Just buy the ES and stop experimenting you’re wasting g your time and money!
Old Sep 11, 2025 | 10:05 AM
I was talking about mixing urethane for filling the uppers, no one makes upgrade mounts for the uppers.
Old Sep 11, 2025 | 05:06 PM
CMax03's Avatar
Oh yes There’s a guy Redlion that does all of the them.
Old Sep 11, 2025 | 07:51 PM
CMax03's Avatar
Red Lion Racing is the name of the company. You can also find him on facebook.
Old Sep 12, 2025 | 10:16 AM
I'm already running E.S. lowers and Nisformance uppers. would have been nice if E.S. made uppers to go along with the lowers.
pahanorlando
Jun 29, 2016 07:56 PM
warlok
22
Mar 16, 2014 05:08 PM
jgilbs
Aug 29, 2010 12:30 AM
bill99gxe
23
Nov 30, 2009 12:50 PM
infinitiman96
Oct 7, 2003 01:03 PM
