check engine soon 2k2
Old May 15, 2002 | 10:19 AM
  #41
gt1380a's Avatar
Re: Re: Re: Re: Re: Re: Re: check engine soon 2k2
Originally posted by akrus
By 'long sensor' do you mean the long hot wire (red in top pic) or the long box as in the bottom pic? Can you check your driver side door jamb and post the build date? It would be nice to see if there is a trend we can spot.
Albert
the actual sensor inside the MAF tube extends almost the entire diameter of the tube. That is what i meant by the long sensor. I will post build date as soon as I get it back from nissan.
-j
Old May 15, 2002 | 11:35 AM
  #42
2002 Maxima SE's Avatar
Anyone who is having the CEL problem try this:
I have had K&N on two cars. The CEL was triggered on my Explorer and here is what I did to fix:
1)Remove air box and MAF.
2)If possible (it is possible on early model Explorers) remove the MAF.
3)Take a Q-tip and spray with Carb/Choke Cleaner. Swab the MAF contacts. On the Explorer, there are two wires (like light bulb filaments).
4)Replace MAF.
5)Use paper towel to 'blot' any extra oil from the filter (both sides).
6)Replace filter.
Ford says the MAF gets 'burned out' as well, but this is not true. Cleaning the oil off fixes the problem.
captchaos
Mar 15, 2016 12:18 PM
6spd4dsc
Mar 4, 2016 05:19 PM
jfl330
Sep 4, 2015 01:44 PM
mikebla
Sep 3, 2015 05:37 PM
A32goldylocks
Sep 2, 2015 06:39 AM
