My Agx Install Dramma
Old May 13, 2002 | 10:29 PM
Deven2kStickMax's Avatar
Some people are confused about installing the AGX, so i decided to do a write up.
Below is how i get mine done.
1. I installed the AGX with the 4th gen mounts(i got from cattman), drive all the way to DE and came back and heard knocking sounds on left. I know something was wrong. Both 4th gen mounts got busted. They were suppose to spin freely when the wheel sturns and they did not. They were too tight . I put on back my Tokicos/Eibach with the 5th gen mounts again, just to drive around. I was almost ready to give up doing the AGX. I let the AGX sit home for a few days and took a few days thinking what will be my next step.
2. I ordered a pair of 5th gen mounts from Queens Nissan for $70, then took them to a machine shop on 129st on 95th ave to have them machine off half cm on each spindle on the mounts(cost $10 ). I learned about half cm on this site from someone who did it. Don't remember who.
3. I took my car in my garage and started working again. I installed the agx with some help from my brother, using the modded 5th gen mounts and the Eibachs. I drove around and heard a noise from my left front. I know what the problem was this time. The strut spindle was not properly balanced in the center, so it was touching the mount spindle housing(the one that i had to clip half cm off).
4. I reinstalled the left front and i'm ok now with no problems.
On the rears i had no problem, except the spring will not go all the way down on the rear shock seat, but you have to install it in such as way that the weight of the car will push it down. Also i reused the stock dust boot/bumpstops on rear and front. i kept my original 5th gen mounts that came on my car, just in case i have to reinstall back to factory specs
HERE IS A WHAT I HAVE TO SAY TO MY MAX FANS, STAY AWAY FROM THE 4TH GEN MOUNTS. THEY WERE MADE FOR THE 4TH GEN AND NOT 5TH GEN. IF YOU USED THE 4TH GEN ONES AND HAD NO PROBLEMS GOOD LUCK, BUT READ NUMBER ONE ABOVE SORRY COULDN'T GET PICS OF THE INSTALL.
Old May 13, 2002 | 11:29 PM
[maxi-overdose]'s Avatar
thx for the post.....I wonder whats up with Cattman...they modified the AGX and gauranteed it will fit.
Old May 13, 2002 | 11:36 PM
well i called them and complaint and they said i was the second one to complaint about my install with Eibachs. I think they said the maxspeed or progress spring works well with no problems. If they had proper instructions on the install i wouldn't have gone through all this, but after all am happy with the AGX, just a little of work man.
Old May 14, 2002 | 09:58 AM
man...agx and eibach were my choice....now I might have to give up one of them. Any other spring u will suggest? Maxspeed sounded too cheap and it makes me worried about their quality. Not sure about progress.
Old May 14, 2002 | 10:05 AM
if u already have eibachs i suggest you keep them . the install is easy just have to follow the right steps, unless you don't want the headace you can get progress. she fits flush in the rears according to cattman tech. also there is a few people here that did Eibach and AGX, you can ask them . For me it worth it for the ride quality.
check this out eibach vs h & R springs...something to think about
http://www.tirerack.com/suspension/t...bach_hr_rd.htm
Old May 14, 2002 | 12:11 PM
thx man
Old May 15, 2002 | 04:57 PM
Galo's Avatar
Maxima Pilot
Dat article in TireRack.com was ezzzactly
why I did Eibachs in lieu of H&Rs on my SE along with the Tokico Blues...two months now, no noises, no creaks, no groans, no clunks, dead, pregnant silence...
Old May 15, 2002 | 05:38 PM
radpp16's Avatar
Re: My Agx Install Dramma
SO whats the big deal with these AGX struts, i am gonna be in the shopping scene in a few weeks for struts. why not Tokicos, seem simple, and they make them for the 5th gen, Are these AGX like the second coming of christ type deal?
Roger
Old May 15, 2002 | 06:02 PM
soundmike's Avatar
Very sound, Mike
AGX is adjustable that's all
Old May 15, 2002 | 06:17 PM
not adjustable alone, but performs goooood too.
Old May 15, 2002 | 06:21 PM
soundmike's Avatar
Very sound, Mike
I usually put that as a given, but just for the record... "performs goooood too!"
Old May 15, 2002 | 08:44 PM
scmaxima2k's Avatar
Im looking to lower my car with some eibachs and i need some new struts too. Ive been researching between the Tokicos and the KYBs and i dunno what to do. Does anyone kno when KYB is gonna release a AGX for the 5th gen and also i herd things about the Tokico illuminas being made for the 5th gen. Anyone got any suggestions for me, I know that im going with the eibachs but now i just need a strut. What is wrong with the tokicos besides the fact that they arent adjustable? I really would like the AGXs but after reading about all these problems and i do think that modified 4th gen struts is kinda sketchy anyways...can someone help me out?
Old May 15, 2002 | 08:58 PM
some ppl have problem with tokicos....esp the rear shocks...they are unexpected short-lived and not stiff enough for performance.
I am still deciding btw AGX and tokicos.
Old May 16, 2002 | 06:27 PM
what problems are you talking about mr. maxi-overdose? there is no problem, is just that is a first time install and the steps are easy as 123, if you follow like what i did and everyone else did. what's the big deal? this is the easiest thing to do, just have to make the effort. talking about problems, how about doing the KONI's install? That's some work, but the only person i know did that was Kevin i think. At least you don't have to rip any shocks apart...
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
