stupid sunroof. . .
stupid sunroof. . .
I was out for a ride this AM in my car and wanted to open my sunroof, and much to my surprise the damn thing didnt open. It has worked perfectly in the past but all the sudden when you slide that little tab back it just doesnt work. Heres the freaky thing, I decided to try the other button (the one to just tilt it up and open) and that one started opening the roof. I had to push it four times to get it open becuase it kept stopping at the points where the other switch is supposed to stop (1/4 open, 1/2 open, 3/4 open, full open). And than to shut the window I had to push it four times the other way. Sounds electrical to me. . .what do you all think. . any suggestions?
btw, its a 2K2 6-speed. . .
thanks
thanks
Interesting timing on your post. Just last night, I had to slide my tab 3 times back and forth for it to engage. There must be some contact points that arent' quite doing their job. Quite honestly, that is one feature on this car that I will be surprised if it holds up over time. I use my roof every day and the mechanism just feels a little flimsy. But so far, I've not had any other weird occurrences, like it opening by itself like some others have had (there's a post on it somewhere).
I think I'll mention it to my dealer next time I'm in for service; at least if they can't do anything to fix it right now, it will be documented.
good luck.
srm
good luck.
srm
That @$#$ switch
I noticed the same non-response on that flimsy switch for the sun-roof. I went to open it and the switch did not work. A few gigles later then it opened. Went out a few minutes ago same thing. After sliding the switch back and forth a few times, it finaly opened. Lets see what Nissan has to say about that issue, especially that the warm weather is here.
Non sliding sunroof
Well I am glad to see that I am not the only one that has had problems. When I installed my new XM radio, then my new Kenwood deck (both times disconnecting power at battery) I had to do the same thing to open and close my sunroof. After doing this once, the sunroof has worked fine. I am not sure if it has anything to do witth disconnecting power, but that is when it happened to me. Also I installed an amp in my friends car, (a 2002 eclipse P.O.S.), she had the same thing happen. It is freaky if you ask me.
Re: Non sliding sunroof
Did a little search for you.
Guy's,
Go read this post:
http://forums.maxima.org/showthread....=reset+sunroof
It seems you have to "reset" the sunroof.
Go read this post:
Re: Re: Non sliding sunroof
Originally posted by Newman
when i finally picked the car up on thursday i slide the button back to open the roof and nothing happened. i switched it forward the back again. nothing happened. did this a couple more times. then i tilted it up, tilted it down and slid the switch back again and it opened.
I have a question sort of off topic. I know it's been covered before but....if you take off the plastic wind fairing on the roof, does this decrease any of the wind noise from the roof being open? Mine's starting to crack anyhow, and I'm thinking I should take it off before it damages the paint. (I hit 120 too many times...It's starting to spider where the bolt is on the drivers side...and no, it didn't come like that.)
Re: Re: Re: Non sliding sunroof
Originally posted by DrVolkl
I noticed a few things too.. For instance, if you slide the switch back while the car is off, and then turn the car on, it won't respond. (i.e. if it's closed and you slide it to open, it won't open when you turn on the car...at least mine doesn't).
Re: stupid sunroof. . .
thanks
thanks
Read the manual on how to reprogram it if that's the case, if it's not call a person you "should" consider a good guy to get to know. He's your service consultant.
l8tr -- SS
Re: yeah..
Originally posted by TimW
owners manuals are wonderful things
no really, they should but the reset procedure in a more conspicious place..
Some people have complained of the sunroof opening by itself? That concerns me the most!! Does that only happen when you're actually driving (or got the car on) or has anyone ever noticed it happend when the car was not on? hm...
Re: Re: Re: Re: Non sliding sunroof
Originally posted by suds1
If you would like a new sunroof wind deflector, let me know. That was the first thing I did to my 2k2 was take it off. Its just sitting in my garage now taking up space. Just pay the shipping and its yours. Reply to this post if your are interested.
Hmmm...never really taken an "extra" off a car...I'm used to just adding crap. Feels kinda wierd.
abcdefhg I was out for a ride this AM in my car and wanted to open my sunroof, and much to my surprise the damn thing didnt open. It has worked perfectly in the past but all the sudden when you slide that little tab back it just doesnt work. Heres the freaky thing, I decided to try the other button (the one to just tilt it up and open) and that one started opening the roof. I had to push it four times to get it open becuase it kept stopping at the points where the other switch is supposed to stop (1/4 open, 1/2 open, 3/4 open, full open). And than to shut the window I had to push it four times the other way. Sounds electrical to me. . .what do you all think. . any suggestions?
thanks
thanks
the dealer won't replace it now, b/c its working
Originally posted by lcf
id be willing to take the deflector!!!!!!!!! plz respond.
dssingletary@earthlink.net
I don't know how much shipping will be. If its not much then I'll just pay for it.
Its yours. E-mail me the address you want it mailed too.
Originally posted by JAKE02
My sunroof wind deflector was cracked also near a bolt on the driver's side. Had it replaced under warranty recently. Just a FYI in case you want to keep it on your max.
Re: Re: Re: Re: Re: Non sliding sunroof
Will attempt again today with screwdriver and wrench.
Found numerous cracks in the sheild that were not there when I bought it....what a piece of junk.
3846 miles....
Re: Re: Re: Re: Re: Re: Non sliding sunroof
Took off the roof deflector. What a difference. The roof is WAY quieter when popped open, a little quieter when slid open. I like the look too.
3846 miles....
3846 miles....
maybe ill take mine off now. if it doesnt reduce noise then whats the point of it? all it does is potentially harm the paint underneath (so ive heard) and water and other things just stuck under there.
Re: Re: Re: Re: Re: Re: Re: Non sliding sunroof
Originally posted by Hobert
Mine came cracked. I recently removed it because I think it looks alot better without it. I have not noticed much more wind noise at all. Maybe I wasn't paying enough attention. Regardless, take it off and see how you like it. If it becomes too noisy for you, put it back on.
But... the service guy that handled my case was such a prickhead that he didn't really want to do anything with it. He said it only carried a 1yr/12k mi warranty too.. All BS.... He even changed the work order statement to read "customer claims sunroof wind deflector is cracked... Inspect then replace if necessary..." It was so obvious that it was cracked. Maybe next time when I do go in for something I'll ask to talk to the Manager first...
great, i took my ride in to the dealership for the 30k service last week, today i found out i have problems with my sunroof. I was driving on the freeway when i wanted to close the tilt on my sunroof. so i pushed the button (i had the sun cover covering it so i couldn't see the sunroof) to close the tilt. anyway i didn't hear it and i thought probably cuz i was listening to the radio too loud, so for safe measure i decided to push the close tilt "again". this time i heard it but i thought it's wierd how i could hear it quite well that time, so i push it again ONE more time, to MY SURPRISE, the sunroof opens an inch!
so i'm thinking...what the heck? (i thought maybe i had flickered the sliding roof switch) so i decide to close it so i hold down the sliding roof switch to close but it only moves in increments! and the super weird thing, both switches do the same thing now. I can tilt the sunroof with the sliding switch. and vice versa. also when it slides open/close it goes in increments!
the auto slide doesn't work either. i tried the "reset" but it didn't work. maybe cuz i have a 2K not a 2K2? cuz I looked in my manual and it doesn't have a section on resetting the sunroof. i called Nissan they told me to bring it in
any suggestions?
any suggestions?
I'd like to know if his ears start bleeding and his eyes bulge.
(Seriously, if you don't get the flutter and pressure changes at high speeds, I'd take mine off... The deflector that is...)
deflector demoted
...after reading some of the posts about removing the deflector, it got me to thinking. I never have liked how it blocks some of the view out the front of the roof and I was sort of concerned about the retention of water and dirt..but not too much. Anyway, I decided to remove it to see how I liked it. Now the funny thing is had my car not come with one, I would have bought one. Well, after a week of driving without it, it is staying off. There is no real noticeable difference in wind noise, I haven't experienced the low speed or high speed flutter that I sometimes get in our LS 400 or SE-R, and actually I think it does look better without it. And the improved view is great; after all, these sunroofs really aren't that large to begin with.
And, my paint is marked too where the deflector was, and although I have waxed and it did remove some of the marks, not all. Hopefully it will lift eventually. So, if you are thinking about it, go for it, I think you'll be pleasantly surprised. The "built-in" pop-up wind deflector actually does a pretty good job at redirecting the air, again, better than our LS 400 and the SE-R doesn't even have one!
Sooo, if anyone wants to buy mine off of me, you can have it...it's just taking up space.
srm
srm
Originally posted by KaxMaxSEAE
Hey, can you do me a favor, and get on the expressway @70mph with someone in the back seat?
...by the way...don't you mean "cars like it...9,999" (grin)...just messing with you, but that would be more accurate, right? Just out of idle curiosity, did anyone ever figure out how many manual AE's were built? Although I traded out of mine...I still wonder just how rare that car was. Although I'm happier with my 02, I do miss the "exclusivity" of the AE. It never failed to turn heads and get people talking. I do still get oogled in my 02, but not as obvious as with the AE. oh well, I'm rambling now...just popped this off to mess with you...but got carried away...srm
Re: Re: Re: Re: Re: Re: Re: Re: Non sliding sunroof
With all these .org non-AE members putting on AE body kits, pedals, engine covers, headlights and tails, sills, shifters and keys (but no floor mats
,) it's probably more than 11,000, but I digress...
Anyone wanna fess up on putting a 20th anniversay badge on their trunk?
Yeah, and I'd like to know 1) How many AE's were put together, and 2) how many aftermarket body kits they've sold...
(Damn. Next time I post, I'm gonna have to break out the scotch...)
Forge277
Jun 13, 2016 09:26 PM
pears
Sep 18, 2015 05:25 AM
A32goldylocks
Sep 16, 2015 01:33 PM
