HELP with Frankencar Intake, 2000
Old Jun 26, 2002 | 06:15 AM
  #41
asu174's Avatar
Clay Aiken has fancy genitals
Originally posted by Neal728
Bump. Anyone use both brackets with their Berkencar, or Frankenberk?
Sorry- to clarify, I originally had JUST the berk filter with no midpipe. This is when I used the Berk bracket. THEN I got the midpipe, which rendered the Berk useless. This is when I put the Frankencar bracket on.
If you look beneath the filter, you will see that there is no way to use the Berk. The wheel well is in the way.
Old Jun 26, 2002 | 10:03 AM
  #42
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Originally posted by y2KAOSMax
Did you connect the black bracket, which it was attach to before taking that stock air box out, back on the strut tower and put it on that??
yes that is what i did. correct.
Old Jun 26, 2002 | 10:10 AM
  #43
Neal728's Avatar
Hey steve, with your bracket, should the bracket go on top of the FSTB or below it, between it and the strut tower. Where'd you put it? Thanks.
Old Jun 26, 2002 | 10:11 AM
  #44
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i installed the berk and franken pipe at the same time. im using the berk bracket and using small tabs of thick window stripping underneath the bracket to keep things sturdy. i wasnt quite sure what to do with the fraken bracket.
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
MichMaxFan
Sep 30, 2015 09:18 AM
homewrecker
Sep 24, 2015 07:01 PM
