nice change in gas mileage
Old Jun 22, 2002 | 12:48 PM
  #41
lcj2002se's Avatar
Originally posted by Mill McSly
i get ****ty mileage on my 2 month old 2k2 se. I fill my tank and it starts at about 240-255... then when my gauge is under a quarter tank...i go to refill it and i look at my miles for the tank and it's merely at 150... Could this just be from my driving? Almost all city..? should i get this checked out. It almost always says i get 14.8mpg..
Don't feel bad. I get 13-15 mpg city/hwy if I drive it hard, but if I drive it easy, I can get 17 combined.But still, that's about what you get. Best Ive gotten on the hwy is 24. Have you taken it to the Dealer to check it out??
Old Jun 24, 2002 | 03:26 PM
  #42
spaaz14's Avatar
I put the Bosch Platnum 4+'s in........not worth the time and effort.
Old Jun 24, 2002 | 03:35 PM
  #43
xChungHsienx's Avatar
soo NGKs at 40,000 miles it is. Thanks guys
Old Jun 24, 2002 | 03:41 PM
  #44
xfirepwr1's Avatar
Re: nice change in gas mileage
403 vs290 seems a little high of a difference. R u sure that u did not only drive on the high way, when u got the plugs installed. If I could get 113 miles more just by changing the spark plugs believe me I would change them every time I change my oil
Old Jun 24, 2002 | 04:16 PM
  #45
ZIPPIN's Avatar
Mauja He Mauja
Re: Re: nice change in gas mileage
I posted this after i started the thread:
this is the best mileage i have gotten since i bought the car. i have gone about 360 bfr, but never over 400. When i changed the plugs. i also went tri-synthetic, cleaned the K&N, cleaned the Throttle, aired up all the tires. But the driving was the same as i do everyday.
I am at 147 and the needle is a tad above the first quarter. Will post how many miles the second tank fives, after the plug change etc.
Old Jun 24, 2002 | 09:03 PM
  #46
Mill McSly's Avatar
If i could just get 113 period i would be happy...
Old Jun 24, 2002 | 11:22 PM
  #47
burma's Avatar
The reason that there are large fluctuations in gas mileage is because people don't calculate it properly. You need to fill your tank and reset the trip meter to zero. The next time you need gas, fill the tank again, and determine how many gallons you purchased. Make sure the tank is filled. Divide the mileage by the gallons to determine the MPG. There is no other accurate way.
People in Canada will get higher MPG readings as Canadian gallons are 20% larger than USA gallons.
Old Jun 25, 2002 | 05:04 AM
  #48
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
i use that method for my gas fillups and i still get horrible mileage, i drive HARD though.
Old Jun 25, 2002 | 05:19 AM
  #49
Virus's Avatar
Years ago when i had my Civic I tried just about every brand of spark plugs imaginable. I always had a smoother running engine with better gas mileage using NGK's. I bought into the hype at that time about the spitfires adding 5hp, but the car ran horrible and the gas mileage dropped.
Old Jun 25, 2002 | 12:30 PM
  #50
wdave's Avatar
Re: Re: Re: nice change in gas mileage
I wouldn't assume that the plugs are responsible for most of the change considering how much else you did - particularly cleaning the air filter and changing to syn, especially since the plugs are a 105kmi service item and important to passing smog.
Old Jun 26, 2002 | 01:41 PM
  #51
Nore474's Avatar
so just go to the dealer
they sell the NGK sparkplugs at the dealer?
and should I get the wires to how much are they?
Old Jun 26, 2002 | 03:38 PM
  #52
ZIPPIN's Avatar
Mauja He Mauja
Re: so just go to the dealer
call Dave.B. they are 8.53 a piece(if you mention the org) and minimal shipping..we have direct ignition so no spark plug wires
Old Jun 28, 2002 | 07:15 PM
  #53
Alain's Avatar
This is pretty much what I get also on my 2k2 SE (when converted to MPG and US gallons). I have about 5K miles on it and average 17MPG (city and highway). The best I got was today (27MPG) but that was all highway at 65 (long weekend here, too many cops). If I only do city driving it can easily go down to 9-11 MPG (and I don't rely on the ****ty onboard computer which is way off...). I drive rather hard from stops (regular stops or street lights) which doesn't help and I have an Auto which doen't help either.
My former car was a Grand Prix GT 1999 and I was riding it harder than my MAX, but it never drank so much gas as my Nissan (and it ran on regular gas as opposed to the Maxima). On the upside, it never handled even close to the MAX...
Old Jun 28, 2002 | 09:02 PM
  #54
Nore474's Avatar
for 4th gens
does anyone else's 4th gen stay full past the F for a while?
then when it goes past it the needle seems to go down fast.I clocked it and half a tank is at 160 miles for me
is this normal?
Old Jun 28, 2002 | 11:50 PM
  #55
DrVolkl's Avatar
Weird. I just went 482.9 miles on 16.6 gallons of gas. That was mostly highway driving (Went to Seattle and back) but I did some messing around...including a little race with a new Eclpise and some sort of mitsu 3000gt (most likely non-turbo from its accel)
I usually get 360-380 on 15.8 around town. I've said this before...I dunno what you guys are doing to get such low MPG readings. Unless you have an auto or unless you haven't tried 5th or 6th gear.
Old Jun 29, 2002 | 08:56 PM
  #56
Fezzik's Avatar
I calculated mine out to be a little more than 450 miles on a tank of gas hwy. I have also calculated out that I get around 26.5 mpg hwy and I am still havent filled up my tank in the city yet. Let you all know then.
Old Jun 29, 2002 | 09:23 PM
  #57
Mikie's Avatar
Can anyone tell me how long it took before you started getting your best gaz mileage figures after you bought the car? Was it after the first tank or 2 or after the first 2500 miles?
Old Jun 30, 2002 | 04:03 AM
  #58
john2002max
I'd get it checked out! That is terrible milage. I have a 2K2 and drive it like mad, but I always get over 20 MPG even in town. Over 25 on the highway.
Old Jun 30, 2002 | 08:03 AM
  #59
ZIPPIN's Avatar
Mauja He Mauja
Last week i replaced the origional spark plugs, at 66000 miles. I was getting about 290 miles to the tank bfr ( half highway and half city driving). i filled up the tank and have 403 miles, and the fuel light hasn't even come on yet...
i didn't know there would be such a big difference,,anyone care to shed some light on it??
Ok second tank gave me 378 miles ,,still don't understand why i got over 400 the first tank after tune-up..and yes the driving again was the same as i do everyday
Old Jun 30, 2002 | 10:01 AM
  #60
maximadriven's Avatar
I am taking delivery tomorrow on a '00 SE with 66k and the first things I am going to do is plugs,synthetic oil and Redline fuel system cleaner. Any suggestions on where I can find a How-To on changing the Spark Plugs?
Thanks In Advance...
Old Jun 30, 2002 | 02:23 PM
  #61
ZIPPIN's Avatar
Mauja He Mauja
i did one with pics and send to Russ. He still hasn't posted it yet. If someone else wants to host it, let me know and i can send it to you
Old May 15, 2004 | 09:10 AM
  #62
ZIPPIN's Avatar
Mauja He Mauja
[QUOTE=dba1999us]i filled up the tank and have 403 miles, and the fuel light hasn't even come on yet...
QUOTE]
wish i was still getting the 400 miles with these crazy **** gas prices..
Old Jul 4, 2005 | 08:37 AM
  #63
ZIPPIN's Avatar
Mauja He Mauja
i wish it was the case now with the gas being soooooo expensive
Old Jul 4, 2005 | 01:10 PM
  #64
dmonger's Avatar
Originally Posted by MaximaMan77
You wanna talk about bad gas mileage lets talk about my 02' 1500 Silverado 5.3L now that sucks it down and it has a 26 gallon tank!
You wanna talk about bad gas milage I have a '96 Tahoe that gets around 12.5mpg with a 30G tank.
Old Jul 4, 2005 | 02:20 PM
  #65
S00NR1's Avatar
OU > *
Wow, way to bring back an ancient thread.
Old Jul 4, 2005 | 02:56 PM
  #66
Y2k2maxse's Avatar
It depens on how fast you drive too, i got great mileage, about 28-29 going 55-60 on cruise with a 5spd. Did some heavy starts too, and still got great mileage. This is after I replaced the MAF sensor. i usually get about 22-23 when going average of 80 MPH.
Old Jul 4, 2005 | 05:53 PM
  #67
handsofstone's Avatar
has anyone factored in the 3 gal. reserve? it will stretch things out for you a bit.
Old Jul 5, 2005 | 01:01 PM
  #68
OAUSSIEO's Avatar
I consistantly get 290-320 miles I drive 50/50 (city/highway) just have new airflow meter, and K&N Filter...
Old Jul 5, 2005 | 09:45 PM
  #69
Gennady7's Avatar
These numbers are all wonderful but why is there such a big gap.
I have a 2000 Nissan Maxima that I have treated well. I am running a stillen pop air intake, NGK Irodium plugs and I keep it under 3k rpm. I get on avg 250 miles. Now I am getting close to 100k miles on the car.
Now how the heck do you get over 300? This is mosly city.
With 2.60 a gallon for 93 I am not sure I wanna drive anymore.
Old Jul 5, 2005 | 11:37 PM
  #70
OhOhMax's Avatar
Are these some "special" NGK plug? All I run in my cars are NGK plugs and I have never payed anywhere near that much per plug. The most I can ever remember spending was $2.76/plug. But then again I haven't done plugs on this car yet.
Old Jul 5, 2005 | 11:58 PM
  #71
OhOhMax's Avatar
Wow.... just looked up that PFR5G-11 plug, that's an expensive plug, holy crap. Normal price $28.22 and I foud it for $17.99 looks like I'll be giving Dave B. a call soon.
Maximan190
Dec 16, 2015 06:01 AM
220k+ A32
Sep 11, 2015 02:18 AM
dcam0326
Sep 7, 2015 07:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
