Maxi's Grille - Still Under Construction
Old Aug 2, 2005 | 09:28 PM
  #41
HzMajesty's Avatar
In answer to the PM's, heres my write up... hope it helps... PM me for any more details.
what you will need is:
small saw (home depot or any hardware store)
mesh grill (automart or any other car store)
cutter to cut the mesh (home depot or hardware store)
glue (i used super glue)
1- use the saw to cut the studs holding the rows of teeth to the frame. You will need to brake the black plastic from the back sides of the teeth to get to the studs on the side. When u saw through them, make sure you dont scratch and damage the frame finish.
2- cut out an approximate peice of mesh and keep cutting/adjusting till it fits FIRMLY into the open space - again be careful you dont scratch the frame with the mesh edges. Once you have a good fit, you can cut the other peice of mesh using this one as a template. they are identical and you just flip the mesh over to use on the other side.
3- Insert the mesh into the frame making sure it holds firmly. Look for contact points between the mesh edge and frame and apply no more than 2 drops of super glue to that point only. Do not over use as superglue will ruin the frame and mesh finish so be careful! Let it dry and instal on ur car!
Old Aug 2, 2005 | 11:38 PM
  #42
boone's Avatar
You gon' pay what you owe
Excellent work. It adds a whole different look to the car.
Old Aug 5, 2005 | 10:51 PM
  #43
cannonscreation's Avatar
that looks hot
Old Aug 5, 2005 | 11:13 PM
  #44
EdRomo86's Avatar
holy crap boone, what the hell do you wax your car with. that is the cleanest max ever. it seems as if you have absolutely no swirls on the paint. the paint actually looks wet. it looks really good. props man.
Old Aug 5, 2005 | 11:42 PM
  #45
DeusExMaxima's Avatar
Thats a really sharp grill. Any intentions of making one that is body colored? How bout a photoshop of it. I bet it would look hot!!
Old Aug 6, 2005 | 01:14 AM
  #46
HzMajesty's Avatar
can u photoshop?
Old Aug 6, 2005 | 05:23 AM
  #47
akaxmrxhammer's Avatar
nice work hzmajesty. btw, are you in bahrain right now?
Old Aug 7, 2005 | 08:27 PM
  #48
HzMajesty's Avatar
i wish bro... Pittsburgh right now..
december though !!!!!!
Old Aug 9, 2005 | 08:15 PM
  #49
twistedsam's Avatar
I like it and its better if u make ur own shzit like ur doing it, in my opinion. I almost did what u are doing but I went with the SSE grills.
Deus where did you get your front grill from? I am diggin the black on black looks hott. Did you paint it your self? thnx
--sam
Old Aug 9, 2005 | 08:50 PM
  #50
Twisted: I bought it from Stillen. Its the Street Scene grill, both teh upper and lower one. I had them powdercoated black. Thanks!!!
REDinLV
Aug 15, 2024 12:30 AM
05RLS2
Nov 7, 2016 05:52 PM
magiconthetire
Oct 26, 2015 09:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
ricky7780
Sep 24, 2015 06:50 PM
