6th Gen Maxima Rim width question
Old May 3, 2007 | 06:14 AM
Smoke_Screen's Avatar
Hey all, I just chose some new rims by Konig after doing MONTHS of research. I chose the 20" X 9" wide Konig Beyond
But when I placed the order, the sales rep told me that these would rub on my car. Now, I personally think he's just mistaken and/or trying to push me to another wheel because these are on backorder.
However, I would feel reeeeeally stupid if I acted smart, bought these with the 245/35/20 tires and they rubbed.
My car is currently not lowered, so the question is do you think they would rub now? Or might they if I lowered the car a bit?
If you or someone you know have installed 20X9's I'd appreciate your feedback although any input is welcome.
Old May 3, 2007 | 07:12 AM
maxchef's Avatar
NO NO NO!!!!!!! its been done a million gagillion times! I have 10.5 in the rears with NO rubbing! But the thing is you have to look at your offset. Find out the offset and let us know. But i am pretty sure that what you have chosen will work out just fine. Stick to your guns and get what you want!...PERIOD!!
Chef
Old May 3, 2007 | 07:22 AM
NmexMAX's Avatar
dot dot dot ...
Depnds a lot on wheel offset.
Old May 3, 2007 | 08:12 AM
Maxchef, is your car lowered? What width do you have in the front?
Good point on the offset. The offset for these 20X9 wheels is 45mm. What do you think?
Old May 3, 2007 | 09:06 AM
MiamiBlackMax's Avatar
what is the range of a safe offset on the 6th gen?
Old May 3, 2007 | 09:24 AM
Puppetmaster's Avatar
That's hard to estimate because it depends on the rim width as well.
Use one of these as a guide:
http://forums.maxima.org/showthread.php?t=243784
And what do you mean by "safe"?
Old May 3, 2007 | 10:32 AM
Check my verification
I wish the calculator sticky in the wheel forum had the OEM data...
Someone please check my numbers, but based on my understanding, the OEM 17" wheel is 8.5" wide and has 45mm offset. -right?
So using the handy tool http://www.rims-n-tires.com/rt_specs.jsp I don't think I have anything to worry about with 20X9's at 45mm offset and the 245/35/20's. It actually shows 7mm more clearance on the inside with the new wheels. Also, I get the same rolling diameter.
Old May 3, 2007 | 10:37 AM
OEM 17s are +40mm offset and are 17x7. Offset should be stamped behind the wheel somewhere and the rest is in your owner's manual.
Old May 3, 2007 | 02:02 PM
xoomer.com's Avatar
I Donate! Why Don't You?
Chef
What offset are your 10.5s??
Old May 3, 2007 | 02:17 PM
kidd4l's Avatar
Cool Member
I have 20x9.5 with 40 offset for the rear, tires are 255/35/20, no rubbing. It will rub if there is 3 people at the back seat. Also, the car is lowered on Progress Springs.
Old May 3, 2007 | 04:19 PM
Thanks for checking my numbers, I was pretty off on the OEM specs, & didnt feel like sticking my head inside the wheel.
With the new OEM numbers, this is what the calculator said about the new 20X9's with 45mm offset:
"Package is 15 mm (0.6'') closer to suspension/brakes components. Acceptable for most cars." how is this so when the 'backspace' is 31mm more?
"Package will stick out 5 mm (0.2'') farther. Acceptable for most cars."
From what kiddl said I dont see how rubbing is even remotely possible with the setup I'm looking at.
I'd still like some general opinions about whether a 20X9 with 45mm offset is likely to rub on a non-lowered car.
Old May 3, 2007 | 06:31 PM
You could always get some spacers to push the rear wheels out a little if they are too close to the inside.
Old May 4, 2007 | 06:08 AM
NismoMax80's Avatar
SuPeRmOd
OUR forum STICKY has the OEM data and calculators
Old May 4, 2007 | 04:47 PM
SEBOY's Avatar
Go for it man you will be fine
Old Sep 5, 2010 | 10:29 AM
04SL's Avatar
Will a 17x7.5 wheel with a 45mm offset (from a newer G35) with a 225/55/17 tire fit a 2004 Maxima ? I currently have 18x8 245/45/18 and they look great but the ride it too stiff and Im thinking about getting a smaller wheel/bigger sidewall.
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
morteljc
Oct 19, 2015 10:47 AM
MikesChevelle
Aug 10, 2015 10:53 AM
