Single outlet 3" exhaust with Vibrant muffler installed!!
Old Nov 10, 2008 | 02:20 AM
  #41
kamski's Avatar
.org extraordinaire
Oh man, Deuski, your tires are facing backwards.
The grooves are supposed to be aligned in such a way that the tread arrows are allways to be facing the foward direction of travel.
Otherwise your tire will be pulling rain in as opposed to pushing it out.
This only matters in wet weather conditions.
Actually i run my tires backwards on the track when its dry to even out the wear.
Kamski
Old Nov 10, 2008 | 04:16 AM
  #42
secondtonone317's Avatar
nycnissans
http://forums.nycmaximas.org/showthr...307#post689307
I posted it up on our local forums......looks good. They did a great job on the pipes.
Old Nov 10, 2008 | 09:58 AM
  #43
DeusExMaxima's Avatar
Thanks. Apparently a lot of them didnt seem to care for it which is ok. I am very pleased with it. It might take a bit of getting used to.
Old Nov 10, 2008 | 10:42 AM
  #44
Torgus's Avatar
i really thought it would come out...better...seeing the muffler is really a turn off to me. i likes your old setup alot more. but the weight savings and performance probably pay off for it. i'm glad you like it! i'm looking forward to the videos.
are your tires backwards?
Old Nov 10, 2008 | 12:17 PM
  #45
BlackDUBS's Avatar
pipe looks good.
Old Nov 10, 2008 | 12:32 PM
  #46
BadBlackMaxSL's Avatar
I know the mod was more for performance and sound/tone but it makes the wide ***-end of the Max look unbalanced. For me, 4>1 but I do love the black muffler. Paint the pipe that you can see flat black too to really hide the secret of your sound. Dues is always expanding the Max's zone of influence.
Old Nov 10, 2008 | 01:18 PM
  #47
2theMaX05's Avatar
Nice job, very unique...
Old Nov 10, 2008 | 01:56 PM
  #48
boiler725's Avatar
Looks like a quality job! Just bought an '08 recently and all you guys are making me want to spend money. Can't wait for the clips...
Old Nov 10, 2008 | 02:13 PM
  #49
CMax03's Avatar
So below 2500 rpm, it's more responsive than stock or Cattman?
Old Nov 10, 2008 | 04:48 PM
  #50
The throttle response is VERY good and the ECU adjusted nicely to the higher RPMs. The sound above 3500 RPMs is absolutely, positively intoxicating. I know its hard to get used to the single pipe versus the OEM quad exhaust, but it really cleans up the rear.
Old Nov 10, 2008 | 04:55 PM
  #51
DrunkieTheBear's Avatar
Turbo'd Saab
and dyno's will probably prove your butt dyno true.
You might be the highest NA whp 3.5 on the org....I think only one hit 270whp...I think your in the 260whp range now
Old Nov 10, 2008 | 05:39 PM
  #52
I tacked together two resonators because I need sound reduction. They didnt make one in 20 inches but they did have two that were 14" each for total of 28". I also needed a small diameter resonator and I went with 4" diameter. I could have gone for one resonator at the risk of being too loud. Im very pleased with balance of this system: sound, performance, look, tone quality. Its ALLLL good.
Old Nov 10, 2008 | 05:41 PM
  #53
Those nycmaxima guys are quite the haters, arent they? Dam!!!
Old Nov 10, 2008 | 05:48 PM
  #54
SpooledVQ35's Avatar
We are not haters. We just voice our opinion more then others.
Old Nov 10, 2008 | 06:11 PM
  #55
scrui's Avatar
Not a fan at all.
Old Nov 10, 2008 | 06:13 PM
  #56
MaxJ04's Avatar
IT looks good .. Mark .. i like the way it looks in black.. flows well with the car... oh yeah try to mold the other side and paint it ... it would look sick... .02cents.. but not bad ...
Old Nov 10, 2008 | 06:59 PM
  #57
IHAVEA2KMAXIMA's Avatar
So where's the sound clip?
Old Nov 10, 2008 | 08:57 PM
  #58
Matts04Maxima's Avatar
why ? ...... why not ??
just not a fan. Sorry
Old Nov 10, 2008 | 09:08 PM
  #59
PulsarGTS's Avatar
I noticed that too. Maybe they are unaware it was more of a performance mod than anything else. Form follows function and it sounds like it works great.
Old Nov 10, 2008 | 09:35 PM
  #60
zuko's Avatar
the anti rice
Jesus, what's wrong with you? That looks absolutely terrible.
While one could admire your attempt of something new and different, the end result to most of your mods is catastrophic and always out of place/ugly/tacky/ricerish/stupid.
Old Nov 10, 2008 | 11:00 PM
  #61
What do you mean "mold the other side".
Old Nov 10, 2008 | 11:03 PM
  #62
There is a distinct difference between voicing and opinion and saying hateful things, and some of the nycmaxima members crossed that line. I can take criticism with no problem, and even haters too. Im just simply voicing my observation.
Old Nov 11, 2008 | 01:07 AM
  #63
po8pimp's Avatar
I know my opinion doesn't matter too much but I think it looks good. Need to install that cover a bit better and paint it but other than that looks like it's supposed to be that way. If you didn't know any better you wouldn't even question it. as far as the tires being on backwards, they are. You had me confused so I had to go check out my tires and make sure. there should be a small arrow on them showing you the direction they turn. sometimes it's on the inside wall. +1 on the sound clips and dyno sheets.
Old Nov 11, 2008 | 01:15 AM
  #64
Ur opinion matters and thank you. Glad u like it. The exhaust cover is painted. I need to clean it up some I think. Ill check my tires and switch if they are wrong.
Ill get sound clips really soon. I have to get retune since it idles poorly from last tune. Ill get dyno run. I did change my intake but it shouldnt make a difference.
Old Nov 11, 2008 | 01:50 AM
  #65
kamski's Avatar
.org extraordinaire
Fak what the haters say. Deus your car sees more track time then any other numpty. This is a true power mod designed for power and track use.
It looks stealthy and awesome, but hey most people that dont like it prolly have chrome rims and some form of noise making subs in their trunks that just weigh the car down even further. They drive around the block half leaning back in their seats, one arm out the window listening to TUPAC with the base cranked. EPIC FAIL!
Deuski you turned this car into a true sports sedan, a car that schools evo's at lone pine. Keep on moddin my friend and schooling the tools.
Kamski
Old Nov 11, 2008 | 01:53 AM
  #66
Kamski
Thanks for the props my friend.
Old Nov 11, 2008 | 08:51 AM
  #67
Torgus's Avatar
your car schools EVOs? i'd like to see that...vids?
Old Nov 11, 2008 | 08:59 AM
  #68
I enter a high speed time trial each year at Lone Pine, CA, and I do school Evos, M3s, 350Z, etc. and whatever else comes. Last time I entered (2007), I was 3rd top time of day with about 50 cars in the event.
Old Nov 11, 2008 | 09:22 AM
  #69
Shizzle-Shane's Avatar
nice job! Now we just need that sound clip
Old Nov 11, 2008 | 10:01 AM
  #70
Torgus's Avatar
what's a high speed time trial? got a link? i'm honestly just curious cuz on an autoX course i would think they would smoke you. again no offense but an evo m3 sti etc should leave you in the dust.
Old Nov 11, 2008 | 10:11 AM
  #71
Apollos2's Avatar
Perhaps in a 1/4mi race but not necessarily on the autocross course:
http://forums.maxima.org/6th-generat...me-trials.html
Link to vid is at post #16. He's serious. Check it out.
Just think what he could do if he put his tires on the right way.
Old Nov 11, 2008 | 10:58 AM
  #72
Torgus's Avatar
lol
Old Nov 11, 2008 | 11:10 AM
  #73
Apollos2's Avatar
:attention
Originally Posted by AV8R
What Makes People ......
Perhaps the wrong forum?
Can a MOD remove this huge post?
Old Nov 11, 2008 | 11:39 AM
  #74
SmokeNismo's Avatar
uhhhh, wtf was that.
I came in here for updates on Deus's setup hoping for a sound clip and i see that?
Mods please remove that piece of spam.
Old Nov 11, 2008 | 04:20 PM
  #75
I am downloading a video now. Will be up in a few min. There will be more later.
Old Nov 11, 2008 | 04:29 PM
  #76
Here ya go:
Old Nov 11, 2008 | 04:35 PM
  #77
PulsarGTS's Avatar
Its sounds really loud, ballzy but loud.
Old Nov 11, 2008 | 04:50 PM
  #78
Its not THAT loud. The cam is right behind it.
Old Nov 11, 2008 | 04:59 PM
  #79
Turbo'd Saab
Here ya go:
you forgot to leave the car unlocked LOL
but a nice sound none the less.
I'm going to try a glasspack cherry bomb for a resonator 27" long
Old Nov 11, 2008 | 05:01 PM
  #80
dammit, someone noticed
