disconnected batt - now surging/lurching? wtf
Old May 30, 2009 | 09:08 PM
Y2k2maxse's Avatar
i had an ses light for no apparent reason..couldnt figure out why so i disconnected the batt to reset it n see if it comes back..now when I drive i get a pretty bad surging/lurching while accelerating...like engine is giving in and out..its a 6mt and i feel it mostly at rpms up to 4k...last time i had this problem was in my 2k maxima and turned out to be the common maf sensor problem.. but i dont wanna just buy a maf for this car and find out its not that. any suggestions? btw ses light code, loked up tsb said check for exhaust leaks and check injector voltage or something no exhaust leaks and doubt its injectors... 136k miles.
Old May 30, 2009 | 10:35 PM
NiZMo1o1's Avatar
Does the car lagg ? could be clogged up cats or gasket leak..
does the car sound like a lawn mower ?
Old May 31, 2009 | 04:50 AM
ramberg's Avatar
GrandPa
When was the last time you had a tune-up? Did you change the plugs at 100,000 miles?
Old May 31, 2009 | 09:19 PM
mynameispee's Avatar
idle air volume re-learn procedure?
Old Jun 1, 2009 | 04:56 AM
Lovemycar's Avatar
If the SES light was on why didn't you pull the code at AutoZone or something
Old Jun 1, 2009 | 03:42 PM
po8pimp's Avatar
chances are the ses light will come back. let us know what it is when it does. I would do the seafoam cleaning procedure and see if that helps. Also get some MAF cleaner. I recommend cleaning the MAF everytime you change your intake filter. Surging can be caused by alot of things, that code would be nice. Check your rpm needle at idle and see if it is steady or moving. should be steady if not clean the MAF and do the idle learn procedure after that, but only if needed.
gigabyte
Jan 6, 2017 06:05 PM
doctorpullit
Mar 29, 2016 11:08 AM
maxima297
Sep 30, 2015 03:32 PM
AaronL
Sep 23, 2015 03:34 PM
Colossus
Sep 9, 2015 05:46 AM
