Mass air flow problems
Old Aug 22, 2010 | 10:00 AM
I VIK I's Avatar
My mass air flow has hit the ****, I will get a replacement as soon as I can (Probably Monday or Tuesday) but until then I will need the car. For now the acceleration lags and the car makes a big clunk when it goes into gear. My question is will this damage the car? I understand the car is running some sort of safety map right now since the MAF isn't working but its the clunking of the gears I'm more worried about (Its stuck in 5th gear according to manual mode and when I try to up-shift or downshift it clunks again)
and I know its the maf because I swapped a friends MAF temporarilly
Thanks,
Vik
Old Aug 22, 2010 | 10:12 AM
LucKie1nE's Avatar
Any form of not letting the engine run proper will evently do damage..
Old Aug 22, 2010 | 11:04 PM
po8pimp's Avatar
use MAF sensor cleaner. I highly recommend using it every time you change your air filter. check the wires for corrosion. These things are pretty well designed.
Old Aug 23, 2010 | 10:01 AM
Apollos2's Avatar
Wow I've never cleaned mine.
Old Aug 23, 2010 | 12:24 PM
Blkmagic's Avatar
I've cleaned mine once or twice...if you end up needing one, I have a spare, just let me know
Smackasmith
Feb 1, 2016 12:40 AM
slowlifer
Sep 8, 2015 05:53 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
Justin Kroll
Sep 2, 2015 11:06 AM
