PCV (Positive Crankcase Ventilation) Valve
Old Oct 28, 2010 | 01:03 PM
NismoMax80's Avatar
SuPeRmOd
PCV Valve replacement is recommended every 30k. Like any maintenance it is debatable if you're conservative or liberal with how often you replace parts...
regardless, anyone know off hand what's involved? Can't find any help. Even the FSM is no help. I understand it is located somewhere on the rear of the engine on the driver's side...
a write up would be great, or tips and I can write it up after I swap mine out.
Thanks!
Old Oct 28, 2010 | 05:10 PM
Terrentius's Avatar
It is to the rear on the passenger side just down behind the intake manifold. I have an 07, so I have to either take the intake manifold off or the COWL TOP to get at the PCV valve.
Old Oct 28, 2010 | 07:32 PM
NismoMax80's Avatar
SuPeRmOd
so i might as wait until I change my spark plugs...
parts guy at dealer told me driver side. although the FSM looked like possibly passenger side. But still not clear enough for me to jump into this little project and get right at it. Just don't enjoy removing parts and searching for a part blindly.
any other input?
I'm hoping more become aware of this maintentance item since i see little to no discussion about it.
Old Oct 28, 2010 | 07:42 PM
Terrentius's Avatar
Yeah, I am chainging mine out when I do the plugs in the spring. She is really tight for me...no way I could change it out without taking one of the aforementioned off.
Old Oct 28, 2010 | 08:07 PM
NismoMax80's Avatar
SuPeRmOd
thanks Terrentius for the pics.
If you pick up a valve you can easily recognize it under the hose. Looks like only the cover needs to be removed to access the hose...
Old Nov 6, 2010 | 06:16 AM
luis narvaez's Avatar
Wow,i cant believe all the crap you have to go through just to replace a simple PCV.
Old Nov 6, 2010 | 08:37 AM
Terrentius's Avatar
You are right! It is not cool!!!!!
Old Nov 6, 2010 | 12:14 PM
NiZMo1o1's Avatar
Well alot of people dont think about this , if you change manifolds as much as I do you will also notice that the PCV will also cause blow by oil,
if you open up the VIAS plate you will more than likely see alot of oil inside the intake manifold.
there hose route from PCV to the intake manifold.
for some you can run a DIY mini catch can to catch the oil before it goes into the manifold, or you can drilled out the PCV for the catch can.
if you dont want to do either, just replace the PCV as its a routine mainitance
DIY catch can mod :
http://my350z.com/forum/engine-drive...catch-can.html
http://my350z.com/forum/engine-drive...n-diy-pix.html
But to get to the PCV , you need to pull off the manifold off , and you might as well change the plugs while your back there
Old Nov 8, 2010 | 05:57 PM
Houstonhulk's Avatar
2007 slightly different?
I recently had to replace mine and talk about a P.I.A.. First I had to removed the windshield wipers, plastic cowl piece and finally a metal crossmember right about the firewall to have enough space to get my hands in there. By looking at the picture you guys have posted, it doesn't seem like the 2006 and down models had this problem. Correct me if I'm wrong. Here are some pics to show you what I'm talking about.
Old Nov 8, 2010 | 06:11 PM
Terrentius's Avatar
I think you are pretty much right on the money. It is such a drag....
Old Nov 9, 2010 | 04:41 AM
Kenneth Joseph's Avatar
replaced my PCV in my 1999 Maxima SE and all the engine ping is finally GONE!!!
Old Nov 13, 2010 | 01:19 PM
Terrentius's Avatar
Changed my PCV valve out today..wasn't as bad as I thought it would be. The pics from Houstonhulk made the difference in my morale to this task. Props to him.
Now for a question to him. When I took the cowl off, there was this strange floppy piece of rubber with two clips on it. It was just laying there. I assume it has a proper place to go. Any ideas?
Old Nov 16, 2010 | 05:31 PM
I have no idea Terrentius, I was wondering the same thing. I just placed it back in there.
Old Nov 16, 2010 | 05:36 PM
Terrentius's Avatar
Yeah, I just put to the right of the vent for the cabin air-intake. Actually in front of the hole that is to the right of the intake. Strange though...it just doesn't seem to fit anywhere....
Old Nov 17, 2010 | 05:40 AM
MadMax07SL's Avatar
Is it really every 30,000 on the 07? I heard it was longer...
Old Nov 17, 2010 | 07:53 AM
Terrentius's Avatar
Well, I am at 60k and my PCV valve was pretty gummed up. I also had a pretty rough idle. I will probably do mine now at every 30k interval.
Give this a read to clarify justification: www.filtercouncil.org/techdata/tsbs/94-2R1.pdf
Old Nov 17, 2010 | 11:20 AM
MadMax07SL's Avatar
You're saying you did it at 60k, and it cleared up a rough idle?
Interesting.
What's the best place to get one of these, dealership, or any auto parts store should have adequate replacements? Is there an online source anyone would like to recomend?
Old Nov 17, 2010 | 11:39 AM
Jatan's Avatar
I should've done this a month or 2 ago when the weather was warmer lol -- completely forgot about it since Advance Auto's website doesnt even have a PCV valve listed for the 07
Autozone shows $16
Pepboys $23
NAPA $12
O'reillys has one for $9 and another for $11 so I'll go pick one up from there and hopefully try to replace it this Friday (should hit 55 deg so not too bad)
Old Nov 17, 2010 | 12:05 PM
Terrentius's Avatar
Interesting.
Not sure if it has cleared up the rough idle....but I assume that the old PCV valve contributed to it. To check it would require reinstalling the old one and visa versa to see if a pattern exists. Anyhoo, while at stop-lights the car is not shaking as much. The true test, however, will be in the summer cause that is when the rough idle is most pronounced in my case at least. I gots my fingers crossed though
I assume you can just pci one up an Auto Zone, Napa or even the dealership. They are not that expensive.
Old Nov 17, 2010 | 01:02 PM
NismoMax80's Avatar
SuPeRmOd
I paid $16 or $18 at the dealership.
Ugh I want to do it now, but come spring plan to do my plugs anyway which would be easier to do this at the same time. at 71k now
Old Nov 17, 2010 | 01:41 PM
Terrentius's Avatar
Do it now, bro. The hardest part is taking off the wiper-arms if you can call that hard. Pop those puppies off, pull off the plastic part to the cowl, then the metal cross beam and you are good to go. Took me under an hour.
Old Nov 19, 2010 | 01:33 PM
67 Lamnas's Avatar
Anybody have the Nissan P/N handy for an 08 Max?
Old Nov 19, 2010 | 02:04 PM
67 Lamnas's Avatar
Answered my own question...for others, here it is.....
11810-8J101
Old Jul 14, 2011 | 09:47 AM
Switch's Avatar
OK. I know this thread is old but I just wanted to add some things for people attempting this as a DIY project. Definitely not a hard one to pull off. You need a 10mm socket with a 6" extension for the 16 bolts that hold the cowl support in place. You also need a 15/16" deep-well socket to pull the pcv valve out with. Also, be careful when removing the plastic cowl as the clips that hold it in place are designed to stay put and the cowl slide off of them in one specific direction. I believe the one on the drivers side clips in from the drivers side and the other two clip in place from the passenger side. Don't pull straight up on them as they will snap and you will have a leaky seal around the windshield.
Also, check the hose from the pcv valve to the intake. Mine was split and so I replaced it with a short section of 3/8" fuel hose I had laying around.
Good Luck.
JB
Old Jul 30, 2011 | 06:35 PM
Longhorn101's Avatar
What a PITA. In most cars this is a 5 minute job. I broke two clips on the cowl and can't find replacements. Great design Nissan....
Old Jul 30, 2011 | 07:24 PM
Shift_Max's Avatar
Random question for you guys, but I replaced my pcv valve. Now with the engine running, I could hear the air moving through it. Sounds like a vacuum leak even though i know there isnt one. Normal or is it supposed to be quite at idle?
Old Aug 10, 2011 | 10:49 AM
Terrentius's Avatar
I would check the PCV valve hose. She might be a wee bit cracked/torn.
Old Aug 10, 2011 | 12:29 PM
revvinMAXto11's Avatar
what are the advantages of replacing the PCV valve? is it just a piece of mind or does letting it go hinder performance? when i installed my BOP i looked into my IM and it was as clean as a whistle in there.
Old Aug 10, 2011 | 01:16 PM
Terrentius's Avatar
Two reasons:
1-Relieves pressure inside the crank case. Too much pressure brings on blown head-gaskets and the like. Think about the weakest link in the crankcase...it is gonna give if your PCV valve is not function properly. When the force of pressure exceeds the force of the parts holding your crankcase together, then you gots a wee problem.
2-It redirects both moisture, brought in through the air intake, and gasoline, both of which blow-by the piston rings, back into the combustion chamber to be burnt off. In fact, there is a considerable amount of both that gets past the piston-rings into the crank case. You don't want moisture in there cause it will cause rust inside the crankcase, and you don't want gasoline in there because it breaks down oil, which is self explanatory.
This is why your change your PCV valve.
This is also why you should change your oil regularly. Your oil changes color because of the dirt, moisture and gasoline getting by the piston-rings, due to blow-by, into the crank case. Changing your oil infrequently is just asking for trouble. This aforementioned gets past your piston-rings and there is no way around it. So, change your PCV valve and change out your oil regularly and you will get the best of your engine for as long as possible.
Old Aug 21, 2011 | 02:29 PM
HVACJOHN's Avatar
PCV VALVE REPLACEMENT
GUYS YOU DO NOT NEED TO REMOVE ANY COWLS OR MANIFOLD COVERS TO REPLACE THE VALVE... I USED A 23MM SOCKET, A UNIVERSAL JOINT AND A SMALL EXTENSION TO REPLACE MINE. IT TOOK ABOUT 15 MINUTES TO COMPLETE AND I DIDNT REMOVE ANY OF THE MENTIONED ABOVE PARTS. JUST REMOVE THE 2 ELECTRICAL CONNECTORS AND DONT WORRY ABOUT MIXING THEM UP, THEY ARE FOOLPROOF.. ONE IS A 6 PIN AND THE OTHER IS A 8 PIN, THEN REMOVE THE HOSE FROM THE MANIFOLD AND THEM OFF OF THE VALVE AND PUT THE WRENCH ON AND REMOVE.. ITS THAT EASY, THE ONLY THING I RECOMMEND IS THAT YOU DO IT WHEN THE ENGINE IS COOL, I DID WHEN IT WAS HOT AND BURNED MY HAND... I KNOW I'M DUMB
Old Aug 21, 2011 | 02:46 PM
eK9aT10pSi's Avatar
when you say universal joint do you mean like a 3/8" or 1/2" swivel joint? damn, im thinkin i should do this now. i have an 04 with ~101k. and what sucks is like 2 months ago, i did spark plugs and NWP spacers it wouldve been cake walk then id bet.
Old Aug 21, 2011 | 04:53 PM
I really thought about trying it the way you describe but no way I could get my hands and tools back in that small space. I would have much preferred not removing all that stuff....
Old Aug 22, 2011 | 03:12 PM
HVACJOHN's Avatar
I do mean a swivel joint or universal joint and i had to use a 1/2'' drive because the 23mm socket was a 1/2''... and guys YOU CAN GET YOUR HAND OR HANDS IN THERE to replace it. Sorry to you guys who had to remove parts to replace it.
Old Aug 22, 2011 | 05:09 PM
Terrentius's Avatar
Yes, you should have plenty of room if you are driving anything before an 07/08. If you, however, own an 07/08, then you are most likely going to have to take the cowl off, unless of course you are a midget-contortionist
Old Jun 11, 2019 | 05:59 AM
maxprivate's Avatar
Black Lion
Ok know this is an old Thread guys and I’m bringing it back!
I did the 3.5 swap on my 97, the rear pcv I want to bring to a catch can and go back into the manifold. I’m supercharged so I don’t want blow by oils getting into my manifold.
The front crank case is just a fresh air intake when the rear pvc vents, correct?
If that’s the case, I only need to run a hose before the throttle body or any fresh air source. I have a dual catch can, for front crank case I’m thinking out routing the the hose out the front crank case, through the catch can, and back to a fresh air source. This way any gases are flowing through the catch can first before going back into the engine. Or now that I’m thinking out loud maybe I don’t need a catch can for the front crank case since it’s just fresh air in.
That sound right to anyone?
smitty124
31
May 6, 2011 09:12 AM
sagemistse
Aug 25, 2004 08:22 PM
ThePauser
Apr 29, 2004 09:44 PM
dvenki
Oct 24, 2003 12:18 PM
wizard6161
Apr 30, 2001 03:53 PM
