coil packs
Old Nov 21, 2010 | 01:35 PM
jay3250's Avatar
coil packs
Ok guys, I was changing the spark plugs in my 04 maxima se and I went to take off one of the coil packs and it actually came apart!!! The top electrical part with the clip seperated from the rubber boot and the spring was lefft in the boot which was still on the spark plug. I freaked out thinking that I ruined one of the coil packs so i decided to put it back together to see if it would run properly. As far as i can tell it doesnt seem to be misfiring. Would it throw a code if it was? Are these coilpacks made to come apart like that? Would any harm come if I just umplug that coil pack from the clip to see if that cylinder is firing?
Old Nov 21, 2010 | 03:43 PM
Lovemycar's Avatar
If the cylinder wasn't firing you would know you should be fine is idle smooth?
Old Nov 21, 2010 | 04:05 PM
jay3250's Avatar
it seems to run fine. idle smooth. I just know that the others did not come apart like that. If there was a misfire would it throw an ses right away
Old Nov 21, 2010 | 06:03 PM
po8pimp's Avatar
I would leave it until you can get a new coil pack to replace it with. they are not supposed to come apart. should work fine if idle is smooth and pack is tightened down.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
