Aluminum Engine Splash Shield
Old Mar 2, 2012 | 10:18 AM
Apollos2's Avatar
Aluminum Engine Splash Shield.
Hey check this out, took the plunge and decided to make a more permanent fix to my ragged Front Bumper Lower Engine Splash Shield. I know I’ve replaced it at least once from the dealer. If I remember right it was around $90.
Our cars are naturally low, and then 90% drop them on springs, sorry to admit but I still scrap it on parking blocks etc even though I try to be careful. Bottom line, I ended up ruining my lower engine splash shield. I think twice in since I bought it in 2004.
You can get cheaper versions on Ebay but let me warn you, I made that mistake when it came to fender liners for the front. $15each, the arrived rolled up in a little ball in a small box, super cheap and flimsy. Be careful ordering plastic parts from EBay
Anyway, I ordered the aluminum version, it's really light weight. If it weighs much more than the plastic one, I'd be surprised. I'll weigh them later.
Link: http://forums.maxima.org/6th-generat...h-shields.html
IT ARRIVED SUPER FAST AND WELL PACKAGED
IT EVEN INCLUDED THE CLIPS I NEED TO INSTALL IT
BUBBLE WRAPPED NICELY
A REAL QUALITY PIECE CAN’T WAIT TO INSTALL IT NEXT WEEK
AWESOME
Old Mar 2, 2012 | 10:21 AM
MAX/GTR's Avatar
SICK!!! Do they make these for the 4th Gen?
Old Mar 2, 2012 | 10:38 AM
Apollos2's Avatar
I bet he can do it.
Old Mar 2, 2012 | 11:14 AM
smittybizzle's Avatar
I am so glad you posted this b/c I was about to buy another OEM one .
Old Mar 2, 2012 | 11:19 AM
Apollos2's Avatar
I'll post up some more pics as I do the install on Mon or Tues.
Old Mar 2, 2012 | 01:18 PM
CMax03's Avatar
Believe it or not I'm using 5.5th gen splash shields on my 4th gen....They are identical in many ways ! But I think the 6th are completely different.....do an experiment dude buy some junkyard 6th gen splash sheilds and test fit it! You maybe able too adjust they to fit and do the same to the new aluminum piece! That new piece is nice but it won't give and flex like the plastic so it could break other things if you run over something next time....but it's nice no doubt!
Old Mar 10, 2012 | 08:27 PM
Apollos2's Avatar
I finally got around to getting the shield installed. It was super easy :shakeshout:
I got all ready to remove and weigh the stock shield. It was gone. I must have lost it in a snow storm.
The vital statistics
Weight = 2.5lbs
Stock weight = Unknown
Total weight gain = Uknown
Cost of the stock $94 part plus clips 11 of them at $1.63 each equal $17.93
Total of stock = $111.93
If that group buy holds up you get everything for $100. You make the call.
UP ON THE RAMPS
THE CLIPS THAT CAME WITH IT
CLIPS IN PLACE. NOTICE HOW IT IS LAYING THIS IS THE TOP SIDE
FACING THE ENGINE
PUT THEM ON LIKE THIS
THERE IS A SMALL LIP/EDGE ON THE BUMPER, MAKE SURE YOU GET THE SHIELD TUCKED IN BEHIND IT
SEEMS TO BE A VERY SMALL ISSUE, THE SHIELD IS SNUG IN ALL PLACES EXCEPT RIGHT HERE
PERSUADED IT A LITTLE BIT
SOME GENTLE TAPPING TO BEND IT SLIGHTLY AND THE PUSH PINS POPPED RIGHT IN.
Old Mar 10, 2012 | 08:28 PM
Apollos2's Avatar
DONE. VERY SNUG, SCREWS IN TIGHT, THIS THING IS NOT COMING OFF.
Old Mar 11, 2012 | 02:06 PM
KCMAXX's Avatar
KC's FINEST
Looks nice, seems it would be a pain come oil change time. Either in the way or a huge filter oil catcher.
Old Mar 11, 2012 | 03:34 PM
killemall2k's Avatar
my spash guard is all messed up, i just considered this option. i think getting to the filter is the only bad thing about this.
Old Mar 11, 2012 | 04:39 PM
Apollos2's Avatar
Question, is the stock shield in the way too then? I never change my own oil so I don't know.
Old Mar 11, 2012 | 04:55 PM
i actually own a 5th gen, so i dont really know where the filter is on a 6th gen. but whenever i change my oil i gotta move the splash guard in order to get to it.
Old Mar 11, 2012 | 05:01 PM
ShocknAwe's Avatar
Very nice
Old Mar 11, 2012 | 05:03 PM
CMax03's Avatar
Whether you own a 3rd, 4th, 5th, 6th, or 7th ...the filter isn't in the front so that shield isn't a problem! I would've painted it semi-gloss black though! It's nice,.... now make one for the rear and you'll increase you MPH thru the 1/4 mile!
Old Mar 11, 2012 | 05:18 PM
Apollos2's Avatar
Originally Posted by killemall2k
i actually own a 5th gen........whenever i change my oil i gotta move the splash guard in order to get to it.
BUT
Originally Posted by CMax03
Whether you own a 3rd, 4th, 5th, 6th, or 7th ...the filter isn't in the front so that shield isn't a problem!...
Which is it? If the shield is in the way, then that's a bit of a problem because while you can remove the push pins the same way you would with the stock shield, there isn't any give in this, so maybe you have to remove the whole thing?
....now make one for the rear and you'll increase you MPH thru the 1/4 mile!
You read my mind, I already hit up the maker about that too
Old Mar 12, 2012 | 01:19 AM
CMax03's Avatar
BUT
My point was that the oil filter isn't in the front on any of the Maxima(s) since actually the 2nd gen! Your filter is located in the passenger wheel well on the 4th, 5th, & 6th and can be removed with or without removing the side splash shield! But the front shield isn't even in the equation when changing ones oil!
Old Mar 12, 2012 | 08:01 AM
spddracer's Avatar
Correct, This shield in no way has to come off to change the oil, There is really no reason to ever have to take it off, I even put a hole in it so you can drain the coolant.
The side flanges do require a little adjustment when installing, they can easily be bent by hand to line it up level with the subframe, no hammer needed
Old Mar 18, 2012 | 06:25 PM
spock's Avatar
I like this. Shipping to Canada?
Old Mar 19, 2012 | 06:32 AM
Apollos2's Avatar
Your going to want to get on the group buy over here: http://forums.maxima.org/6th-generat...h-shields.html
I don't make or sell, just bought one and posted up my findings
Old Mar 19, 2012 | 06:52 AM
spddracer's Avatar
6 Gen shipping would be $45 to Canada. I may be out of these at the moment, Need to count and see how many I have left, I need to make sure I can fill the orders that are already paid our people that have payments on the way to me.
I will get more made but it may take a week or so to get them done.
Thanks!
Old Mar 19, 2012 | 07:52 AM
locknuts27's Avatar
Apollos2,
Hey man, that's pretty freaking awesome find. Looks pretty sick! You need to do the rear and let us know if it helps you with the 1/4 mile times you were speaking of????
Old Mar 19, 2012 | 08:17 AM
Apollos2's Avatar
Originally Posted by locknuts27
Apollos2,
Thanks, yeah I love it, I waiting to see if Spddracer is going to make one for the rear!
(hint hint)
Old Mar 28, 2012 | 05:36 PM
Apollos2's Avatar
Got it sprayed with liner, came out nice. Then I'll re-install it one final time.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
jc53
Oct 12, 2015 05:12 AM
carid
Sep 17, 2015 05:00 AM
seesole
Sep 14, 2015 12:38 PM
mclasser
Sep 6, 2015 09:05 AM
