04 max cant open trunk w/o key farb???
hey whats going on guys... hopefully someone has this answer i checked the fuses replaced anyway even though they werent blown the gas button works which is right next to it but the trunk button doesnt work? any suggestions helpp thanx in advance
Look in your glove compartment, there is a switch on the left side. This switch turns on and off the functionality of the trunk lever. It's a security feature, if you switch it off, lock the glove compartment, and lock the rear seats, there is no access to the trunk without the key or key fob.
If it isn't that then I'm not sure.
The in cabin microfilter is in there, has anyone changed that recently, maybe bumped a wire or something.
i think i figured out the problem theres a braided metal wire that hooks to the trunk and its loose im thinking there isnt enough tension when i hit the button to open it... theres barely any room to get in there though im probably going to have to take half the rrear of the car apart. Nightmare! and i never even thought to change the in cabin filter.. going to do that this week thanx man! ill let you know if thats the problem though
Good luck. Here's a link to some of the trunk stuff in the factory service manual, starts on page BL-76.
http://www.nicoclub.com/FSM/maxima/2006_Maxima/bl.pdf
The rest of the factory service manual is here.
rbaker100
Sep 6, 2015 02:46 PM
