timing chain replaced won't start
Old Dec 13, 2012 | 06:54 PM
txtmoore's Avatar
2004 maxima. I have replaced my timing chain and other timing components and it will not start. Tore back down and made sure primary timing chain was in correct position. Wouldn't start. Tore back down again and made sure engine was at tdc, all timing marks, grooves, dowels, gold links, and blue links were aligned properly. Even made sure that the moon was in the seventh house, and jupiter was aligned with mars. Still won't start. What do I need to adjust or check now, to get this engine to start?
Old Dec 13, 2012 | 07:35 PM
Kryogen's Avatar
plug the battery?
Old Dec 13, 2012 | 07:41 PM
Fakie J Farkerton's Avatar
Originally Posted by Kryogen
plug the battery?
Wow. Save your keystrokes. I bet this guy is frustrated as he**. Don't make the org look like a bunch of a**holes.
I wish you luck OP.
Old Dec 13, 2012 | 07:50 PM
mrjasonlyrics's Avatar
I wish you luck OP.
It's not a stupid suggestion because something similar happened to my car when I had my timing chains replaced. The engine cranked but didn't start and my mechanic pulled out the timing cover re-did it and as crazy as it sounds there was a negative wire or something where he couldn't see and that was my problem.
Make sure all your connections are connected because the car not starting could be the either a off timing or a simple thing like a wire. Good luck man
Old Dec 13, 2012 | 09:13 PM
Cool then, but he did say this:
Old Dec 15, 2012 | 07:31 AM
Kryogen's Avatar
well, he did not specify anything, he just talks about the moon and planets.
Therefore it would be unreasonable to expect a serious answer to this.
Define "not starting"
Will it crank, or nothing?
Check battery, air, fuel....
What can we say to "not starting", seriously. Don't blame me.
Old Dec 16, 2012 | 03:57 PM
He must have figured it out..mystery question. His one post..Will he be back?
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
stromm
Aug 27, 2015 04:13 PM
erictown
Aug 20, 2015 08:01 AM
BobMax
Aug 15, 2015 12:35 PM
