06 with a mystery misfire..PLEASE HELP
Old Sep 11, 2014 | 02:00 PM
justin2386's Avatar
Car is throwing a random multiple cylinder misfire code P0500, have swapped injectors, coils, nothing has changed, have power to all 3 front cylinders to the coils, and have injector pulse as well..cylinder 6 is just dead, you can unplug the coil and nothing changes, but if you unplug 2 or 4 it dies down a little..any ideas?? Compression is fine too
Old Sep 11, 2014 | 04:53 PM
BigLou55's Avatar
Check your engine harness, make sure everything is seated properly and you have no damaged wiring. I just went thru this on my 5th gen and it ended up being wire breakage at cylinder 3.
Old Sep 12, 2014 | 05:56 PM
justin2386's Avatar
But we have power to both the coil as well as the injector and we have injector pulse
Old Sep 13, 2014 | 08:16 PM
justin2386's Avatar
Bump
Old Sep 14, 2014 | 05:25 PM
L36's Avatar
L36
Make sure you plugged the coil harnesses to the right coils.
Old Sep 16, 2014 | 05:58 PM
justin2386's Avatar
Everything is all plugged in fine
Old Sep 27, 2014 | 08:47 AM
justin2386's Avatar
Could it be something in the computer? This happened when I was getting on it a bit too..just wanted to add that in there
Old Sep 27, 2014 | 11:16 AM
CALIMAX06's Avatar
Just to make sure, you meant p0300 instead of p0500 right?
Old Sep 27, 2014 | 01:59 PM
justin2386's Avatar
Idr off the top of my head..last codes I remember seeing were the random cylinder misfire and cylinder 6 misfire codes
Old Sep 28, 2014 | 05:26 AM
Khamisalminawi's Avatar
Common problem with these years is the main ground breaking off the from negative cable of battery to Transmission. Which is the ground for engine also. Usually happens from not having a engine shield under car to stop water from corroding ground. If yours is broken, it may have burned out ECM. Sometimes causes coils to burn up and bubble on side and for little diodes inside ecm to burn up. Easy way to know is with a probe to check for power running through engine grounds. need any other help just text me at 3474584697. Have about 6 years expeeriance in every kind of problem on 6th gens
Old Sep 28, 2014 | 10:04 AM
justin2386's Avatar
the only thing is i think that the cable being corroded may have been noticed because the motor was just out of the car a couple months ago and rebuilt and put back in..is this something that could have happened in an instant? the car was running totally fine then a little pop bang boom and it was running like sh-it
Old Oct 2, 2014 | 09:37 AM
justin2386's Avatar
Found the problem..took valve cover off on a whim and lo and behold the bank 2 exhaust cam is broken! Great!
95seMax
May 22, 2003 10:30 AM
TimW
Mar 15, 2003 10:56 AM
blackandwhite
Oct 28, 2002 08:04 PM
Nmax92
Oct 21, 2002 06:56 PM
njmaxseltd
Jul 23, 2002 04:56 PM
