Noise from under dash (HVAC/heater), please help identify (video)
Old Dec 26, 2017 | 09:23 AM
DMAXI06's Avatar
Hello!
Please help identify the problem with my Maxima's HVAC unit.
The noise has persisted for several years, worsening each season.
NOTE: I have changed the actuator for the passenger side already to no avail. In the video, all functions performed worked as planned (heat/cool,modes all function normally). The issue seems to be with cabin vs fresh air.
Thank you!
Old Dec 27, 2017 | 08:22 AM
Doc Plus's Avatar
I checked the ATC section of the service manual.
On page ATC-34 there is a schematic which tells you where are located the different motors.
What I will do is to access each motor to find the one which makes noise. If I found one I will unplug it to see if the noise goes away.
Because of the noise location on your video, I will first check 2 of them: the "air mix door motor" on the passenger side and the blower motor.
Old Jan 16, 2018 | 11:29 AM
Roymg's Avatar
Originally Posted by DMAXI06
Hello!
https://youtu.be/lg24IeAepK0
Thank you!
Sound like a leaf against a fan blade.
James92SE
Sep 21, 2010 07:00 AM
nismopc
May 28, 2006 09:12 PM
limsandy
May 13, 2005 07:23 AM
steelymatt
Apr 11, 2005 08:17 AM
seno76
Sep 18, 2002 06:54 PM
