Sputter
Old Jul 24, 2019 | 09:48 AM
Sunburst's Avatar
Sputter
2007 Nissan Maxima. Randomly will sputter when start then fade out and run fine. Other times sputtering will not stop. If try drive get little acceleration and SES light will blink then stay on.
Was hooked up to reader said Camshaft sensor bad. And a misfire in #4. Replaced Camshaft Sensor. Replaced all 6 spark plugs. Ran fine. Now back to same issue randomly happening...at times when sputtering is a faint smell of gasoline. Injectors have been cleaned. What could ithe issue be??
Old Jul 24, 2019 | 10:09 AM
Tarzan's Avatar
Did you re-read codes when the issue returned? If you only replaced 1 cam sensor, the other one could have kicked the bucket since.
Post the actual codes if you have any.
Old Jul 24, 2019 | 10:16 AM
Sunburst's Avatar
Thanks for reply...I had taken to garage to have checked..do not have the codes. Was not rechecked after replaced. Was not aware is more than 1 Camshaft Sensor? Where would the other be located? How many of these sensors are in the car?
Old Jul 24, 2019 | 12:25 PM
Tarzan's Avatar
Download the FSM for all "where is it" questions.
There are 2x cam sensors, one for each bank.
Old Jul 24, 2019 | 12:35 PM
Sunburst's Avatar
Will do....Thank you
Old Jul 24, 2019 | 01:45 PM
TarmacSL1's Avatar
The misfire in #4 was probably not your Spark plugs but a bad coil pack. I had the same issue couple of months ago it would sputter during acceleration until you got to about 30+ mph and would flash the CEL but it would not stay on. It was my coil packs
Old Jul 24, 2019 | 02:15 PM
Sunburst's Avatar
Would bad coil pack give off smell of gasoline when start it ? I just started it again this time the smell of gas was bit stronger
Old Jul 24, 2019 | 02:35 PM
Tarzan's Avatar
Where does the smell come from - from the exhaust or from under the hood?
If it is from the exhaust, then the bad coil pack could explain it as 1 cylinder sends un-burnt gasoline down the exhaust pipe.
If it is from under the hood, then the bad coil pack would have nothing to do with it and the most likely reason is a dried up and loose fuel hose somewhere around the fuel rails sipping gasoline.
I had the latter issue on my 1993 Maxima during the cold season until I bought the short hose which connected fuel rails together and replaced it.
Move your coil packs around cylinders and see if misfire follows. If it does, then you found your culprit.
car5car
29
Aug 27, 2025 05:29 PM
Chris8428
May 29, 2018 05:07 PM
bvb_09
Jan 5, 2016 07:22 PM
BlackSpeed
Aug 21, 2012 05:43 PM
nismoSEXIMA
Aug 11, 2011 11:58 AM
